05-20-2023, 01:14 AM | #1 |
Rep 9
Rod knock or something else?
Hello guys, wanted to see if anyone could help with an advise if its not a rod knock to what it can be?
Here is the link to the video, the car is fully warmed up and idling, nothing can be heard from inside, and very faint sound when standing outside, however, from under the car more toward the right side (passenger) is where it is the loudest: It is happening only on Idle, the slight RMP increase make it disappeared, here is the video of slight revs of the engine The story on the car, it is 2014 M5 competition package 100k on the odometer, but it is all misleading, as the engine got locked up on it (busted oil pan) and I finally got around replacing the engine from a wrecked donor 2013 M5 with ~ 60k miles on the clock. So, the engine is with 60K paired with original transmission 100k. Prior the swap, I ran the donor engine, however, due to the fact that it had full straight pipes and free flow intake, it wasn't possible to hear such noises, at least I didn't hear them. Now I am wonder, if I end up putting the engine that is on the way out, or I it is not the rod knock. At the same time, I drove the car already for around 800 miles, with no apparent changes in the noise level or its intensity. I sure hope perhaps it is the injector related problem, or maybe even flywheel noise, or whatever else it can be. I would think if it was indeed the rod knock, it would not go away with the very slight RPM increase, car idles perfectly fine, in fact no any issues at all. |
05-20-2023, 02:14 AM | #4 |
Rep 9
No being in gear vs neutral or parking makes no difference on the noise. The only thing that makes it go away a very slight increase in the rpm. I think it idles around 500-600, so going up to like 900 makes it disappear
05-20-2023, 04:58 AM | #5 |
Rep 19,560
Like Alrock31 says it's not rod knock or it would be pronounced, I don't think it's a big problem if it disappears above tick over, if you can increase the tick over to some more see what that does. A/c on and off does it still do it?
05-22-2023, 10:22 PM | #6 |
Rep 9
Sorry took a while, good point was to check with the ac being off, however, ac didn’t seem to make the difference.
05-23-2023, 03:42 PM | #7 | |
Rep 9
I ordered a blackstone oil analysis container, will sample to see what is going on with the oil to give me a peace of mind Another test I could do, is while it’s running try to have each cylinder disabled(injector or spark plug wire) to see if the noise disappears on any of them. It’s going to be a pain though to get it done, plus it’s so already hot outside by the time I get to the last cylinder will fry my hands |
05-24-2023, 05:22 AM | #8 | |
Rep 19,560
