04-24-2014, 09:12 AM | #1 |
Rep 174
Valentine 1 Radar Hardwire-not off sunroof
I plan on hard wiring my Valentine 1 radar detector after work today. I need to stop by the auto part store to pick up a fuse tap kit. There is a nice write up in the DIY section on tapping it off the sun-roof; however, I want to see if there is a way to tap it off one of the fuses in the glove dept. I have done this successfully in the F01 750 and in the e92 m3.
Can you advise which fuse I can work off of? The car is fully loaded except for night vision and rear entertainment. Thanks guys |
04-24-2014, 10:41 AM | #2 |
Rep 1,622
I do know it's possible to tap a fuse in the glove.
I would recommend using the sunroof though. Less wiring to route / seems like a cleaner install option?
04-24-2014, 10:56 AM | #4 | |
Rep 846
04-24-2014, 01:10 PM | #5 |
Rep 174
04-24-2014, 01:11 PM | #6 | |
Rep 917
04-24-2014, 01:13 PM | #7 |
Rep 1,622
As mentioned above, it's very easy to remove the light housing.
04-24-2014, 01:35 PM | #8 |
Rep 174
04-24-2014, 02:44 PM | #9 |
Rep 846
Well thats even better use that but make sure u use that thing called tap a circuit
04-24-2014, 03:34 PM | #10 |
Rep 365
Running a power cable from the fuse box up to the V1 would be much more of a challenge as that A pillar has an airbag. Also would hate for you to ruin that alcantara!
2015 ///X5M
2014 ///M6 (traded) 2014 ///M5 (traded) 2011 550i (traded) |
04-24-2014, 04:40 PM | #11 |
Rep 641
54 or 48. 54 (bigger fuse) turns off in about 10 minutes, 48 (small size fuse) goes off immediately. Have 1 hooked up to my bel stir+ and the other to LI.
Just use 2 - 5 amp fuses, cause those taps are not suppose to go any higher. 54 is a 20, 48 is a 5 |
04-24-2014, 05:59 PM | #12 |
Rep 451
I hooked up a dash cam and V1 to the rearview mirror. You don't have to pull any panels. Super easy:
http://www.bimmerfest.com/forums/sho...d.php?t=546557 Just the little connector behind the mirror. |
04-24-2014, 06:06 PM | #13 | |
Rep 174
Now I need to swap out those front and rear reflectors with IND's painted ones... |
04-24-2014, 07:46 PM | #14 | |
Rep 93
04-24-2014, 07:48 PM | #15 | ||
Rep 93
04-24-2014, 08:33 PM | #16 |
Rep 174
04-24-2014, 08:34 PM | #17 |
Rep 93
Yeah you did it right, you just need to have both fuse sockets filled because otherwise one of the two circuits won't work. If both sockets have fuses in them should work
04-24-2014, 08:38 PM | #18 |
Rep 174
