06-30-2023, 06:17 AM | #1 |
Rep 575
Drives: 2016 M5 Comp. Ed.
engine overhearting warning - but engine temp is normal
Hi, I came back into my parked car (after 40 min at the shops) and started it, got this overheating warning right away. Notice (first 2 photos) though that the engine temp display shows normal starting temp. It is not even a hot day and this is late morning and the car had been parked for over 40 min.
Second 2 photos show the temp while driving around for a few minutes after the initial warning. Last 2 photos are after driving back home (after about 25min of first warning) where the warning has disappeared and engine temp display is still normal. What could it be? Faulty sensor?
Current:
2012 520d 2016 M5 Comp. Ed. 2020 Porsche 911 Carrera S (retired) 2023 X5 xDrive45e |
06-30-2023, 11:12 AM | #3 | |
Rep 575
This is why I never thought this fault was referring to the engine coolant since there was no mention of the coolant. Also, the coolant error message was persistent because at first I just thought the coolant level was low so I topped it up but due to the leak I kept losing it and the error message would pop up again. This message just mentioned the overheating engine ONCE and then disappeared. If this was coolant related should I expect another error message about the low coolant level? Any other possible reason to get this fault?
Current:
06-30-2023, 02:01 PM | #4 |
Rep 19,563
^ It could be a sensor glitch, if coolant is not being lost anymore then it may be a signal bounce from when it was.
When dealer bled the brakes on mine last year the brake fluid warning came on after being parked up for shopping, after switching off for a minute the warning disappeared and never came back on again. |
darrko62.50 |
06-30-2023, 09:16 PM | #6 |
Rep 146
Drives: BMW's
Garage List 2020 G07 X7 [0.00]
2013 E70 X5 [0.00] 2003 E46 M3 [0.00] 2013 F10 M5 [0.00] 2009 E90 335ix [0.00] 2009 E90 M3 [0.00] |
If you check faults in the DME you’ll probably find a problem with the turbo coolant pump. Whether the connector is melted to the pump or it’s just internally faulty it will likely need replacement.
