08-07-2015, 09:07 AM | #1 |
Rep 61
Sport Display Max HP
I've had my '15 M5 for about 2 months. Playing with the sport display my max HP is 540. I've seen others state that there's show way over the stated 560hp. I realize it's a little gimmicky and probably not very accurate but why is mine so much lower then others. I turned everything to sport plus , mdm on and hammered 1st,2nd,and 3rd.
08-07-2015, 12:32 PM | #2 | |
Rep 1,231
What does it measure
08-07-2015, 03:59 PM | #3 |
Rep 354
depends on what gear too!
2015 BMW M///5 Comp. Package I Black Sapphire Metalic I Full Black Leather I Gruppe M Intakes I 3D Design Side Skirts I HRE FF01 I RKP Lip I IND Cosmetic Pkg I JB4 BETA I BMS Meth SS I MSR CP I Challenge SS Brake Lines I Challenge Diffuser I Undercover DP's I Dodson Clutch Packs I VRS GTS Tips I M Perf. Carbon Mirrors, Spoiler and Full Interior +++ 698 WHP & 653 WTRQ (Corrected) |
08-07-2015, 08:10 PM | #4 |
Rep 61
08-08-2015, 10:12 AM | #5 | |
Rep 1,231
If you think about it....
All the look up table does is provide the HP rating by RPM and a temperature correction factor and the job's a good 'un (as they say in these parts). There's no easy way to measure actual HP and Torque. Could be as simple as the fact you measured it in Florida on a hot day and the others were in Canada, freezing their patooties. |
08-09-2015, 03:40 AM | #6 | |
Rep 5,110
My understanding is that it works roughly the same as a aftermarket OBD reader that calculates hp and torque based on some of these values: -RPM -Air Temp -Mass Air Flow -Fuel Flow -BSFC (this value is a "unknown" on a aftermarket OBD tool, but BMW engineers know this value at every rpm and load on the engine) -Throttle position -Ignition timing -Boost Level If you have these values you can calculate the engines HP and Torque very accurately. You can also do a very rough estimate just based on the engines mass air flow sensor. If the mass air flow to the engine is 200g/s that roughly equals 200kW (272hp) |
08-09-2015, 02:41 PM | #7 | |
Rep 1,231
MMMMmmm
08-09-2015, 03:05 PM | #8 | |
Rep 5,110
Would like to see a picture of the display readings to verify that it indeed says 540hp Assuming it does, it could actually be a sensor that reads low. Say the MAF sensor is slightly off, that would cause a wrong result when calculating HP. Worse, it would also affect the DME's calculations for fuel and timing etc. Affecting engine HP. The theory about warm or cold weather should not influence the HP since these engines have the capability to adjust boost to accomodate for different climatic conditions and altitudes. |
08-09-2015, 03:33 PM | #9 | |
Rep 61
Can other people with 15s post their numbers. One reason I'm wondering is I had a '13 c63 amg coupe with a rentech tune and the M5 doesn't feel as fast even though it should be every bit if not more. Maybe the wonderful noise the amg made made it feel faster then it was. When I look down at speedo on m5 I'm impressed but not as much seat of the pants. |
08-10-2015, 02:50 PM | #11 | |
Rep 806
08-12-2015, 09:37 PM | #12 |
Rep 798
OP - good question. I have not looked closely but I think my car (with CP) has shown a Mac of about 540 as well. I have never managed to get close to 575 that it should have.
For reference, it's a 2015 with CP. curious!
2015 M5 Individual Moonstone Metallic / Special order Caramel/Black / Special order Walnut Honey Trim/ Comp Package / ED / Left the Stable :-(
2018 Volvo XC90 T6 POLESTAR 2018 AMG GT 2017 Fiat 500C Abarth |
08-13-2015, 03:11 PM | #13 |
Rep 422
I have an F13 M6 CP with 575HP. I also have Awron display, which displays the same HP and NM as the Sport display on Navi.
The car has factory software and has the following modifications: - factory turbos with some machining to provider better exhaust flow - ceramic coated turbine side of turbos - ceramic coated exhaust manifolds - ceramic coated OEM downpipe - Okada coils Before modifications i had 575HP/685-690NM, after modifications the max values i had: 717NM and 589HP (whatever does it mean). |
