04-26-2023, 07:07 AM | #1 |
Rep 538
the magical disappearing oil consumption & Sport+ throttle
Curious if anyone else can speak to this. For the first two years of ownership I was burning a quart of oil every 1500-1800 miles. Last year I chose to run the car only in Sport+ throttle once up to temp, as I wanted the significantly lower coolant temps. However something happened that I did not expect: I burned no oil. It got to the point where I got a bit paranoid about the oil level sensor, but with 4.2K miles on the oil I did the change not long ago, got out what I expected, and the oil level sensor was confirmed working.
Has anyone else experienced this? My only guess is something Sport+ throttle does has some impact on crankcase pressure, causing it to keep a vacuum in certain scenarios it wouldn't otherwise and thus prevent oil from coming through the PCV. That said, I'm a bit stumped.
04-26-2023, 02:50 PM | #2 |
Rep 280
I can’t confirm the oil consumption but I drive on sport plus ALL the time no matter what the scenario is, I think efficient is garbage and frankly horrible for the motor from how hot it gets.
Sport plus won’t do any harm while the car is warming up as long as you don’t get into boost |
04-26-2023, 03:46 PM | #3 | |
Rep 112
04-26-2023, 04:42 PM | #4 |
Rep 538
I noticed it too, especially in the winters when the whole car stays much cooler.
During the summer I get more oil burn, it’s even visible in the back due to the catless downpipes. Priuses hate me |
04-27-2023, 09:45 AM | #5 | |
Rep 159
ICE are thermal engines, so the efficiency in the cooling process is paramount for improved results like better fuel economy, longer oil changes, less mechanical wear etc. |
BMWSauberF135.50 |
04-27-2023, 09:56 PM | #6 |
Rep 171
My car has 81K miles. I purchased over 4 years ago with 38K miles. I have always driven in Sport+ and never had to add oil between changes every 5K miles with Liqui Moly 5W-40. Also have a BMP Stage 1 tune. Maybe I'm just lucky.
04-30-2023, 07:38 AM | #7 |
Rep 538
I thought about oil temps but I don't see a noticeable difference in sport+, at least not in the driving I normally do. I guess it is possible oil going through certain paths is staying noticeably cooler. My best guess, though, is still that it's something stopping oil from coming back through the PCV.
Anyways, I suggest anyone burning oil try running only in Sport+ throttle and see if it stops. Last edited by vafan13; 04-30-2023 at 07:59 AM.. |
04-30-2023, 11:59 AM | #8 |
Rep 742
Drives: '13 F13 M6, '94 JDM Supra
You can also run a cooler thermostat that way you're not having to run it in Sport + all the time. If I were keeping my M6 that's what I'd do, as the throttle response is way too touchy in Sport +
2013 F13 ///M6 Alpine White • Zandvoort Full Merino Driving Assistance Pkg • Exec Pkg • Vent Seats
Vorsteiner VFF-103 Carbon Graphite 343M dimensions • H&R Lowering Springs • Soul PP Resonated Muffler Delete • AeroFunction AF-1 Carbon Front Lip • Carbon Front Grilles • Carbon Mirror Caps • IND Black Fender Vents |
04-30-2023, 08:28 PM | #9 | |
Rep 538
I've considered it but honestly one gets used to sport+ very quickly. Last edited by vafan13; 04-30-2023 at 08:39 PM.. |
04-30-2023, 09:58 PM | #10 | |
Rep 112
I’ve been running sport+ all the time now for the past few days and already I noticed when I get back from drives my car doesn’t smell like burning oil like it usually does I’m assuming just because the temps are so much lower. Well one time I still smelled oil but I had just been bombing it on the freeway on the way home so even sport plus couldn’t keep the temps down to under 210 oil temp that seems to be the magic number is in that 200-210 range for oil temp. Once it gets into the high 210’s and 220’s that’s when I really smell the oil burning smell. |
06-29-2023, 07:21 AM | #12 |
Rep 19,548
06-29-2023, 07:38 AM | #13 |
Rep 91
06-30-2023, 03:04 PM | #14 |
Rep 66
07-02-2023, 03:56 PM | #15 |
Rep 91
