      03-06-2017, 05:38 PM   #1
R3dn3k Flyby
BigMacs
R3dn3k Flyby's Avatar
69
Drives: 2019 BMW M5
2019 BMW M5  [9.67]
Catless Downpipes - Squeak / Chirp noise after full operating temp?
Situation:
Drive M5 to full operating temp.
Park M5 for anywhere between 10 minutes and 90 minutes.
On start-up, rapid chirp / squeak noise can be heard.
Goes away after roughly 15-20 seconds.
It's best heard on the driver side from the front wheel well behind the front tire. If the hood is popped, it's not as noticeable, and sometimes cannot be heard at all.
If you drive the car to full operating temp and come to a stop with the car running still, there is no noise. It's only if it sits for a short time and is then started again.
On cold start, it does not do it. Example, if it sits in the garage from 7pm to 8am, no noise. If it sits at work from 9am to 6pm, no noise.
I initially thought it was some sort of belt / tensioner / pulley noise.
After having the car for 3 days, BMW is blaming the noise on my catless downpipes.
Anyone else encounter this?
Here's a video:
2019 M5 : Black Sapphire Metallic / Black Full Merino / Carbon / B&W / Executive / Driving Assistance Plus / BMW Performance Carbon Fiber Front Splitters, Side Skirts, Rear Diffuser, Trunk Spoiler
2020 RDX A-Spec : Apex Blue Pearl / Red
      03-06-2017, 05:44 PM   #2
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
It's possible that with catless downpipes aren't properly fitted or designed and sitting against metal which is creating that noise since due to the vibration.
Worth having a shop check it out.
      03-06-2017, 06:28 PM   #3
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
I would also say recheck the install. Take off the plastic cover and check the mounts compared to the other side. Maybe there's something missing like a washer or rubber bushing. Did you change the gaskets?
      03-06-2017, 06:35 PM   #4
apexlocator
Drives: 2014 M5
Maybe its your wastegates.
2014 "AW/SO"me M5
Mission Performance/3.5 Bar
RK Autowerks/ CSF ICs
SSP Spec-R
KW V3/ Corsa Axle back
      03-06-2017, 08:17 PM   #5
13M5F10
13M5F10's Avatar
Very true.
      03-06-2017, 10:02 PM   #6
R3dn3k Flyby
BigMacs
69
Drives: 2019 BMW M5
2019 BMW M5  [9.67]
Per BMW, they traced the noise to the downpipes. My SA wasn't sure if it was up top or underneath. I replaced the gaskets when everything was installed. Wastegates have a mild rattle on deceleration as I'm nearing a stop. No chirp / squeak. We're gonna get it on a lift and see if we can find something that came lose. Exhaust has been on the car for months. Just recently started doing this.
Mainly curious if anyone else has had the same sound or similar and what the solution was.
-James
      03-07-2017, 03:28 PM   #7
2016-M5
Drives: M5-2016 Grey
i had something very very similar from new, but after a few thousand miles it just went on its own, BMW only scrathched their heads, one guy said it may be the fuel rail
      03-07-2017, 09:23 PM   #8
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Yes! I just started having this issue after running my car pretty hard over the weekend. I originally thought it was belts making noise, Bmw said it was DP's. going to have the gaskets checked out.
      03-07-2017, 10:26 PM   #9
combatbmw
Drives: 20' X3M CP
Non catted DP's rattle thats normal, annoying as hell though.
Especially if you have a aftermarket exhaust even more noticeable.. putting it in sports mode helps at idle but not on decel.
Good luck
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 |
      03-08-2017, 08:16 AM   #10
R3dn3k Flyby
BigMacs
69
Drives: 2019 BMW M5
2019 BMW M5  [9.67]
I always drive my car hard, but I think this noise started happening after we did a bunch of dyno pulls for the next Armytrix video. I'll report back once we check the downpipes.
-James
      03-08-2017, 10:33 AM   #11
TrevorM3
Drives: 6.3 AMG
Why were u running your car hard?
      03-08-2017, 05:07 PM   #12
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Haha
Your car was running pretty good on Sunday.
      03-08-2017, 10:35 PM   #13
R3dn3k Flyby
BigMacs
69
Drives: 2019 BMW M5
2019 BMW M5  [9.67]
^Video from tonight. We checked downpipes. Unless it's somehow being made by the gasket, it's not the downpipes. In this video, you hear the sound change as I turn the steering back and forth slowly.
Any further ideas?
-James
      03-15-2017, 02:43 PM   #14
CSL335i
Hungary
207
Drives: M2 and...
I had a similar, but not exactly the same strange noise coming from the same location that you mentioned. Sounded like my turbos were off. I used Fabsped HJS 200 cell catted downpipe. The fitment and installation was good. The strange sound came up after a few months from the installation.
I put back the factory downpipe and the sound went away. In my case i think two reason: one is for the CAT itself, maybe it is damaged or was not produced properly or the other reason is resonating/fitment.
I suggest you to put back your OEM downpipe (with new gaskets of course) to make a reverse test.
      03-21-2017, 08:21 AM   #15
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
If noise changes when you turn steering wheel then it might be power steering pump? Check fluid first. Good luck with finding that noise, it can be frustrating.
      04-18-2017, 12:17 AM   #16
747flyboy
Drives: 2008 M3 2012 550i M
Possible root cause
I drive 550i N63 fitted wih M5 F10 OEM downpipes. Experienced similar harmonics/sound from that general area including opposing side as heat builds up. I learned to live with the sound since there were no malfunction indications or loss of performance until I decided to upgrade to ALPINA OEM Turbos. Found the Ceramic 200CPI cells were either damaged or coming apart in chunks after separating turbos from downpipes. Apparently, during cold operation or initial start there is minute metal expansion alleviating metal contact and or vibrations. No need panic since there is no reverse flow into turbo turbine section making ceramics/metal chunks blown out through exhaust piping as a worst case scenario.
      04-18-2017, 05:41 AM   #17
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Mine went away and can't replicate it anymore. I noticed it when it was cooler outside but car was warm. Weird but everything is running fine now
      04-18-2017, 06:29 AM   #18
NightM
NightM's Avatar
450
Drives: Bmw
Sounds like either something rubbing from vibration or check your turbo wheels/propellers
Take intakes out
Inlets out
Start the car u should see propellers spinning if it's wobbling and maybe hitting the side then its that.
      05-14-2017, 12:47 AM   #19
Earthmaster
Drives: 15' M4 Austin Yellow
Omg this is my exact same problem dude.... did you figure out what he problem is?
      08-12-2018, 03:14 PM   #20
k_barakeh
k_barakeh's Avatar
21
Drives: 2015 BMW M5
Did anyone ever figure anything out? I am also having the same noise after installing my Akrapovic M performance exhaust. I put new gaskets as well and hear a loud chirping noise on cold start that honestly sounds like a belt/ pulley noise. Goes away after warm up. My BMW technician went to loosen the bolts and re fit everything and the noise went away but came back again after a week. Does anyone suggest to remove the metal spacers between the downpipes and exhaust flanges?
