      07-10-2016, 05:30 PM   #45
Eddybro
Eddybro's Avatar
553
Drives: Melbourne e90 and SG e92
Originally Posted by HXS
I've had H&R and now am on Eibachs. H&R is bouncy and gives that raked look. Eibachs are really comfy and give a balanced stance. I prefer it a bit lower though. So if I had to do it all over again, I'd pick KW HAS.
Do you still have the ability to adjust he dampening electronically when you put on the eibach Springs? What's the difference between Eibach springs and the kw HAS KIT
Previous - '11 E90 M3 6MT Stripper Full Cloth
Current- GT3RS,MR e90 and SG E92 Comp
      07-10-2016, 05:31 PM   #46
Eddybro
Eddybro's Avatar
553
Do you still have the ability to use EDC after installing the springs? What's the difference between just eibach springs vs the KW HAS kit ? Any feedback ?
      07-12-2016, 05:15 AM   #47
mjc90
Indonesia
Drives: '14 M5, '14 528i
Originally Posted by 6spdterror
Like the title says....does anyone have any real world experience with the 2? Most of the guys here have H&R but i havent heard of anyone with Eibachs. Trying to decide what springs to go with without spending an arm and a leg!
I'm running eibach with spacers too. My wheels are 19" and they are better than h&r... [IMG][/IMG]
      07-18-2016, 09:04 AM   #48
cjrdriven
Drives: 2014 BMW M5
Couple questions. Have 315s r888s on 343 rear, curious if they will fit with 10mm spacer. Heard from others they fit fine without. Just curious. Also, has anyone tried M6 343 rears with no spacer?
      07-18-2016, 10:27 AM   #49
HXS
Licensed Drug Dealer
HXS's Avatar
Yes you can still use EDC with either Eibach springs or HAS kit.
The differences between the two are price and the ability to adjust height.
      07-18-2016, 03:15 PM   #50
Eddybro
Eddybro's Avatar
553
Grazi!
      12-04-2016, 01:50 PM   #51
Lowflight
Lowflight's Avatar
Drives: 2012 E93 M3
Question
I had a ton of squeak with my Eibach on my CTSV. Are there any common spring issues with the M5? Does it void CPO warranty?
      12-04-2016, 08:11 PM   #52
josec70
josec70's Avatar
I was on H&R's originally and never had any issues whatsoever; ride quality was fine and the car looked significantly better. Recently went to 21" wheels and went with KW HAS as I wanted to be able to adjust the ride height. The KW HAS work very well in all respects and are nice compromise between Springs and Coils; all depends on what you're going for in regards to ride height.
      12-13-2016, 10:48 AM   #53
Lowflight
Lowflight's Avatar
Drives: 2012 E93 M3
Originally Posted by Lowflight View Post
Question
      07-16-2017, 08:40 AM   #54
Lowflight
Lowflight's Avatar
Drives: 2012 E93 M3
Question
      07-16-2017, 02:35 PM   #55
Goranot
Drives: Bmw m5
Any particular reason why AC Snitzer weren't considered ?
As am contemplating lowering my car but not sure which springs to use
Preferred option on forums seems to be the ACS
      07-17-2017, 11:22 AM   #56
josec70
josec70's Avatar
KW HAS is the best option outside of coils; better than the fixed height options (H&R, Eibach, ACS).
lanab39.00
      08-15-2017, 12:55 AM   #57
YanoM5
Drives: 2018 Individual Nardo M5
What is a reasonable amount to pay for springs to be installed?
      01-26-2018, 06:23 PM   #58
ST3M4
ST3M4's Avatar
Drives: '20 M5 Comp & '20 X5 M50d
Bumping this. I have a 2016 Singapore Grey M5 with the matt black 20” upgraded rims. We have just had a baby so my wife drives the M5 now and I bought a 2016 M4 coupe. Ive just fitted the Eibach Pro Kit to the M4 and whilst it’s reduced the front gap issue the back of the car needs to be 10mm lower. I had 15mm spacers on the rear and 12mm in the front, but it’s just not a drop I look back at and am 100% pleased with. The wife will go back to work soon and I’ll be back in the M5 and I fancy a few mods. Can we please reopen this thread and battle out whether H&R works and looks good and if the F10 Eibach kit actually lowers the car unlike my M4? Thanks!
      01-26-2018, 11:42 PM   #59
josec70
josec70's Avatar
KW HAS or coils much better than H&R or Eibach IMO.
      01-27-2018, 01:28 AM   #60
M5 TT
Scotland
169
Drives: F90 M5
With Eibach it depends where you live. UK or US they have different part numbers with different lowering heights. Not sure about spring rates I cant find anything about the UK springs. The US springs seem like they will be comfy on normal driving and as you push on they get a good bit stiffer
UK -25mm all round
US-18mm rear - 23mm front (I can't remember the exact numbers but its more or less that) Not quite low enough to be perfect but pretty close. To be perfect you would need front -30mm rear -25mm. Might whip out the grinder when they arrive
I will be buying the US ones as I hate the rear looking lower than the front.
H&R seem like they will be to hard for me but again cant find spring rate number.
540i
GTR-R35, F90 M5, X3MC, RS3, RS7, M5, S7, S3, RS3, RS6, GTR R35, 996 Turbo, M5, RS6 V10, Cayenne Turbo S
      02-18-2018, 11:05 AM   #61
Lowflight
Lowflight's Avatar
Drives: 2012 E93 M3
I have H&R and have zero complaints. All it did was move your settings. Comfort is now Sport and so on....
Ickdeep5718.50
      02-20-2018, 12:57 PM   #62
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
That has to been one of the cleanest setup out there
      03-05-2018, 09:10 PM   #63
Mr_M_Cinco
Drives: 14 550i M sport Pkg
I have a good question would the M5 KW HAS kit fit on a F10 550i RWD or Eibach or H&R springs?
      03-06-2018, 04:33 AM   #64
M5 TT
Scotland
169
Drives: F90 M5
Yeah thats why I have gone for Eibach. I want comfort and performance, so going progressive rate should make the car a bit more comfortable but then stiffening up as you press on. The roads I drove on are very poor, could not cope with the car being any harder in comfort mode.
540i
      03-06-2018, 07:44 AM   #65
Lowflight
Lowflight's Avatar
Drives: 2012 E93 M3
Coming from Multiple Corvettes including a C7Z06 and a 2014 GTR Black Edition, the car still rides like a luxury car. I have always preferred almost zero movement and body roll in any car.
      04-10-2018, 06:09 AM   #66
itachi_d
itachi_d's Avatar
South Africa
208
Drives: F30 330d M-Sport
BEAUTY!!!
Love yourself, Fight for yourself!
Sasuke: F30 330d M Sport
Luffy: F30 328i M Sport
