      07-24-2016, 09:42 AM   #1
Eddybro
Eddybro's Avatar
553
Drives: Melbourne e90 and SG e92
Just installed my AMS Downpipes
Just installed my AMS downpipes! Took me about 2 1/2 to compete.
The sound is amazing and I freaking love it!
There is some rattle tho and I have been reading about the same issue some other people are having with the AMS downpipes rattle.
Other than that I'm super happy, CEL is on, so I'll be getting JB4 soon to get rid of that!
Previous - '11 E90 M3 6MT Stripper Full Cloth
Current- GT3RS,MR e90 and SG E92 Comp
      07-24-2016, 10:08 AM   #2
TrevorM3
Drives: 6.3 AMG
Tips?? Looking to do this myself
      07-24-2016, 10:31 AM   #3
Eddybro
Eddybro's Avatar
553
Get it done! You won't regret it. It sounds amazing.
If your getting the AMS downpipes you might need to get longer bottom o2 sensor wires. I was able to run the o2 sensor wires under the heat shield and bracket for the DMEs also make sure you get new gaskets (thanks allmotor) for the bottom of the down pipes where it connects to the rest of the exhaust.
The gaskets are supposed to stop the rattle, but I'm guessing it's inevitable. I might contact AMS to see if they have a fix for it.
What brand are you going with ?
      07-24-2016, 10:44 AM   #4
TrevorM3
Drives: 6.3 AMG
No idea. They were in my dads car when he bought it. But im going to swap it out and put it on my incoming m5
      07-24-2016, 10:46 AM   #5
Eddybro
Eddybro's Avatar
553
Nice! Catless?
Yes I think the car should have sounded like this from the factory..
The turbo spool sound is bonkers!
      07-24-2016, 11:27 AM   #6
apexlocator
Drives: 2014 M5
You seem mechanically-inclined. Your 2.5 hours would = 10 hours for me + any MacGyver factors.
      07-24-2016, 11:38 AM   #7
Eddybro
Eddybro's Avatar
553
Lol not really mechanically inclined, just worked on a lot of the cars I owned (40+ cars), I think having the right tools was the key.
Did it at my buddy's shop with him, after hours so I had full access to the tools and lift so it made everything a lot easier.
Also one of his buddies who is a BMW tech, showed up during the end of the process, so he kinda steered us through the end of the process
      07-24-2016, 12:32 PM   #8
TrevorM3
Drives: 6.3 AMG
Everything done from up top?
      07-24-2016, 12:45 PM   #9
Eddybro
Eddybro's Avatar
553
95% of the work is done from top.
You have disconnect the downpipes from exhaust from under the car. Two bolts each pipe if I remember correct.
Getting it lined up from the top, into the exhaust was a little challenging. And you might need to grind down the washer, atleast I did a little to make it fit better. Might be just with the AMS pipes.
      07-24-2016, 01:18 PM   #10
TrevorM3
Drives: 6.3 AMG
ecu's have to be removed completely?
      07-24-2016, 01:19 PM   #11
Eddybro
Eddybro's Avatar
553
Nope, just push them off to the side of you have zip ties, just use them to keep them out of the way.
      07-24-2016, 02:09 PM   #12
TrevorM3
Drives: 6.3 AMG
hmm, may just remove them at once and send ecu's out to get tuned while im in there.
      07-24-2016, 03:52 PM   #13
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Good job man!
      07-24-2016, 04:39 PM   #14
Drives: Black M5
I've got a BMS CAN CEL Delete Tool for sell if you don't want to go through all of the trouble of installing a JB4.
      07-24-2016, 07:04 PM   #15
boots
Curve Thrasher
boots's Avatar
623
This^^^this
      07-24-2016, 08:20 PM   #16
Eddybro
Eddybro's Avatar
553
Tell me more..
      07-24-2016, 11:53 PM   #17
M5 addict
Thailand
69
Drives: m5
Did you feel any power loss?
      07-25-2016, 01:53 AM   #18
Nikolov
I'm on the fence of getting downpipes + JB4, what's holding me back is the mentioned rattle and possible drone. I have a Supersprint exhaust and it already has a very mild drone at low RPM. I'm afraid it might get worse after I get downpipes. A guy I know with the same exhaust had Supersprint downpipes installed + JB4 and he said there's rattle from the downpipes when they get hot and noticeable drone at 3k rpm...
Anyone else can share their input on the drone/rattle?
      07-25-2016, 11:01 AM   #19
M5Beast_NYC
Drives: 15 M5
nice. cant wait to get downpipes as well!!
      07-25-2016, 11:20 AM   #20
Eddybro
Eddybro's Avatar
553
Nope, why?
      07-25-2016, 11:21 AM   #21
Eddybro
Eddybro's Avatar
553
Only one way to find out
      07-25-2016, 11:44 AM   #22
apexlocator
Drives: 2014 M5
If you've already got some drone, then catless downpipes will only amplify it.
