      05-05-2015, 01:50 PM   #1
falsalem
falsalem's Avatar
Kuwait
14
Drives: 2013 F10 M5 Alpine White
12mm Spacer with 305 width rear tire - question
I've had 12mm spacers (front and back) for a while now and have recently installed 305 width PZeros in the back. The rear tires rub a bit on bumps now. The fronts are stock 265 PSS so no issues there.
What is the largest spacer size I can use now in the rear and avoid rubbing?
Would it be safe to remove the rear spacers and keep the fronts ?
      05-05-2015, 02:27 PM   #2
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
305s are too much for a 10 inch wheel. I'd go back to a 295, PSS even.
Matt
      05-05-2015, 03:12 PM   #3
falsalem
falsalem's Avatar
Kuwait
14
When you say "too much" is it a life-safety issue that I should be concerned with ?
By the way, only reason I bought 305 PZero is because PSS isn't available in my market currently.
      05-05-2015, 04:37 PM   #4
MCarsFan
MCarsFan's Avatar
Drives: 2014 BMW M5 F10 CP
2014 BMW F10 M5  [10.00]
I don't have these issues..I'm unclear..I have no spacers at the rear and I'm running 305s on a 10" rim..
      05-05-2015, 04:42 PM   #5
MCarsFan
MCarsFan's Avatar
No rubbing
Put my car up on a lift to check the space issue...to me there is still 2" space..
      05-06-2015, 06:05 AM   #6
boots
Curve Thrasher
boots's Avatar
623
Still grip real good rob?
      05-06-2015, 06:10 AM   #7
falsalem
falsalem's Avatar
Kuwait
14
Thanks for giving me peace of mind...the 305s definitely grip more and I love MDM mode now...virtually no power cuts in 3rd gear under full throttle in a straight line
      05-06-2015, 10:35 AM   #8
MCarsFan
MCarsFan's Avatar
Excellent.. Back doesnt kick out as much with traction control off..can get the power down a lot more aggressively.
