      02-07-2019, 12:55 PM   #1
michael4702
F10 M5 JB4 Map 1 clutch slip in 4th
Hi all,
Just got the JB4 running well, colder plugs...
I put the JB4 in map 1 and went for some 4th gear pulls...
Clutch slip at the top end of 4th... 4-4.5K rpm.
I am in the UK and running 99 octane fuel, outside temp today 7C.
Is there anyway to limit the torque? The wife wont allow a clutch upgrade at this time :-)
Many thanks
      02-07-2019, 12:59 PM   #2
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
Say your wife that clutch is gone and have to upgrade. When it slip once. This is the end for that clutch. 👎🏻
      02-07-2019, 01:18 PM   #3
michael4702
Hi,
When I reverted back to stock (turned off the JB4) the clutch did not slip :-)
      02-09-2019, 02:27 AM   #4
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
Originally Posted by michael4702 View Post
Hi,
yes because less power, adding power again = clutch slip
      02-09-2019, 02:55 AM   #5
PattyF10M5
Drives: MCB F10 M5
Time for a new clutch. If you want to keep running higher power and torque you will need after market ssp clutch.
      02-11-2019, 06:12 AM   #6
Chauncey.Bishop
Big girls don't cry.
Chauncey.Bishop's Avatar
India
125
Drives: E46 M3
I personally skipped map 1 and went straight to map 2 on my JB4 but if your clutch is already slipping then I recommend you check out the latest BootMod3 tune designed to limit the torque until higher in the powerband.
