10-06-2014, 06:56 AM | #1 |
Rep 116
M5 in the snow
How is the m5 in snow? I would like to use it this winter in the New York area with snow tires. I probably wouldn't use it in major storms but the day after with roads plowed but snow still on them would it be fine? I also have the competition package which probably doesn't help matters. Thanks
10-06-2014, 08:46 AM | #3 | |
///MSport-DC
73
Rep 274
Drives: 2013 F10 M5, 2012 X5 35d
2012 BMW X5 35d (Alpine white/Black - Loaded) - Delivery: 2012/9/17
2013 BMW M5 (Azurite black/Black full merino/Piano trim/20"/Exec./Driver Assist. - Delivery: 2012/11/16 (GONE) |
10-06-2014, 09:00 AM | #4 |
Rep 116
How about just cold weather but no snow. On a 20-25 degree day are the factory tires still bad enough you need snow tires just in the cold?
10-06-2014, 09:07 AM | #5 |
Rep 116
Also, has anyone gone with the BMW winter tire set up? I believe the dealers offer a winter tire set up option although I can't find it on the site currently?
10-06-2014, 09:07 AM | #6 |
Rep 7,885
Once the temps outside start getting like below 15 degrees F, then the compound of the PSS's start to be affected. I've raced on a racetrack with the stock Michelin PSS's in temps below 32F, and the level of grip was unaffected. However, having the tires exposed either on the car or not on the car and just sitting outside to freezing temps for long periods of time, say months on end, the treadwear ability of the tire decreases. The PSS's are good tires to drive in below freezing temps on dry pavement only. On ice or snow, they are practically unusable, and if you try, you will crash the car.
10-06-2014, 09:24 AM | #7 |
Rep 2,245
I would say get winter tires, no doubt. You will be fine as long as you dont drive in big storms. I wouldnt want to drive on PSS tires in the cold weather though, they will freeze up.
That being said I just sold my winter tires and got a Jeep - felt bad for the M with all that sand and salt.
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red Last edited by PatrickC23; 10-06-2014 at 09:31 AM.. |
10-06-2014, 10:26 AM | #9 | |
Rep 2,202
Thats on summers with 40-60% tread left I climbed two mountains in those conditions and it only got worse took me 2.5hrs to get 40 miles but still, I'm here speaking to you today... Lets not forget the supersports have very good wet ratings, and our cars with passengers weigh almost if not more than 5000lbs. I think the best thing for anyone to do is to get winter tires, but the car performs remarkably well for light winter conditions.. Above 60+ you can mash it and hook fine.. 30+ eh better know what you're doing |
10-06-2014, 10:29 AM | #10 | |
Rep 7,885
10-06-2014, 10:31 AM | #11 |
Rep 2,202
10-06-2014, 10:35 AM | #12 |
Rep 4,721
wow. if you guys are driving in snowy conditions with summer, I got to say, "Brave" and hope you don't cause misery to other drivers on the road.
I drove mine with just one summer (rear driving wheel) on last winter due to a flat tire and it was rock solid hard and no traction at all. |
10-06-2014, 10:38 AM | #13 | |
Rep 2,202
Its far from ideal but as equally far from catastrophic. I will say I never came to a complete stop that trip and am curious if I could have gotten moving... Once I made it to the highway changing lances was awful since it was all piled up in the centers, and my slowest stoping speed getting back going was a tad challenging. As for the picture above I didn't go out looking to drive I was away from home and it called for rain that day.. When flakes started showing up I tried to get home as fast as possible [wasn't fast enough ] |
10-06-2014, 10:55 AM | #15 |
Rep 1,548
Driving these cars in freezing conditions with summer tires is nothing to brag about.
It's analagous to saying you spent a week in Bangkok without using condoms and didn't catch anything. So it must be ok right?
CURRENT:
His: Porsche 991 Turbo S Carrera white/Black Hers: BMW X3MC BSM/Black |
10-06-2014, 10:59 AM | #16 |
Rep 2,202
No and its not bragging... It's saying that if you drive in sub ideal conditions as long as you adjust reaction time and other conditions accordingly you could certainly make it through a winter fine... And simply pointing out to the OMG world will end if you drove it on a Sunny day when it's 15degrees crowd that it's simply incorrect.
I'd also note there are plenty of days at least 8 that I went no where as a precaution. The tires preform quiet well and while serious limitations arise in anymore snow than pictured above, and especially ice. If you pick your days when you go out it's quiet capable. Again we aren't talking about a 3300lb Z06. This car with drivers and passengers and a full tank is 5000lbs lol Last edited by M5Rlz; 10-06-2014 at 11:05 AM.. |
10-06-2014, 11:11 AM | #17 |
Rep 7,885
How'd you know I was in Bangkok?!
10-06-2014, 11:37 AM | #18 | |
Rep 1,548
CURRENT:
10-06-2014, 12:45 PM | #19 |
Rep 798
So, with the bad snow and snow storms that we get here in NYC, even with winter tires, the M5 should not be driven?
That is a bit of a downer. I am planning on having it as my only car (can't keep more than 1 car even if I wanted to given the space restrictions in my condo building). NYC drivers - thoughts? How was your car last winter? Did you drive it in bad weather or didn't drive it when it was bad snow? Thanks, |
10-06-2014, 12:53 PM | #20 |
Rep 116
I live just north of NYC which is why I asked the original question. Hopefully with winter tires it will at least get me to the train station in snow and around on weekends once the streets are plowed. I assume do you guys drive it in D1 mode vs shifting for yourself in these condiitions?
10-06-2014, 01:01 PM | #21 |
Rep 1,844
With snow tires you can drive the car as long as you are cautious and the roads are plowed.
The 19" package uses 408M wheels. The challenge for some is that most US dealers don't have snow tire packages for cars with CCB. There is a European package with 409M (20 in) but this is not available in the US. One can use 343M fronts in all positions with 255/35/20 snow tires but it is expensive (~$6000). |
10-06-2014, 01:10 PM | #22 | ||
Rep 2,202
In the picture above with snow if you added an inch or two of accumulation I think I'd have been done or wrecked. Even going down and up hills with 2+ of PACKED plowed accumulation was challenging and I wouldn't attempt. If its just really cold sub 32... It should be fine just don't tailgate or gun it too much as traction and stopping was different. Bottom line: If like here in DC where its 50-50 what kind of winter you have I'd risk it knowing a week or two worth of days inside is a safe assumption you'll make it out ok, but up there where its like 80-20 you'll see big snows/ice/etc. then I'd have gotten the $4200 tire package from bmw for the 19'' wheels. Quote:
