      10-19-2013, 12:12 PM   #1
Simon H
Simon H's Avatar
876
Drives: M5 Competition
Battery conditioner ?.
Anybody using a trickle/battery conditioner on their M5 here ?. Will probably not use my car much when full on winter arrives, so might invest in such an item now. Thanks.
      10-19-2013, 12:34 PM   #2
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
I use the same .75 ampere Battery Tender that I use for the motorcycles and it works fine. If the battery is down a bit it may take a day or two to reach full charge, but for my use I'm in no hurry.
      10-19-2013, 12:37 PM   #3
JOHNBMWM5
JOHNBMWM5's Avatar
Hi Simon, I put mine on trickle once a week.
Sometimes leave it on for 24 hours.
It can't hurt, I intend to use mine sometimes over the winter for long runs, I will fit winter wheels/tyres though.
      10-19-2013, 01:00 PM   #4
Simon H
Simon H's Avatar
876
Thanks for the replys chaps. John, where are you connecting the charger, onto the battery itself, or the terminals under the bonnet ?, thankyou.
      10-19-2013, 02:51 PM   #5
JOHNBMWM5
JOHNBMWM5's Avatar
Under the bonnet mate.
I got one of these multi battery chargers I set it to "Jell battery" and it will condition charge, it can be left connected indefinitely
      10-19-2013, 03:34 PM   #6
Simon H
Simon H's Avatar
876
Thanks John, will have a shufty for the terminals to use, but will find them under the bonnet.
      10-19-2013, 03:43 PM   #7
Used2be
Perennial PFC
Used2be's Avatar
Not sure what the Brit meaning is for 'shufty', but the battery charger connections under the bonnet are covered in the owner's manual.
      10-19-2013, 04:02 PM   #8
Simon H
Simon H's Avatar
876
Hi Mate,
"Shufty", in this sense, means, have a look for. Just peeped at the manual, and found the connections locations, thankyou.
      10-19-2013, 04:13 PM   #9
Neil McRae
BMW Motorsport
Neil McRae's Avatar
Drives: BMW ///M4 F82 / BMW ///M5 F10
2020 BMW M5 CP  [0.00]
2015 BMW M4  [10.00]
Simon
make sure you use the terminals under the engine, if you connect direct to the battery it confuses the in car battery monitor, and can cause other chaos.
Neil.
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY
M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White
      10-19-2013, 04:35 PM   #10
Simon H
Simon H's Avatar
876
Originally Posted by Neil McRae View Post
Simon
Neil.
Thanks Neil,
Ive found the correct terminal locations, and was aware of some of the problems of using the battery terminals themselves. Ive heard of ECU damage being caused, by not using the correct locations on BMWs before ?.
      10-19-2013, 04:58 PM   #11
Neil McRae
BMW Motorsport
Neil McRae's Avatar
2015 BMW M4  [10.00]
I only know that the batter monitor thinks there is less juice than what's in the battery and can shut down non essential things even though there is plenty of juice.
      10-19-2013, 05:30 PM   #12
JOHNBMWM5
JOHNBMWM5's Avatar
Thanks Neil,
Just to be sure they are:
Negative "Steel looking POST" front L/Hand side.
Positive (Red Plastic cover) Back L/hand side by bulkhead.
      10-19-2013, 08:49 PM   #13
bobafettt
bobafettt's Avatar
Drives: 2014 M5 CP
I recommend this charger:
4 stages
http://www.weathertech.com/weathertech-battery-charger/
      02-25-2014, 11:47 AM   #14
mvigod
mvigod's Avatar
Drives: 2021 X5M
Anyone ever charge via the 12V lighter adapter receptacles (the one in front of the shifter and the other one is under passenger wheel well). I have a Ctek 7002 charger and it does have accessories for using the lighter receptacles. Safe on an F10 M5?
http://smartercharger.com/battery-chargers/#CTEK Multi US 7002
http://smartercharger.com/products/a...ator-cig-plug/
      02-25-2014, 03:44 PM   #15
ghueser
Drives: 2014 M5
I'm not sure but everything that I have read indicates that you should use the terminals provided in the engine compartment. Whenever I see the dealer cars being charged in the showroom, they also use these terminals.
      02-25-2014, 03:48 PM   #16
mvigod
mvigod's Avatar
Drives: 2021 X5M
Yeah. You are right. I just checked the manual and it explicitly says NOT to use the receptacles and only use the engine compartment terminals. Ctek charger is now hooked up to terminals and charging in progress.
I got the low battery message from the car sitting the better part of 3 months now here in the northeast except for a few short rides around the neighborhood to keep things moving. Have not been able to do that over a month and only started it for and let it run for about 5 minutes couple weeks ago.
This is the first winter I can't take the car out (or won't) at all due to salt and potholes. All should be ok now with the tender topping it off and maintaining until the thaw.
      02-26-2014, 08:19 AM   #17
mvigod
mvigod's Avatar
Drives: 2021 X5M
Anyone know if the F10 M5 (2013) uses Hawker or Optima AGM batteries? My Ctek charger has two modes. One for regular batteries and some AGM and a "snowflake" mode which they say is for Optima and Hawker AGM batteries. Can't tell what OEM battery is in there.
      02-27-2014, 04:36 PM   #18
GarbageMan
Drives: 2014 M5
I put on a Battery Tender Plus that I use for the gel cells from my boat when I pull them for the winter. I did this because I got a warning that I had discharged it last Friday evening when I washed before Saturday clear bra installation. The warning went away when I started it and moved it, but it put the charger on nonetheless, just because I was not driving it this week. I have had it on for four hours and don't have a blinking green light yet to indicate I'm getting close... The car only has 700 miles... This is silliness...
      02-28-2014, 05:40 AM   #19
GarbageMan
Drives: 2014 M5
I'm thinking about taking the car in for a new battery. It is two months old, and I can't get it to "green" blinking or solid status. The trickle charger is a Deltran Bettery Tender Plus, the same as BMW's (Deltran makes them). The problem is that if the battery still starts the car, I suspect they won't replace it, regardless if it won't hit full charge... The car is two months old... In any event, I should probably get it into them to "mark my territory"/go on record right now, as a potential battle may ensue in the not too distant future. I think I have a dud. Opinions?
      02-28-2014, 06:05 AM   #20
bobafettt
bobafettt's Avatar
Drives: 2014 M5 CP
It took my m5 almost 2 days to go to full on my battery charger. The problem could lie with the battery charger itself. I would wait it out and give it a few more days of charging. If this doesnt work, then maybe a trip to the shop would be in order.
      02-28-2014, 07:22 AM   #21
ghueser
Drives: 2014 M5
My garage is pretty cold so when I used the CTEK a few weeks ago, just put it in the snowflake mode. Had no issues at all and the M was fully charged in roughly 30 hours. I could have kept it on but finally got a set of all season tires on the car so have been able to drive it. As far as specific type of battery, I think it is still a conventional type. You can unscrew those two plastic nuts on the trunk floor however and get access to it. (It's located right where our old spare tires used to be in days of old )
      02-28-2014, 10:08 PM   #22
GarbageMan
Drives: 2014 M5
The charger is sound. I use it all the time on my boat's gel cells, but you have me intending to put it on and leave it on this weekend to see if I can get "green".
