      07-30-2014, 07:01 PM   #1
ShePearl
ShePearl's Avatar
South Korea
138
Drives: F82 M4 & F10 M5
How do you guys turn off your M5 ?
When your M5 is parked, how do you turn it off ?
I always put in "N" and applied parking brake before turning off ignition.
My friend tells me that I'm supposed to leave it in "D" or "R" with parking brake applied before turning it off. (DCT)
Which is correct way for M5 ?
      07-30-2014, 07:19 PM   #2
Spinny02
Spinny02's Avatar
Leave it in gear with foot on the break and hit the stop once to turn off the motor and the car automatically puts the car in park. Hit stop one more time to turn off all electronics.
      07-30-2014, 07:19 PM   #3
soooma
///MD
soooma's Avatar
Drives: M5 F90
We don't -
Well 2 stop/start button pushes with B&O speaker down and just get out of the car and it does take care of the rest for you and it really does.
My radar detector always remains on for avoid a few minutes then switches off on its own too.
      07-30-2014, 08:02 PM   #4
Fantasm
Algeria
39
Drives: SL63
I put it in Neutral, jump out, and it activates the auto-stop feature when it hits the wall.
BEFORE: 24+ Other Awesome Cars - BYE - My Straight Piped Ferrari 458 (plus other mods): http://goo.gl/2qf5fW
M5Noob73.50
M5Rick59630.00
      07-30-2014, 08:03 PM   #5
Fantasm
Algeria
39
Drives: SL63
You will find that when you put it into Neutral, and try to turn it off, the car will scream at you about not being happy.
Leave the car in D or R as you come to a stop and turn it off.
      07-30-2014, 08:26 PM   #6
mstmng
Drives: M5 F10
if you leave it in N, u need to press button twice
OP:
i leave it in D or R, apply Parking Break and then turn ignition off. this way Parking break holds the car, not your gearbox, which is not good in long term if you park on non-flat surface
dont worry about electronics, once you lock the car, everything shuts down
      07-30-2014, 08:27 PM   #7
gblansten
gblansten's Avatar
1967
Drives: 23 Tesla S Plaid
Sounds like you put you're foot on the break.. I hope I didn't loose anyone.
      07-30-2014, 08:35 PM   #8
ShePearl
ShePearl's Avatar
South Korea
138
OP:
Thank you!
      07-30-2014, 08:38 PM   #9
gblansten
gblansten's Avatar
1967
Thank you!
I agree with using the parking brake. It would be cool if turning the car off automatically deployed the brake.
      07-30-2014, 08:52 PM   #10
boots
Curve Thrasher
boots's Avatar
623
I always put mine in neutral and then parking brake. Button twice. Everyone has there way I guess.
      07-31-2014, 03:25 AM   #11
JOHNBMWM5
JOHNBMWM5's Avatar
I press stop/start and get out,unless on a hill, then apply the brakes then switch off. nothing else.
It puts it's self into "P" and thats it.
      07-31-2014, 09:04 AM   #12
johntomferg
Mine gets really "turned off" if a Prius parks next to it.
      07-31-2014, 11:48 AM   #13
savela
savela's Avatar
Drives: 2015 X5M
Gear, parking brake, start/stop once. Mine is coded to shut down electronics when I open door.
Occasionally when I attempt to lock, it honks twice - I think this is when I leave it in neutral and shut off. Also acts differently when I have an active bluetooth call - wish it would automatically transfer back to the phone when I turn my car off.
2015 ///X5M
2014 ///M6 (traded)
2014 ///M5 (traded)
2011 550i (traded)
      07-31-2014, 03:24 PM   #14
Knight Commander
OP:
Same here. This is the correct way.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
      07-31-2014, 09:26 PM   #15
soooma
///MD
soooma's Avatar
Drives: M5 F90
Just tried leaving it on D and pushing the Stop/Start button once and B&O goes down which usually requires 2 pushes on N and I believe this is better..
Only if no long term consequences !
LSM348.00
      07-31-2014, 09:42 PM   #16
ShePearl
ShePearl's Avatar
South Korea
138
I've found an interesting thing.
When I...
1. put M5 in "N"
2. apply parking break
3. press start/stop button to turn off the engine,
"Auxiliary Ventilation" is always greyed out.
However, when I...
1. put M5 in "D" or "R"
"Auxiliary Ventilation" is no longer greyed out. It's available to be enabled.
And M5 no longer beeps (warning message) about car can move away with "N" engaged.
      07-31-2014, 09:43 PM   #17
MBrown1003
Eight Bimmers and counting
Drives: 2014 F10 M5
OP:
The problem with that is what if I'm parked in my garage? I don't lock the car there.
2014 F10 M5
Previously...
Threes: '08 E90 M3, '07 E92 335i,
Fives: '11 F10 550i, '02 E39 M5, '00 E39 540i/6, '97 E39 528i, '92 E34 525i
Others: VW, MBz, Peugeot, Toyota, Olds
      07-31-2014, 09:49 PM   #18
mstmng
Drives: M5 F10
OP:
Too bad for you then
      07-31-2014, 09:59 PM   #19
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
^^ This is funny
      07-31-2014, 11:35 PM   #20
Fantasm
Algeria
39
Drives: SL63
#1. it will turn off on its own anyways after a few minutes.
#2. push the button a second time and everything immediately turns off.
This is kinda standard for all newer BMW's... my 2011 550i, 2013 M5, 2014 M5, and 2014 X1 all operate the same.
      08-01-2014, 05:01 AM   #21
MBrown1003
Drives: 2014 F10 M5
That's how my 2011 550i is, too, but I always set the parking brake and leave the (manual) transmission in first gear. My M5 will be my first car ever without a clutch pedal, and the whole idea of "Park" is new to me.
2014 F10 M5
Previously...
      08-01-2014, 05:28 AM   #22
AttyGunther
AttyGunther's Avatar
15
Drives: 14 M5~11 Z435is~14 K1600GTL-E
If you press and hold the start/stop button, all the electronics shut down. No need to press twice, just hold it momentarily if that is what you intend to do.
