08-15-2014, 01:43 PM | #1 |
Rep 1,027
Initial Results with Noelle DPs and Dinan Stage 2
It appears to have all worked better today but I couldn't find a level enough spot that was really long enough. Here are a couple of pretty decent quarters but one was completely uphill.
11.865 @ 122.88 11.892 @ 122.84 Both of them with 2.0s 60 ft times. Both of them mash and go in MDM with sport plus gas. I didn't do any runs where I disabled DSC completely and shifted myself. I will do some of those the next time out. These are better than the day I tested with just Dinan Stage 2 and the open air box. However, they aren't as good as I could have done. I never really did get a good level run and so I know the results will be better on level ground. Horsepower estimates around 650 from the trap speed and weight. |
08-15-2014, 02:18 PM | #2 |
Rep 1,840
Thanks for sharing ! I am sure the heat has something to do with the 122mph. That should improve with the temp.
08-16-2014, 10:22 AM | #4 |
Rep 1,027
Just for grins, a cold start with Noelle pipes and Dinan exhaust now that the mods are all done, except possibly for the wheels which I am now seriously considering as the last touch.
08-16-2014, 11:06 AM | #5 |
Rep 375
Thanks so much for sharing.
Have not seen any head to head as of yet BMS vs Dinan In the recent past just as a quick comparison what type of times are cars with BMS and DPs running? |
08-16-2014, 11:16 AM | #6 |
Rep 1,027
It's very hard to tell what different people are doing because there are enough differences in the cars and mods and driving ability that the real improvements are obscured. There are people here who get sub 2s 60ft times and I cannot do that. If I could, my car would do a lot better. For example, I have a 11.865 best ET with a 2.0s 60ft time. If I could get it down to 1.6s like greentrbo or some of the other featherfoot types, then I would have a much better ET and possibly a little better trap time. My driving skills aren't very great but I do have a fast car that sounds fast.
08-16-2014, 11:30 AM | #7 |
Rep 1,048
The exhaust sounds great! I have a totally stock 2014 M5 and the factory exhaust is a little lacking (too quiet) in my opinion. But I am leasing so it is a tough call.
By the way, watch those hedge clippers to the right of your car. I can't tell how they are secured or how close they are to your car but it might be a close encounter with your paint if they were to fall! Dave |
08-16-2014, 02:36 PM | #8 |
Joint Chiefs of Staff
4914
Rep 115,980
I think -0.4 slope is close enough to what you'd see at a track. Don't these cars run around 122mph stock? I thought with downpipes and a tune you'd be looking at 126-130mph? Maybe it's not turned on?
Mike |
08-16-2014, 03:09 PM | #9 | |
Rep 1,027
The previous results for my car were a best of 120 mph trap with 12.0 ET. The cars vary from driver to driver and with different components. If someone got 122 stock it was with a CP, not a 2013 stock M5. The tune is turned on but it has only been on for about 200 miles now and when I made the runs it only had 100 miles on it. |
08-16-2014, 03:42 PM | #10 |
Rep 6,067
Motor trend guy got 120.3 @ 11.9 second with stock M5. He also got 122.2 @ 11.9 second with M5 CP. Both in good road condition and nice whether of SoCal using Launch Control!
08-16-2014, 03:44 PM | #11 |
Rep 6,067
@wrsbmw Thanks for sharing!
I'm just curious to see the result using Launch Control!
08-16-2014, 06:52 PM | #13 |
Rep 646
If you are going to compare US car mag times, you need to use the GPS based ending trap speed which looks like 123.7mph since the car mags don't average the last 66' of the run like the drag strip or the vbox analysis above. Also most US car mags weather correct the acceleration data. I think Road & Track doesn't.
08-16-2014, 11:10 PM | #14 |
Rep 6,125
Dinan sounds even better with noelle dp!
Congrats and thanks for sharing!
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
08-17-2014, 07:09 AM | #15 |
Curve Thrasher
623
Rep 3,773
You'll get it right William. Just take your time. Glad your liking your car better. Your car sounds better now since adding the dp. When time permits we'll all get together for round two of some more runs.
08-17-2014, 09:09 AM | #16 | |
Rep 1,027
Here is Stealth with a total bone stock car and he posted a 11.92 at 118.5mph with a 1.96 60ft time. He has a better 60ft and thus a better ET but his trap speed was only 118.5. Definitely the tune and the pipes are having an effect and I expect it will get better with time. I will probably get better on the 60ft with more practice but I think the best I can expect without putting drag radials on is maybe 11.6 ET but that would be above 125 on the trap. Cooler temps will get me the faster trap and better surface will help too. I will try to get out to the spot on the I45 service road before it gets too hot, i.e. early in the am. Of course doing it in October would probably be about the best time of year in these parts to put down a really good number. Last edited by wrsbmw; 08-17-2014 at 09:22 AM.. |
08-17-2014, 09:21 AM | #17 | |
Rep 745
Drives: '14 M5 CP & '62 corvette
2014 ///M5 Singapore Grey Metallic, Black Extended Merino, Anthracite Wood Trim, Comp Pkg, Driver Assistance Plus, Exec Pkg, Lighting Pkg, B&O, 343M Wheels (11.597 @ 122.44MPH)
Mods: Gloss Black Wheels, 35% 3M Tint, IND Gloss Black (LCI Grilles, Side Markers, Rear Emblem) IND M5 Floor Mats, RKP (McRae Splitters & Rear Diffuser), Passport 9500ci, Suntek PPF-C, M Door Projectors 1962 Corvette Convertible Red/Black (Gone:'11 750Li, '09 Z06, '08 550i) |
08-17-2014, 10:03 AM | #18 | |
Rep 1,027
So by comparison, my ET is 11.865 with a 2.0s 60ft and my trap speed is 122.8 which is really where the tune shows it's stuff. Obviously, 5mph in trap speed is a significant difference. This is probably the best stock to tuned comparison for the numbers I posted in the OP. |
08-18-2014, 08:56 AM | #19 | |
Rep 1,917
Matt
08-18-2014, 10:30 AM | #20 |
Displaced Iowan
16
Rep 47
My '13 has a stock motor and drivetrain. I did 11.97 @ 119.3 in early June when the weather was cooler. 60 ft was 1.9 s. That run was 'pristine', and I got decent traction right from the start. I haven't been able to break 12 s again, with most of my runs coming in around 12.2 s @ 119 as the weather got hotter. I think you're getting results from the upgrades. It's hard to tell from the graphs, but it doesn't look like you're getting 1 ft of rollout on your runs. If that's so, you can expect even better times at a dragstrip. Still interested in a get together with you and boots when the opportunity arises.
2011 Z4 35i Dinan Stage2 - Hers
2015 Golf R APR Stage 2 - Mine 2019 Tesla Model X Perf. w/ Ludicrous - Hers 2018 911 GT3 (Manual) - Mine 2013 911 S Cabriolet - Mostly mine |
08-18-2014, 12:04 PM | #21 | |
Rep 6,067
http://www.6post.com/forums/showthread.php?t=1024799
08-18-2014, 12:10 PM | #22 | |
Rep 1,027
Now I hope that I still have some room for improvement under these conditions due to more adaptation. I am still interested in getting together as well. I think up there around Madisonville works well for all of us. Boots is putting his car in on Friday though since he ran it hard this past weekend. I am open to meeting up this weekend if you can or we can wait for boots and spinny to be available. |
