03-10-2015, 06:50 PM | #1 |
Rep 313
My custom skid plates project
Hey guys,
I just wanted to show a custom skid plate project I worked on for my car. These are made exactly with the same material and same way as those Ferrari and Lamborghini skid plates. These are cut from polyethylene plastic, which have good impact and abrasion resistance. I worked with a mechanical engineer to get these drawn up in CAD and cut from a CNC machine. I made these to incorporate OEM bolts so any DIY'er can put these on within minutes. These will be attached with 3m double sided tape along the front edge along with the 3 oem bolts below the splitter. These have a 1/16 inch wiggle room since your bumper might be a tad off than mine. *** Holes look big, but they are cut to fit the oem washers that are locked on the bolts *** I figure this is a nice little addition to preventing unwanted and unavoidable scrapes. Let me know what you think BTW: I have two sets of these for sale if anyone is interested and can make more anytime. Last edited by ThisFlyGuy; 03-11-2015 at 12:18 PM.. |
03-10-2015, 07:23 PM | #2 |
6'0 / 250lb
137
Rep 1,797
Nice! How much?
03-10-2015, 08:20 PM | #4 |
Rep 388
skid plates
Now that is really something,
very fresh idea ! If the price is going to be fair... watch these babies go like hot cakes. Really niche idea Good luck |
03-11-2015, 03:04 AM | #11 |
Rep 102
Whilst I think the product is a good idea, I have got to question why the need to hide the price? Why have to PM for it. Are you charging everyone a different price?
This way of selling always puts me off, much like going in to a store that has no prices on anything. Just my thoughts. |
03-11-2015, 03:16 AM | #12 |
Rep 315
Drives: 13 AWSO M5,16 DGMR X5M
interested!! PM me
2012 Rosso Mars Lamborghini Gallardo STS LP570-4
2013 AW SO F10 M5 upgrades: RKP front spoiler, M performance carbon spoiler, 3D design rear carbon diffuser, KW HAS Sleeve Kit, Akrapovic Evolution Carbon tips, ind black LCI front and rear grills, GruppeM RAM intake, 20" HRE P104 satin charcoal with PSS tires) |
03-11-2015, 03:38 AM | #14 | |
Rep 313
I need to discuss with the international folks what shipping would be since I do not know the shipping logistics abroad (Canada, UK, Aus, etc.). Upon looking on the USPS site and international priority flat rates, it ranges anywhere from $40-60 depending on size. I could use some suggestions for sure. |
03-11-2015, 03:39 AM | #15 |
Rep 313
03-11-2015, 07:36 AM | #17 |
Rep 1,840
+1 on price
03-11-2015, 08:46 AM | #18 |
Rep 102
Thanks for the reply. As I've said, great idea.
A couple of questions though. What are they made of? What grade of polypropylene? What is the density and hardness? The reason for my questions is that with applying them, you are in effect lowering the front albeit by less than 15mm. However, if the grade and density is not pliable enough the shock of the scrape could deform the actual bumper. If it was a low grade soft material, this would absorb/ disintegrate thus protecting the bumper. A sacrificial limb so to say. Again just a few thoughts that fitting them would raise for me. Might I also suggest that when fitting that a washer is used on the bolt head thus spreading the load pressure a little more. |
03-11-2015, 09:24 AM | #19 |
Rep 764
I share Steve's concerns. While these look cool, they reduce clearance slightly so that they will hit, when the factory fascia surface would not. If it's a subtle scrape, no big deal - although in this case you would not have scraped without them.
If it's a bigger hit (interference), then being screwed through the RIM fascia, they are likely to transfer the load and cause damage whereas in there absence the load would have been far less. No matter what grade of PE, these are harder than RIM PU from which the fascia is molded. Screwed into place as they are, I don't see really how they are sacrificial. Again, I think they are nice and well designed. In certain specific cases they will help. But overall, I think a better solution is to just not hit the curb to begin with. I have not had one instance of this kind of scrape with my E39 M5, E92 M3 or F13 650i. Not bragging, just saying. Be careful. |
03-11-2015, 12:04 PM | #20 |
Rep 313
The material is 3/8" thick that has been cut with a beveled edge.
This is the description from the manufacturer: 1/3 less weight than solid (foamed core) Closed/small cell structures - non absorbent Weatherability (UV stabilized) Solid skinned surface RoHS compliant HDPE is produced utilizing co-extrusion technology that allows for solid outer surfaces with foamed core. The core is produced with a closed cell structure that eliminates propagation of moisture within core. It weighs 1/3 less than solid HDPE. I made this as an added extra protection in addition to being careful when driving. In no way am I saying this will be a complete indestructible shield for your bumper against scrapes- if you hit anything hard enough at any angle, it very well could damage the bumper. This was just made to give a little more peace from scraping the bumper. Not sure if you could tell, but the last picture is showing it fitted with the OEM bolts, that have the washer integrated on there already. Each of the 3 bolts have locked washers which my hole have been cut to fit (looks a bit camoflouged in the black in the last pic). |
03-11-2015, 12:06 PM | #21 |
Rep 313
