      05-09-2018, 02:39 PM   #1
WickedBMW
WickedBMW's Avatar
Drives: 2021 BMW M3 MT
Erratic Idle
Im not sure if there’s another tread on this issue, but if anyone can advise on this it would be greatly appreciated. This just started recently during a cold start where idle would stutter and then jump to higher RPMs than norm. Could it be dirty MAFs that’s causing this issue? Thanks
      05-09-2018, 03:08 PM   #2
New2MPerformance
Drives: F10 '15
Maybe not at all relevant but I experienced the same once at a cold start and then after 15 mins of driving the car suggested an engine oil top at my earliest. So did so and then it was fine....and been fine ever since....
      05-09-2018, 03:24 PM   #3
New2MPerformance
Drives: F10 '15
Oil top up....
      05-09-2018, 08:59 PM   #4
MpowerMike
MpowerMike's Avatar
361
Drives: 2012 IB BMW M5
Check the mafs I cleaned mine and put back oem air boxes and it went away
      05-09-2018, 09:38 PM   #5
WickedBMW
WickedBMW's Avatar
Originally Posted by New2MPerformance View Post
Oil top up....
Check oil readings, and it reads max
      05-09-2018, 09:39 PM   #6
WickedBMW
WickedBMW's Avatar
Which CAI were you using?
      01-29-2019, 12:53 PM   #7
induc916
Drives: 2014 M6
Bringing this thread back to life, i'm having this issue now after installing project gamma intakes
      01-29-2019, 02:02 PM   #8
WickedBMW
WickedBMW's Avatar
ECU maybe able to adopt to new air system. How long did you have them on?
      01-29-2019, 02:37 PM   #9
induc916
Drives: 2014 M6
it does adapt after driving but on startup it doesn't either way i'm hoping when it goes off to DME for custom dyno tune they'll get it sorted out there on the dyno.
      01-29-2019, 11:18 PM   #10
WickedBMW
WickedBMW's Avatar
If it’s during idling it could be your timing chain. My car had this issue, but once it was replaced by BMW it was all good.
      01-30-2019, 11:21 AM   #11
Reemas Dreemas
Drives: NICE
its not always the mafs... remember that the our injectors are bad on these cars. i say look at the injectors
      01-31-2019, 07:05 PM   #12
Yay-Z
Shifting to Top Gear
Yay-Z's Avatar
Drives: F10 M5/E70 X5
They changed out my MAF and swapped my battery. It went away. I think it was the MAF sensor
2015 F10 M5 CP
2013 E70 X5
