      01-23-2015, 08:39 AM   #1
pank11
Drives: 14 M5 Alpine White CP
Has anyone successfully ordered and installed a blendmount
I have sent in pictures to blend mount and it would appear that I would need BMX 2117 for the passport max 2. When I try to install my mirror stem is just to wide. I've installed them plenty of times on my other cars with no problems.
      01-23-2015, 02:11 PM   #2
darkz
darkz's Avatar
2016 BMW X5M  [0.00]
2013 BMW M5  [9.00]
2012 BMW X3  [9.00]
2013 Ford F150 FX4  [10.00]
not sure about passport, but I use V1, so mine is BV1-2017
      01-23-2015, 07:25 PM   #3
pank11
Thanks for the reply! Do you know if the top and bottom of the mount touch when tightened down? It's almost like my stem is larger than 3/4
      01-27-2015, 04:21 PM   #4
darkz
darkz's Avatar
2016 BMW X5M  [0.00]
2013 BMW M5  [9.00]
2012 BMW X3  [9.00]
it fits perfectly on mine, and yes they do get touchy once tightened.
      01-29-2015, 12:36 AM   #5
wontonbomb
wontonbomb's Avatar
121
Drives: TBD
I also have a BV1-2017 for my V1 and the fit is pretty snug - especially up against the rear view mirror housing.
Here's a photo:
      01-29-2015, 02:26 AM   #6
variable229
Drives: M5
Where did you tap your wire into? It looks like you used the blendmount tap kit.
      01-29-2015, 05:19 PM   #7
darkz
darkz's Avatar
2016 BMW X5M  [0.00]
2013 BMW M5  [9.00]
2012 BMW X3  [9.00]
it can be a tap kit or the hardwire kit from blend mount.
      02-04-2015, 07:59 PM   #8
pank11
Thanks for all the help. I ordered the blend mount again and this time it went on in a few minutes. The last mount had to be mislabeled or something because it barely fit.
