06-06-2014, 08:42 AM | #1 |
6'0 / 250lb
136
Rep 1,797
Improve Handling of NON-CP M5...?
Hi guys...
So what's the one KEY component to change to improve the handling of a NON-CP model...WITHOUT sacrificing the ride quality. Sway bars? Springs? Software? Bushings? It's for a Daily Driver and I transport customers and colleagues at times, so the ride quality NEEDS to be maintained.
06-06-2014, 09:06 AM | #3 |
Perennial PFC
336
Rep 1,274
It's always a combination of parts to make the handling better, but in my brief experience with the M5 I noticed a definite improvement with just the CP sway bar upgrade. Then, a further improvement by going to the 275/30-20 front tire for corner turn in and feel through the corner. That is from the stock 19" tire, so if you have the 20s already, maybe not such a difference. Still have stock springs and bushings and the only slight negative from the sway bars is that on a road surface that has undulations that affect either side of the car, but not both, the car will rock side to side slightly more than before. Very minor, and I doubt your passengers would mind.
06-06-2014, 09:16 AM | #4 |
Rep 739
Keep in mind that everything will be at least a bit of a trade off. I doubt there is much (if anyting) you can do to improve the handling in any noticable way that will not also affect the ride at least minimally. I am not saying that it is necessarily a proportional gain to loss, but I don't think there are an "zero sacrifice" handling improvements out there.
06-06-2014, 09:41 AM | #5 |
Rep 6,125
There is a member who wants to make his competition package M5 more softer/comfortable.
You should contact him and swap all suspension parts and leave really good iTrader feedbacks for each other. =D
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
06-06-2014, 03:26 PM | #7 |
Rep 5,109
I just addded M5 CP FSWB and M550d RSWB to my Eibach lowered, non M5 F10 (M5 RSWB doesn't fit on our "lesser" F10's ).
The lowering springs improved ride quality to a stiffer but still comfortable ride. Honestly, the major improvement was looks and not necessarily a better handling car... The M5 CP FSWB and M550d RSWB on the other hand transformed the handling and steering feel of the car!!! You can now push through the corners and feel how the front tires loads up and get a proper feedback on tire grip. It's so much more confidence inspiring and provides tons more feedback. It's so responsive to mid corner steering corrections and you definitely feel more in control over the car. You sense you can toss the car around in a totally different way. Turn the steering wheel and the car just responds! The ride quality haven't suffered noticeably. As mentioned above by another member, it might react more to uneven road surfaces that affects only one side of the car. But, it's not a big issue at all IMO. This is on a regular F10, not a "fancy" M5. But I suspect that the stiffer sway bars of the CP makes a major impact on handling on the M5 as well. Just look at some of the videos online and notice how much flatter the CP corners compared to a non CP M5. That is mainly sway bars. |
06-06-2014, 08:32 PM | #8 |
e36s54, e70x5d
151
Rep 1,723
Invest $3500 in a set of KW V3s and never look back.
Proper ride height, alignment, corner balance and compression/rebound settings makes this car handle better then an OE e92m3....it feels like it should have come this way from the factory. Best, most underated and most misunderstood mod for the F10M5 |
06-07-2014, 03:01 AM | #9 | |
Rep 5,109
But you trade off the electronic damper settings for either a fixed setting (V1) or manually adjustable settings (V2 and V3). I personally would not want to loose the easy adjustability of the electronic dampers unless I only drove on one kind of road surface all the time... With the V3's "infinitely" adjustable damper settings, how hard is it to find the right setting combinations? For me, with my limited track experience, I think that the V1 with settings determined by suspension engineers would have been a better choice? |
06-07-2014, 04:39 AM | #10 | |
e36s54, e70x5d
151
Rep 1,723
Only V3 and Clubsport The OE damper adjustment is more gimmick then functionality. In the hardest setting all you gain is ride quality harshness with the "effect" of less body roll due to the compression being limited. Lowering springs are more of the same with slightly lower center of gravity, mostly aesthetic for that lowered look. To improve this car's handling you can a) replace the sway bars for a little less body roll and/or b) coilover kit I was never a fan of KW until this F10M5 kit. It makes the car handle 30% better without turning it into a bouncy Honda. The street ride quality is amazing...it complies with bumps and road irregularities better then the OE adaptive shocks. I have not done the sway bar upgrade ...but to be honest....with this KW V3 kit, I dont feel the need. As far as the "infinite" settings on the KW V3s....not so much.... its actually 14 clicks on the rebound and 14 clicks on the compression. The settings are not that drastic between eachother....so more important then the compression and rebound settings is proper alignment, ride height and corner balance. Other then that I have both set to a medium setting with a little softer bias in the rear. Last edited by mastek; 06-07-2014 at 04:58 AM.. |
06-07-2014, 06:05 AM | #11 | |
Rep 5,109
06-07-2014, 10:33 AM | #12 |
Rep 6,125
i've also experienced KWV3. While it's lowering it, it was actually more comfortable (very smooth ride) yet, extremely sharp in turns. It was non CP M5 and boy, I think F10M5 KWV3 is one the the best KWV3 application they've designed.
06-09-2014, 02:34 PM | #13 |
Rep 211
I have had the AC springs fitted and can highly recommend them.
Makes the car look mean, hardly any difference in comfort and the car seems to perform so much better in the corners. Flatter and more precise. |
06-12-2014, 10:01 AM | #14 |
Rep 317
has anyone installed the dinan sways? if so did you set to most stiff setting or softer setting? wondering how much it changes comfort and why you choose this over the cp bars.
'22 Macan GTS
'21 911 C2S '20 Cayenne '16 X5 50i M-sport (3rd row!) |
06-17-2014, 08:03 AM | #15 | |
Rep 1,840
06-17-2014, 11:14 AM | #16 |
Rep 357
What are the warranty implications for installing aftermarket springs? I did it on my Audi a few years back and they voided my suspension warranty. Has anyone had any issues with this?
06-17-2014, 01:07 PM | #17 | |
Rep 6,125
Most likely BMW dealer will not like it if you modify it and they will try to blame any issue to aftermarket parts but honestly, it's pretty rare to have any issue on the suspension parts (I always upgraded suspension parts from my 99 M3 but never needed any service). So you don't need to worry too much (in my opinion).
06-17-2014, 02:26 PM | #18 |
Knight Commander
559
Rep 5,948
I have the Dinan Sways in the softest setting and I find it is a dramatic improvement over stock. Car is very flat.
I don't see any need to change springs.
2022 Mercedes-Benz EQS 580
06-17-2014, 02:27 PM | #19 | |
Knight Commander
559
Rep 5,948
CP bars are too weak. They work in conjunction with stiffer springs and shocks. IMO Dinan sways with OEM suspension delivers a more flat cornering with smoother ride than CP. This is the best of all worlds.
06-18-2014, 02:01 PM | #20 | |
Rep 357
06-18-2014, 02:05 PM | #21 | |
Knight Commander
559
Rep 5,948
The reason for buying the Dinan Sways over CP sways is because they are 35%-70% stiffer than stock based on the setting. CP sways are only 20% stiffer, because they also work in conjunctions with stiffer springs and shocks to reduce body roll. In case of a non-CP car, you need the sways to do more work when cornering so that's why I went with Dinan. It's also a really high quality product. I bought them and installed them at my local Independent Dinan dealer. I was going to buy from the BMW dealer but in the end I didn't trust them with my car so I went to the Independent Dinan dealer who is actually a friend of Coldlist. These guys were superb. They also did my exhaust.
06-18-2014, 02:13 PM | #22 | |
Rep 357
