F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 335 sport front bumper WHISKERS removal / install DIY
GetBMWParts
      08-11-2012, 01:53 PM   #1
1.fresh.f30.335
Drives: 2014 535xdrive M-Sport
Hey Guys,
Heres a quick guide to replacing the bumper whiskers/blades on the F30 335 sport (non-M package).
Estimated Time: 5-10 minutes
Tools Necessary
Optional: a flat head screwdriver/plastic molding remover
Steps:
1. Take a look at the new whiskers and locate the clips. there are two on the passenger side and three on the drivers.
Passenger Side:
Drivers Side:
Pass Side Demonstration:
2. Slowly apply pressure to the whisker to pull down and pop the clip against the fog light. (you can use the screwdriver/plastic remover to help pop the tab off)
3. Now reach into the bumper behind the where the whisker attaches to the bumper, it's hollow.
4. Referring back to the whisker not yet installed, notice how the clip is configured. It is easy to reach with your finger and press down on the clip and then slowly work the whisker out of place.
*Note that you may need to apply a fair amount of pressure to work the whisker out of place, just have patience on this cause you don't want to snap the clip or the larger insert.*
5. now line up the new whisker and press. simple as that.
Other F30 DIYs:
Grills : http://www.f30post.com/forums/showthread.php?t=701830
Reflectors: http://www.f30post.com/forums/showthread.php?t=730082
Springs: coming soon
Down pipe: coming soon
Hope this Helps to answer any questions!
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa
shiftdnb376.50
vooonoo537.00
      08-13-2012, 05:43 AM   #2
MSPORTWORLD
MSPORTWORLD's Avatar
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Looks pretty good with just the whisker removed as well...does it look like its missing when it's not there?
      08-13-2012, 11:39 AM   #3
1.fresh.f30.335
yes and no, its black so it doesn't stand out that much but it looks like your missing something in the front end.
      08-24-2012, 04:42 PM   #4
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
i second that 1.fresh... me personally i have the base model and upgrading to the sportline foglight grills only(35 a pop). still debating on the whiskers tho..i guess ill see how it looks once theyre on there and how bad my ocd kicks in and take it from there.
imo, its personal preference.
the only thing in this world that gives orders is balls. You got that? Balls.
      08-27-2012, 05:07 AM   #5
Sephanite
Drives: BMW Z4
where to buy the black whiskers?
      08-28-2012, 12:19 PM   #6
1.fresh.f30.335
**********s.com
      08-29-2012, 02:24 PM   #7
steadymoddn504
Drives: e36 m3
12 BMW 328i  [0.00]
update
FYI sportline fog grills dont fit on the base model but only by a couple of missing inserts and overall whole foglight bumper dimension
had that one coming bc of different bumpers but it didnt hurt to try plus the parts guy wasnt sure either so i went with it. dnt judge me
with that being said, my plans for a gloss black theme (m performance grills+black chrome tips+gloss black fog grills w/black whiskers) are a no go..
i was trying to go for the perfect gloss black trifecta looks wise...tellem franco
      09-08-2012, 01:49 AM   #8
Lamboblue
Bad Motherfucker
Drives: 2009 E92 AW
Just plastidiped f30 whiskers red on an alpine white... It looks amazing!! Perfectly matches red sport line interior trim.. Will post pics this weekend from conputer
      09-09-2012, 09:41 PM   #9
pohlease
Drives: 2012 F30 Sport
Anyone else wish they made LED whiskers?
      09-13-2012, 07:21 PM   #10
1.fresh.f30.335
"Yes, Yes, Yes! Find One, Yes"-(name that quote)
I agree
      09-17-2012, 11:52 PM   #11
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
Hey i was wondering why is there a hole on the passenger side right next to the fog light, but on the drive side its covered next to the fog light. i seen it on a lot of pictures of people with the sport line. but on bmw website it doesnt show that hole (missing piece look)
      09-20-2012, 07:41 PM   #12
nybimmer91
Drives: 320i
Does anyone know what the section the whisker is in is called? The whole black section? I have a 320 and that lower grill (?) has no spot for whiskers, and I need to change the whole piece. Its currently all black plastic.
      09-25-2012, 08:30 AM   #13
1.fresh.f30.335
Nybimmer, if you don't have a sport the grill will not fit. I don't have the exacts as to why but I know it won't... Search it but I'm like 99% sure
Antbabee, I think it has to do with the stock intercooler(s) but don't quote me, that's based off working with Audis and vws
      12-04-2012, 02:26 PM   #14
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
I'm really considering pulling the whisker off, pulling the sport line surround out, cutting out the fog light mount and filling the gap on the inside left by the whisker, re-spraying it and putting it back in - I think big gaping holes on either side will look good
Opinions?
