      07-15-2014, 12:07 AM   #1
MpowerMike
MpowerMike's Avatar
360
Drives: 2012 IB BMW M5
Question Ordered BMS Stage 1 Tune
Hey guys so I finally made up my mind and thought I should try the BMS piggyback until a true tune flash comes out. What should I expect from this BMS tune? I heard it's easy to install and uninstall if you go in for service. Also I heard you can adjust the psi for the turbos? 3.5 is what I think I'm going to run. Any other info I should know about this tune? By the way I'm running catless downpipes so this should too it off for now power wise
      07-15-2014, 07:38 AM   #2
Andym3100k
Singapore
110
Drives: 2014 M6 GC FULL HAMMAN WIDE BO
U can easily run 5psi on 93 with proper adaption.
      07-15-2014, 07:48 AM   #3
M5Rlz
Drives: R8, f10m59(Rip), m4, GTR
I'd do the 3.5/4 to start see how the car likes it...
      07-15-2014, 08:18 AM   #4
Timberwolf
Timberwolf's Avatar
196
Drives: People crazy
Personally I wouldn't run anything over 3.5 unless you mix in MS109 in. That's just being wise.
991 Turbo
993 GT2 Outlaw
      07-15-2014, 12:06 PM   #5
gmd2003
gmd2003's Avatar
352
+ 10000
At some point you stop making power and just make heat with added boost via piggyback . Look at my trap speed with 93 octane on + 3.5 psi ( 130mph ) . I've tested and that's optimal for consistency on a CP with catted DP's , above that and too much timing is pulled up top and I actually lose speed . The increase in tq down low still happens but up top you will make less power . The only way to correct that is to run race gas or meth . More isn't always better .
G
      07-15-2014, 06:56 PM   #6
EuroKar
Agree as above.
Run 3.5 and you'll be more then happy !
      07-15-2014, 10:04 PM   #7
Andym3100k
Singapore
110
On VP109, I'm running 7.5psi with no problem at all.
2 months ago, a lot of them said best is at 2.75psi so now till some of them tried higher to 3.5psi then the story line change again!
Guys, this is only a matter of whether do u dare to do it & NOT OUR ENGINE CAN'T MAKE IT.
m6beast did 6psi about 1mth plus back & I tried 7.5psi on vp109 without any problem. By all means u can do whatever u like cos is yr own car. Good luck.
Just FYI, I won my friend by about 5cars length for the different of 3psi n 7.5psi on 20 lamp pole.
      07-16-2014, 11:08 AM   #8
gmd2003
gmd2003's Avatar
352
Just because you're engine didn't blow up doesn't mean it's faster . Show me with objective performance numbers that 7.5 psi is faster than 6 , or even 5 on 109 octane . I've tested after adaptation and my car wasn't faster at 4 psi vs 3.5 psi on 93 octane , that is fact . You are not data logging AFRs , EGT's , timing , etc. so how do you know it is "fine ". You don't know and eventually will have an epic failure . You're choice but don't encourage others to follow in you're footsteps .
      07-16-2014, 11:30 AM   #9
EuroKar
What is your current setup running 7.5 ?
Meth ? Exhaust ? Intakes ? etc..
      07-16-2014, 12:03 PM   #10
biswa002
Drives: 2013 M5 Imperial Blue
How do you order BMS tune?
      07-16-2014, 12:33 PM   #11
EuroKar
Online.
He lives outside of California.
We are the only ones restricted from buying their tunes.
Thanks to the CA government
      07-16-2014, 05:49 PM   #12
Andym3100k
Singapore
110
See for yourself, I have post vid thru YouTube. Just search for BMS M6 7.5PSI VS BMS m6 3psi u will understand. Talking is always not effective as real race on the road.
      07-16-2014, 08:21 PM   #13
MpowerMike
MpowerMike's Avatar
360
How do you guys adjust the psi??? I got the bms box today and there is no instructions and no USB cables.
      07-16-2014, 09:16 PM   #14
Spinny02
Spinny02's Avatar
Need to buy the USB cable
      07-16-2014, 09:20 PM   #15
gmd2003
gmd2003's Avatar
352
Here real data , please get a Vbox and show me how fast you're car is. Of course 7.5 is faster than 3 on race gas , a video against another car isn't proof of anything . I'm telling you , that you will make the same and maybe even more power with less psi . You are not even running meth correct ? You've turned you're turbos into hot air guns. !
      07-16-2014, 09:25 PM   #16
M5TXGuy
M5TXGuy's Avatar
Drives: 2013 M5 BlackSapphireMetallic
Go to N54Tech.com and you will find the detailed installation instructions there.
      07-17-2014, 05:18 AM   #17
M5Rlz
You will need their special cable [good marketing]
PSI will be adjusted in the software on the computer
Things to remember:
-make sure you assign a usb port [match them up so the software reads the exact com port its plugged into]
- You are only setting two variables PSI [labeled BOOST OVER STOCK on the software] which should be standard at 2.2 [maybe higher if you have a newer one I'm not sure]...... and Future use 0-100 which for an m5/m6 should be set at 1
read the first page in that thread make sure you get the right download file for the marker written on your stage 1:
http://www.n54tech.com/forums/showthread.php?t=18035
      07-17-2014, 06:24 AM   #18
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
You'll know how far to push right up until you need a flatbed. Then you can back off a tad.
      07-17-2014, 07:23 AM   #19
Andym3100k
Singapore
110
Haha I'm running 100% METH. Lol... Lol... Lol....
      07-17-2014, 07:27 AM   #20
Andym3100k
Singapore
110
A sleeper will always be a sleeper, till u wake up from yr dreams then start posting again lol.. Lol... Lol...
      07-17-2014, 07:47 AM   #21
akh23456
All I do is Win... Eat Race Sleep
akh23456's Avatar
Drives: 2018 Range 2011 M3 2019 600lt
Didn't someone from BMS say that the most anyone can go is 6 psi no matter what someone puts in the boost setting ?
Rs7 : 10.4 133.50 with a 1.7 60ft Toyo R888
F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires
E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires
      07-17-2014, 08:18 AM   #22
gmd2003
gmd2003's Avatar
352
Ha ha. ! Yeah there is no helping some people .
