12-08-2021, 04:50 AM | #1 |
Rep 99
Drives: BMW F10 M5
BMW M5 - New Brakes and Rotors Break In
I recently changed the brake out on my car to go with the Hawk Ceramic compound brakes as I always had great success with them and I went with the Zinc Coated rotors... is there a special break in process to make sure the wear is even.?
12-08-2021, 01:59 PM | #2 |
Rep 19,560
Just go the first 200 mi with gentle application to bed in then increase approaching 200.
12-08-2021, 03:21 PM | #3 |
Rep 538
I've done this procedure on countless sets and never had a problem. Make sure you do it on an empty backroad so you can follow it like it says, otherwise you risk warping them. They'll get hot and smell too, that's normal.
12-08-2021, 10:18 PM | #4 | |
Rep 99
Drives: BMW F10 M5
2013 BMW F10 M5, Moonstone Metallic, 700whp, stage 2 tune, fully straight piped - catless downpipes - resonator delete and fabspeed muffler delete, cold air intake and many more cosmetic mods. | '92 525i (long gone) | '02 Dinan M5 (sadly gone) | '06 Dinan M3 (also sadly gone)
12-08-2021, 10:22 PM | #5 |
Rep 99
Drives: BMW F10 M5
Thanks this is similar to what I have heard!
12-09-2021, 01:10 AM | #6 |
Rep 19,560
I would never do it that way (on new pads.
12-09-2021, 09:47 PM | #7 | |
Rep 71
On street cars, I've never bothered to go through this process, slapped on the pads and drove normally and that also worked! The biggest piece of wisdom in that note is the bit about not engaging the brakes when stopped (including parking brake) when the rotors are really hot. That will result in uneven pad compound transfer and vibrations. That does not "warp" a rotor. ("warped" rotors are the biggest piece of scam in dealership history). One way to solve the issue is to slap on some really aggressive pads and use them to scrape off the uneven deposits.
88 S14 M3 (NASA GTS3 racecar) / 11 6MT 550i M Sport / 14 6MT M5 Competition / 15 X5 50i M Sport (tow vehicle)