      01-09-2013, 01:24 PM   #15
1.fresh.f30.335
Opinions?
I agree that would look sick, let me know how it goes... I'm tempted to try it.
      02-08-2013, 01:18 AM   #16
hotwheels83
Drives: 2013 335i Sedan
Actually, I think removing the fog lamps and keeping the whiskers as it is will make it look less like something is missing. Just saw this picture in google images and I liked it.
Ever since I have seen the m-sport with front bumper lip and splitters, I am regretting my decision of getting a sport instead of m-sport
      04-09-2014, 07:56 PM   #17
RicardoSwe
RicardoSwe's Avatar
10
Drives: 2014 335i Mineral Grey
I replaced my silver whiskers today with black whiskers from IND. Went well --- thanks for the directions.
Only thing I'd add is that the black tabs on the "car side", not the whisker, do NOT move. The tabs are clearly not designed to move. So I had to gently pry the whisker "holes" to get them free. Once the small end was free, the bigger end popped out suddenly on both sides. Nothing broken, but it scared me. If something broke, it probably would be on the whisker side. Probably.
Photos showing before & after. 2014 335i Sport, Mineral Grey. The black whiskers are 100%+ better.
I was even able to move the clear bra that I had installed on the silver whiskers to the black whiskers. Check out how to install clear bra to get pointers. It involved a hair dryer for heat, a small container of water with 2 drops of detergent and a very gentle peeling back of the clear bra, trying not to stretch it. It worked fine.
      05-23-2014, 02:07 PM   #18
Jera_Jakerz
Jera_Jakerz's Avatar
Drives: 2014 BMW 335i xDrive
[SIZE="4"]Hey Guys,
OH MY G! Thank you for this, and special thanks for picture 5. I was doing my install and freaked out like I hit some bird or pressure washed the piece of plastic off because it just did not look right, but it looks like you have the same weird one sided intake as I do.
      05-23-2014, 02:15 PM   #19
Jera_Jakerz
More specifically this.
What exactly is this for, and looking at the post above mine, his gap between the intake and nada is much smaller, mine looks like a tiny piece of plastic has ripped off - the white could also be from the rushed DYI car wash I did and not thoroughly rinsing all the soap.
JB4 Stage 2 | aFe Magnum FORCE Intake System DRY | ER Chargepipe | ER CATLESS Downpipe | ATM Intercooler | BMS 2.3 Gal Meth Inj kit | Bilstein B14 | OEM Slotted/Dimpeled front rotors | Cool Carbon brakes | Go Fast Bit DV+ | Pure Stage 2 Turbo | Pure inlet
      06-02-2014, 11:26 AM   #20
Sleepwalker
Drives: 2012 BMW F30 320d M-Sport
http://www.ebay.com/itm/LED-Daytime-...732439&vxp=mtr
taadaaa! Hmm, buy or not buy..?
      07-30-2014, 12:04 PM   #21
kobebrain
Italy
Drives: F31 Sport Line
Hi
I cant remove the clip show in figure 3 and 4. I don't have a hole where to put my finger. Why?
Mine is an European F31 with Diesel engine.
      07-30-2014, 12:51 PM   #22
junkyjunky
junkyjunky's Avatar
Drives: 2013 328xi Sport Line
Originally Posted by kobebrain View Post
Hi
I had trouble at first, but if you get those small tabs off first, then apply pressure from behind where those tabs are (pushing forward) and pull from in front at the corner, they come off pretty easily.
Note, you'll need to gradually increase the pressure, I remember feeling like I was pushing too hard, but then they came off.
If your replacing them altogether, then you should worry if they break. However, if you're painting them, then just increase the pressure from behind gradually.
At least, that's what worked for me.
3 series f30, 3 series f30 diy, 3 series f30 forum, 3 series forum, bmw 3 series diy, bmw 3 series forum, bmw 3-series f30, bmw f30, bmw f30 3-series, bmw f30 diy, bmw f30 forum, bmw f30 reflectors, bumper reflectors f30, diy f30, f30 3 series bumper whiskers, f30 3 series diy, f30 3 series reflectors, f30 3 series reflectors diy, f30 3-series, f30 3-series forum, f30 bmw diy, f30 bumper reflectors, f30 bumper reflectors diy, f30 bumper whiskers, f30 diy, f30 forum, f30 forums, f30 reflectors, f30 reflectors diy, f30 whiskers, f30 whiskers diy
f30post
