      12-31-2013, 03:13 PM   #1
2013alpinewhitem5
Drives: 2013 M5
Why my brakes make noise?
All,
I have 2013 M5 with less than 5000miles on it.
I have noticed that when car is making slow stop between 15-5mph, brakes make noise. Is this normal?
I need yr opinions.
Thanks
For yr reference, my brakes are not ceramics.
      12-31-2013, 03:39 PM   #2
brainblade
Drives: 2016 x5m
mine squeak and bmw told me its normal. I can't stand the noise and it bothers me
      12-31-2013, 03:42 PM   #3
Knight Commander
The issue with steel pads. Need ceramic pads to reduce noise.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
      12-31-2013, 04:05 PM   #4
mstmng
Drives: M5 F10
Originally Posted by 2013alpinewhitem5 View Post
All,
I need yr opinions.
Thanks
u need to break-in your breaks as well! noise will disappear!
avlnch has written a thread on how to break-in the breaks, very helpful
search on forum
      12-31-2013, 04:16 PM   #5
Dionysus
Drives: TBC
Brake squeal is a high frequency vibration. Suspension geometry and wheel imbalances are sources of introducing vibration as well as the brake components themselves, which makes it harder to diagnose and rectify as related wear and tear to the brake components can mean that the source is not obvious and several items need to be replaced to cure it.
Not sure if BMW has tuned this out of the LCI or the specific CP suspension geometry has cured it (it was present on the pre-LCI demos I drove), but my non-ceramic LCI CP does not have this problem fortunately, as I would find it difficult to live with. It did briefly appear after I left the discs with rust on them for a couple of weeks (took some revs to free the brakes), but disappeared after the discs had been cleaned up through applying the brakes.
You can clean or replace the pads/discs/calipers, etc. to attempt to fix the issue, but it may reoccur if the source is not also fixed.
      12-31-2013, 04:45 PM   #6
Knight Commander
You're tempting fate there mate!
      12-31-2013, 04:47 PM   #7
Dionysus
Drives: TBC
LOL; I sure am
      12-31-2013, 04:50 PM   #8
Dionysus
Drives: TBC
And my discs are rusty again through not driving the car enough
      12-31-2013, 05:24 PM   #9
2013alpinewhitem5
Drives: 2013 M5
search on forum
Thanks, I will look into it !!
      12-31-2013, 05:25 PM   #10
Mikeisen
Civilian
Mikeisen's Avatar
13
Drives: 2016 Mineral Grey M4 F82
2016 BMW M4  [0.00]
Mine squeak too, not all the time, but occasionally. Was about to ask the same thing. I know that high performance brakes will squeak until they are warmed up, but mine even do it when warm. Anyone else discuss this issue with the dealer.
2016 F82 M4 - Mineral Grey
2009 911 Turbo - White
      12-31-2013, 06:16 PM   #11
dan99
Drives: 01' 330xi / 15' M235i
All,
I need yr opinions.
Thanks
search on forum
+1 bed in the brakes
      12-31-2013, 06:34 PM   #12
gblansten
gblansten's Avatar
1977
Drives: 23 Tesla S Plaid
Loud stove
      12-31-2013, 09:23 PM   #13
mstmng
Drives: M5 F10
My friend's m5 had entire break system changed by dealer, but they were squeaking worse than london double deckers
      01-02-2014, 01:15 PM   #14
ppg4
Drives: 2013 MCB
We picked up a 2013 with a bit of dealer mileage on it for a steal on the 29th. I took the car in the morning of the 31st because the right front was howling under low speed/parking lot braking. I expected them to just spread some anti squeal on the pads and be done with it.
Four hours later I get a phone call that they are ordering new pads for all four corners due to significant micro cracking on all four corners and that I will be without the car for three days while they wait for parts to arrive.
Ouch.
      01-29-2014, 05:57 AM   #15
FLOMACKS
FLOMACKS's Avatar
Drives: 2024 X7 M60
You pretty much need to wear ear protection if you're anywhere near my car when I'm coming to a stop. It totally sucks.
2007 550i
2012 BMW - M5 European Delivery
2014 911 C2S- Agate, MT, PDCC, SC, SE
2015 S63AMG Sedan
