04-30-2021, 02:39 PM | #1 |
Cole
322
Rep 498
Dinan coilovers
Has anyone installed the Dinan coilover set?
I just ordered it and it seems like a really nice setup. Definitely not the cheapest, but i was looking for the best set up which retained EDC control. |
05-01-2021, 06:58 AM | #2 |
Rep 91
I bought my car a couple of weeks ago, and it has Dinan coilovers.
Obviously I never drove the car with the stock suspension, but I will say that the ride is the perfect combo of comfortable but aggressive. It's a pleasure to drive. It also has the Dinan sway bars and it handles really well. |
05-02-2021, 06:37 PM | #3 |
On the Go!
79
Rep 235
If you got it new, it comes with reccomendated settings for track and road in a leaflet. Most installers suggest sticking to the road settings, at least to start, if you do not plan to track more than once monthly.
Suggest start with their recommended one and dial it based on your preferences and road conditions. Also, its a coilover setup and at all times you can retain the EDC.
05-03-2021, 03:39 PM | #4 |
Rep 396
i have been running it for nearly two weeks and have been impressed so far.
besides the edc retention, the springs are only slightly more stiff than my non-comp suspension and the provided bump stops add another level of care and comfort. i set it to rear spec provided by dinan (~.75") and lowered the front by about an inch. with the dinan sways, it's night and day on the cornering, stability and handling. i plan to lower it a bit more all around, ~.125", and then alignment. happy to answer any questions you have
current: 23 g20 m340ix
05-03-2021, 04:21 PM | #5 |
Rep 396
adding, if you are looking to install it yourself ... or want to subscribe to a killer build thread, check out chad's. he's got great mods going and insight on the diy install.
https://f10.m5post.com/forums/showth...1762200&page=2 i went to my tuner. turned out awesome though; dinan provides great instructions and tech support.
05-03-2021, 05:20 PM | #6 | |
Cole
322
Rep 498
I installed springs on my f10 550i so these should be about the same install procedure. I have watched a couple videos and this kit comes with a ton of small spacers etc. |
05-05-2021, 06:43 PM | #8 |
Rep 396
you can see how low i am here
it's all personal preference, of course, but i don't feel "bounce" on this set-up. i did play with the rear sway settings, going from mid to soft, as i noticed backend stiffness after lowering. as stated, i am going to go a bit lower - and not worried about the ride. this thing is planted, only slightly stiffer and fun to drive with the dinan mods even on (horrible) detroit roads.
05-05-2021, 08:38 PM | #9 | |
Rep 469
05-10-2021, 06:20 AM | #10 |
Rep 606
Glad to see others are happy with the setup. I bought F/R swaybars, this adjustable spring set and monoballs. Hopefully will be installing them within the next month. I'll be sure to take photos and post up.
