08-28-2014, 08:43 PM | #1 |
Rep 61
535 -> M5 Winter setup
Currently have a 535 x-drive and need a winter wheel/tire set for this year. When my lease is up I plan to replace with an M5. It will likely be a MY2016 or 2017. Ideally, I'd like to purchase a winter set that I can keep for the M. I realize a redesign is coming for either 2016 or 2017. Any suggestions for wheel styles that might work for my scenario?
If I have to ditch this set it's not the end of the world.. Just thought I'd ask you guys for opinions before I do anything. Thanks for any help. Last edited by Eric; 08-28-2014 at 08:53 PM.. |
08-28-2014, 08:59 PM | #2 |
Rep 4,721
If you have or bought a set of wheels for the use on 535 and going to use them in the future M5, the offset is different + they will not fit due to brake caliper clearance issue.
08-29-2014, 05:18 PM | #4 | |
6'0 / 250lb
136
Rep 1,797
These were made for you. I bought a set from this seller a few months ago. GREAT to work with. Honest and fair.
08-29-2014, 06:01 PM | #5 |
Rep 4,721
^ I have this myself but with Michelin PA4. Do note if you are buying this 345M, they have different width (front 19 * 9 & back 19 *10). Therefore, if you intend to run a square setup, you will have to remember which wheels are for the front and which ones for the back.
