      11-05-2021, 06:21 AM   #1
Craze
Front sway bar link measurement
Hi i have front dinan sway bars front and rear
The end spherical balls each end of sway links are worn and making clicking noises over bumps
The measurment is 415mm centre to centre
Can anyone measure stock ones please to see if this works? I threw mine out years ago
Alternatively can i order sway links either completely or ends only?? The ends are different as top one is m12 and spherical washer and bottom is m10
The manual does list some part no but description and qty doesnt match up and doesnt actually show what part no is what
Any help is appreciated
Thanks
      11-05-2021, 02:03 PM   #2
vafan13
Drives: Sakhir Orange F10 M5
It looks like they are around 340mm. I would contact Dinan and see if they can sell you just ends with the balljoints, or at least the whole end link assembly.
Even if you could make the stock ones work without binding, you'd at best be down to just 2 settings (high and low), as you'd have to use the same hole on each side. You might even be forced into only one setting to prevent binding.
      11-05-2021, 02:12 PM   #3
Craze
Thanks
So i need the dinan links
Bit of a shame only did 10000km or so on them and already clunking
I will await there reply email!
Or can i get cp pack front and rear sway bars? The genuine stuff always lasts forever
      11-05-2021, 02:29 PM   #4
vafan13
I'd stick to getting new endlinks for the dinan if you can. BTW, are you 100% sure the nuts for the links are torqued down properly? I had a clunk a few thousand miles after installing mine and turned out one of them had come loose. To be sure I would jack up the front to get the weight off and check that way.
      11-05-2021, 09:25 PM   #5
Craze
Hi yes i am sure thanks
End links have play for certain
Ive contacted dinan and esc tuning
Strange esc list one of them on website (but no pic) and dinan doesnt
