      09-02-2023, 07:00 AM   #1
scene.parade
Drives: BMW F10 M5
Best brake pads available
Hello allo,
I have a BMW F10 M5, which has been tuned to 900+BHP.
Having spoken to ML Performance, they recommend the Pain RSL29 brake pads, as they have superior stopping power to other brands such as EBC Bluestuff.
However, the RSL29s are road illegal. I have been informed that many drivers still use the RSL29 pads with no issues, other than it takes time for them to heat up to optimum working temperatures.
Any advice on the best brake pads available?
What effects should I expect from the RSL29 before heating up?
M5Rick60089.00
      09-03-2023, 02:33 AM   #2
Not a great expert on brake pads for tuned M's, some are great on the track but the pay off can be sluggishness on public roads so your best bet is to get a set with a good compromise.
Put some pics of the car on so we can see what you have and maybe some of our friends over the pond can help with that.
      09-04-2023, 04:14 PM   #3
m5rosco
Drives: 2016 F10 M5
Originally Posted by scene.parade View Post
Hello allo,
Hi.
You are correct in that the RSL29's are technically not road legal. However, this is because they are too good. To maintain the road legal standards in the UK pads have to be within a small percentage of the friction coefficient of the OEM pads, which is something proper performance pads exceed.
I use RSL29 pads and they work absolutely fine when stone cold. You wouldn't know they are not OEM pads, it's just they work at their very best when they are hotter.
They have similar dust levels to OEM, and if not driven on hard for a while on the road they can squeal a bit at low speeds, but then if you give them a hammering, and get them hot, they will then stay quiet again for a good few hundred miles.
Hope that helps.
      09-04-2023, 04:16 PM   #4
m5rosco
Drives: 2016 F10 M5
Braided lines and decent fluid help a lot too.
      09-18-2023, 03:05 AM   #5
scene.parade
Drives: BMW F10 M5
Originally Posted by m5rosco View Post
Hi.
Hope that helps.
I have ordered the RSL29s, but they have a 2-3 week turn around time.
Thanks for help.
m5rosco210.50
      09-18-2023, 03:06 AM   #6
scene.parade
Drives: BMW F10 M5
I have bought the Proline braided brake lines. I just need to install them.
What is the best brake fluid to use?
      09-18-2023, 06:56 AM   #7
We like to appreciate here mate, there's a button for that bottom left of the post.
m5rosco210.50
      09-18-2023, 08:08 AM   #8
M5_Brandoe
M5_Brandoe's Avatar
Drives: Black sapphire M5
Brake fluid- I’ve used Castrol React SRF in my high horse power and track cars. Look into that, they have high boiling points for both dry and wet.
Instagram MRBrandoe
M5Rick60089.00
      09-18-2023, 01:49 PM   #9
m5rosco
Drives: 2016 F10 M5
Castrol SRF is the best, but is very expensive. Motul RBF600 or 660 is very good stuff and reasonably priced.
      09-24-2023, 11:15 AM   #10
scene.parade
Drives: BMW F10 M5
Any advice on the best engine oil?
At the moment I am using castor 5W-30 fully synthetic.
