05-11-2014, 04:30 PM | #1 |
Rep 672
Drives: M2 Comp
Garage List 73 911 RSR [0.00]
04 996 Cup [0.00] 06 997 Cup [0.00] 12 Boxster Spyder ( ... [0.00] 15 Sierra HD Denali [0.00] 16 GT3RS [0.00] 17 Radical SR3 [0.00] 18 Model X [0.00] 18 GT350R [0.00] 19 M2 Comp [0.00] |
KW Height Adjustable Spring kit review
I have a 2013 F10 M5, which has been running 100% stock suspension since purchase in late 2012.
I've wanted to drop the car for aesthetics but was unwilling to do so with H&R springs (the only choice on the market at the time), as I personally feel that performance is lost using that setup. The rebound of the H&R springs is very bouncy IMO. Finally KW has come to market with their own spring kit. This package has the added benefit of completely height adjustable springs, so you can dial in the cosmetic drop to your preference. The adjustable system ranges in drop from 0.2"-1.2" in the front, and 0.2"-1.0" in the rear. I used macht schnell spacers of 10mm on all four corners with stock 20" 343M wheels. Lastly, I upgraded the stock sway bars to the BMW Competition Package sway bars (27% stiffer) Results: Cosmetics - As you would expect the results are great. I may lower the front a bit more later. Very nice to have the flexibility to do so. Performance - I'm extremely pleased with the feel of the springs. It's nearly identical to stock in ride quality. I drive in Sport Plus suspension almost all of the time (unless I have passengers), and I'm rather shocked to say that with the KW setup, the ride in sport plus has actually improved a bit. It feels slightly more progressive. In combination with the sway bar upgrade, the car handles significantly better. Turn in is sharper and the car corners flatter. I don't feel any of the bounciness I experienced with the H&R springs. One negative is that the difference between EDC settings (comfort, sport, sport plus) now seems less noticeable. Comfort does feel a bit stiffer. And sport plus feels a bit more progressive. At least this is my perception. Since I never drive in comfort, this is of little concern to me. These springs are more expensive than alternatives from H&R and Eibach (which I've never experienced), but I am super pleased with the results. A no brainer if you ask me Special thanks to Nate and IND for getting the kit out to me last second on a Friday. And to HG Motorsports for an extremely professional, fast and quality install. I'll post more/better pics soon. |
05-11-2014, 05:06 PM | #3 |
Rep 1,837
05-11-2014, 06:38 PM | #4 |
Rep 672
Drives: M2 Comp
Couple more shots - fronts actually look fine here. On a slight decline though
Jairomvp120.00 jairomvp182510.00 |
05-11-2014, 07:59 PM | #6 |
Rep 10,166
Rob well done--- I think the spring rates of the KW are more to your liking than the H&R's. How much are they again?
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
05-11-2014, 08:29 PM | #7 |
Rep 672
Drives: M2 Comp
Thanks Vic. List is ~$1100
05-12-2014, 05:23 PM | #9 |
Rep 1,489
Can't wait to see how these handle in person. But then again, saying that it is better than OEM is almost reason to drop the $ on them now.
BTW, looks great
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
05-12-2014, 07:50 PM | #10 |
Rep 29,202
Great looking drop, I guess it's more or less at it's lowest setting.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
05-13-2014, 10:23 AM | #12 |
Rep 434
Looks awesome Rob. Thanks for the write up.
Current ///M: '13 F10 M5, Sapphire Black, Eisenmann Race Exhaust, CF Delete, H&R Sport Springs, iND Cosmetics, Escort 9500ix hardwired, 21" Vorsteiner VFF-103 w/Michelin PSS, RKP Front Lip, Challenge Rear Diffuser, M Illuminated Door Projectors, and LCI M Performance Black Grills
'15 i3 BEV |
05-15-2014, 12:57 AM | #14 | |
Rep 672
Drives: M2 Comp
05-15-2014, 09:05 AM | #15 | |
Perennial PFC
336
Rep 1,275
05-16-2014, 10:16 PM | #16 |
Rep 672
Drives: M2 Comp
Since I modded both the sways and springs at the same time, it's difficult to say. I have driven the car very hard and was impressed with cornering. A significant improvement.
HG did an alignment and camber actually remained very close to stock. I will post the alignment details when I can (on mobile right now). Another negative I've now detected is that with the tighter suspension, the slop/play in the non-LCI steering is more noticeable. I find myself wanting to drive in sport steering now (prefer comfort), but it really doesn't help much. Has anyone retrofit any CP or LCI components to improve steering feel? Especially on center? I drove a LCI M5 and it was in fact improved. |
05-17-2014, 04:57 AM | #17 | |
Perennial PFC
336
Rep 1,275
It seems like the KW HAS will be fine for my uses and I'll go ahead and get it now. My car wants a slight drop for looks anyway, and if it handles as well or better than it does now, all to the good. Thanks for the report. |
05-23-2014, 07:37 AM | #18 |
Curve Thrasher
623
Rep 3,773
Congrats and your car looks good with that stance. Sounds like a good product. I've been using hr on mine for a long time now. Your ride height looks just right. Well if you went from stock to hr to kw your review is greatly valued and helps us all. Thanks.
08-19-2014, 09:50 PM | #20 |
Rep 273
Nice write up Rob. Car looks much better w/ that setup. What did HG charge you for the install?
I just ordered the KW V3 kit and front & rear CP sway bars. |
