07-12-2021, 06:48 PM | #1 |
Cole
321
Rep 498
Power steering or AC noise? What is this noise
Ive been trying to figure out what this noise is for a couple weeks. Sometimes its there, some times it isnt. Louder when AC is on. Any ideas? Definitely coming from one of the accessories up front.
07-16-2021, 02:47 AM | #5 |
Rep 19,565
It's that sewing machine clicking sound that Manzera had,but his was far worse. He said it was a dct g/box mounting seal that needed replacing though he never came back to confirm.
07-16-2021, 11:33 AM | #6 |
Cole
321
Rep 498
07-16-2021, 01:09 PM | #7 |
Rep 19,565
11-01-2021, 10:33 PM | #8 |
Cole
321
Rep 498
Just an update if anyone else hears this same noise,
Dealership had the car for a couple weeks and eventually gave up. They basically narrowed the noise to bottom end and said i could pay to have the pans pulled to see if the rod bearings or wrist pins are the cause. Took it to my local bmw independent shop and they came back after a few days of diagnostic time with same conclusion. Sent oil out for analysis, left car sitting in the garage for over a month now. Came back with better than average wear readings for all metals. I decided to have the shop go ahead and repla e rod bearings. Hopefully they dont find anything else and the bearings are replaceble. Will know more by Friday when its all done. |
11-01-2021, 11:15 PM | #9 | |
Rep 538
11-02-2021, 09:12 AM | #10 | |
Cole
321
Rep 498
Unfortunately, at this point iwe are certain 100% the noise is someher on bank 2 in the bottom of the motor. They are going to pull the lower pan, look over the oil pump and than proceed up to changing the bearings. If we find nothing, we will replace the bearings as a preventative measure and put it back together. At that point we will be completely lost as to where the noise is coming from. Bmw said possible put a camera in the top to inspect at that point. |
11-08-2021, 09:55 PM | #11 |
Rep 71
Hmmmm....This sound seems a bit random to me. No clear cycle. How does the sound change with revs (if at all)?
88 S14 M3 (NASA GTS3 racecar) / 11 6MT 550i M Sport / 14 6MT M5 Competition / 15 X5 50i M Sport (tow vehicle)
11-10-2021, 07:13 AM | #12 |
Cole
321
Rep 498
It doesnt change with rpms whoxh is even more puzzling. It actually goes away at about 2k
Either way the bottom end has been taken apart at this point. New bearings are being installed this morning so we shall find out if that was the cause. I went over and looked at the internals while it was on the lift yesterday and everything looked extremely clean. Wrist pins, cyclinder walls, oil pump, bottom of pistons, all looked and brand new. |
11-10-2021, 05:45 PM | #13 |
Cole
321
Rep 498
Well its discouraging, picked up the car today and the noise is exactly the same. Good news is the bewrings showed plenty of wear and were definitely in need of replacement. But unfortunately, i still have no resolution as to the noise cause. Shop feels everything looked
rand new inside and moved smoothoy so they have no idea where to go at this point other than drive and get it to blow up for warranty to cover a replacement motor. Lost at this point. |
11-10-2021, 06:21 PM | #14 |
Rep 545
It sounds like the known DCT seal issue and fw chatter to me.
11-10-2021, 06:44 PM | #15 |
Cole
321
Rep 498
11-11-2021, 12:44 PM | #16 | |
Rep 71
11-11-2021, 08:12 PM | #17 | |
Cole
321
Rep 498
My warranty is a third party warranty. Wont make any difference who changed to bearings. Its already documented by bmw that the bearings were possibly the cause. |
11-12-2021, 02:51 PM | #18 |
Rep 538
I was hoping for a different resolution for you. You need to find a different shop, I would've done that way before changing the bearings.
I went through 3 "performance" shops that mainly focused on BMWs before finding one that actually solved the problem I was having last year. Don't give up! |
11-12-2021, 05:16 PM | #19 |
Rep 19,565
If the rod bearings were worn then it's good that they were replaced, saving the engine. Inspecting the oil filter folds gives a precursor to r/b failure if there are metal filings or debris there.
As far as the sewing machine noise goes then it's continue with the search. |
11-12-2021, 08:52 PM | #20 | |
Rep 71
I do not trust aftermarket warranty to take care of any major issues in a performance car like this. Their fine print tends to have so many clauses that they always have a way out of not paying for a blown engine, so I have always skipped them. A bearing on a stock E92 M3 I bought new spun at 15k miles and it took BMW 3 freaking months to agree to replace it (with the scored crankshaft). The repair bill was ~$12k (don't ask me why; BMW covered it). So, if that is how BMW acts, I expect less from an aftermarket warranty issuer but again one may get lucky. Anyway, I hope you get to the bottom of the issue. I am at a loss as to why nobody can localize it...
11-13-2021, 02:21 PM | #21 | |
Rep 74
11-13-2021, 02:33 PM | #22 | ||
Rep 538
