12-17-2019, 11:58 AM | #1 |
Rep 540
suspension upgrades
now that I've put the M5 into hibernation after my first glorious "year" with the car, my thoughts turn to what I might look to do to it when I get it back out. what I'd like to focus on is making it more responsive, or otherwise feel "lighter on its feet", and improve feedback. Here's what I'm looking at, in order of how I'd want to do them:
KW V3 coilovers Dinan swaybars monoball thrust arm bearings (either dinan or turner, not sure if it matters?) Does this sound about right? Am I missing anything that might be a higher priority? Are the monoballs worth it? |
12-18-2019, 08:43 AM | #2 | |
Hide! My wife's coming!
813
Rep 2,816
Depending on your mileage, you may be just as satisfied with KW HAS over coil overs. I'd only go coil overs if you plan to track the car or if the existing suspension is about to go out soon. I suggested the control arms because once lowered, you'll max out the camber on the stock setup possibly and have uneven wear and tear on the tires. I learned the hard way. You could find a lot of info on them from others who experienced it. If i could do it all over again, sway bars first.
12-20-2019, 01:38 PM | #3 | |
Rep 540
12-20-2019, 01:49 PM | #4 | ||
813
Rep 2,816
Doesn't hurt to get the alignment checked after. Typically do not need it but never hurts.
12-22-2019, 11:31 PM | #5 |
Rep 385
Get the KW V3's. Dinan sways are optional. I planned to get them also, but never have after dialing in the V3s. The KW V3s are probably how the car should have been delivered instead of the adjustable suspension that does nothing well. KW V3's are about $3K as I recall. You get a lot for your money. Dinan sways are just a pair of sway bars, and it costs you $1000.
12-23-2019, 01:23 PM | #6 |
Rep 184
Street use and track days, competition front sway bar and KW HAS is plenty.
Competitive Track use, dinan sways and the KW V3's. Thurst arms with either setup if you are going low as stated. If youre going it in parts, start with sway bars. I did my comp front bar and it was more than good enough for hard street use. No point spending $4-5k when $1500 will do all you need. |
12-30-2019, 11:27 AM | #8 | |
Rep 540
Thanks for all the replies. |
12-31-2019, 08:41 AM | #9 |
Rep 503
I have the kw V3's and imo that with my BBS wheel setup was the best thing I did for the car. It feels much more nimble while remaining firm and planted, never harsh.
2016 M5 | Instagram: @black_f10m5
IND cosmetic | M Performance , RKP , 3D Design aero | Eisenmann Race exhaust | AMS catted downpipes | MSR intake | CSF charge coolers | DME Stage 2 tune | KW v3 coilovers | BBS FI | Michelin Pilot Sport 4S |
12-31-2019, 08:47 AM | #10 |
Rep 540
Thanks! Last spring KW had a mail-in rebate thing going. Perhaps they will this year as well. What is typical for install cost?
01-03-2020, 04:19 PM | #11 |
Rep 385
Too much attention to tuning and power adding on these boards. Out of the box the most glaring problem with the f10 M5 cp is that it doesn't handle and ride like an m car should. My e60 545i sport package was better.
I paid about $2300 for installation, corner balancing, aggressive street alignment but labor for front tire mounting and balancing is probably included in that. It was a reputable Bay Area bmw tuner/race shop and they did excellent work although they didn't read the instructions that say the shocks are preset at the basic settings and gave it to me on the softest settings which floated like crazy over bumps at speed and yet still low speed cornered better than stock. I set it back to the recommended start settings at home and have only gone one click up from there . |
01-13-2020, 07:09 AM | #12 | |
Rep 540
$2300 is more than I was expecting, but I guess I really didn't have a good feel for the cost. Perhaps SE Michigan will be a bit cheaper than SF. Last edited by vafan13; 01-13-2020 at 07:18 AM.. |
