      05-23-2017, 07:24 PM   #1
panhe
Drives: 2013 BMW M5
Transmission problems
I installed Dodson clutches(before I knew their bad rep!) car seems to ride fine but shop tried to do the relearn and keeps getting these faults:gearhift rod,position sensor of the gearshift rod,gear 5 or 7 is blocked.Opened up the transmission again everything looked fine mounted everything again,got the same fault codes. Anybody have any ideas what could be the problem?
      05-23-2017, 07:44 PM   #2
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
This isn't the clutch - trans is busted. Search the threads... I tried to solve this for months and ended up getting another DCT.
FSociety3812.50
      05-23-2017, 07:46 PM   #3
allmotor_2000
1087
http://f10.m5post.com/forums/showthr...ight=DCT+build
      05-23-2017, 08:44 PM   #4
panhe
Drives: 2013 BMW M5
I was afraid of that!Did you rebuild the transmission or get a new one?
      05-23-2017, 09:05 PM   #5
allmotor_2000
1087
New one...
      05-24-2017, 06:30 PM   #6
panhe
Drives: 2013 BMW M5
Did you buy it from a bmw shop or elsewhere,around how much do they go for?thanks
      05-24-2017, 07:16 PM   #7
550Reasons
550Reasons's Avatar
Drives: F10 550i
Damn wtf ? What could have caused that ?? Was it because of the clutch install ??
2011 550i
2013 M5
2014 M5 CP
2016 550i
      05-24-2017, 07:28 PM   #8
panhe
Drives: 2013 BMW M5
No,apparently the internals of the transmission may fail with the high hp,unclear what will be a safe limit to take our car ,I have 776whp.
      05-24-2017, 07:57 PM   #9
allmotor_2000
1087
You can find them used for 3-4K plus install.
Clutch doesn't cause the rod 5-7 issue.... torque does!
      05-26-2017, 09:58 AM   #10
panhe
Drives: 2013 BMW M5
Any particular reason to buy the whole transmission versus only the megatronic unit if the clutches are intact?
      05-26-2017, 01:26 PM   #11
allmotor_2000
1087
1. New mechatronic unit was the same price as a used trans
2. Issue wasn't with the mechatronic... its with the actual transmission
You can't just take a used mechatronic... car won't start (EWS/CAS alignment). With the new trans I had to use the original mechatronic unit. You can buy a NEW mechatronic and have it VIN coded by BMW but that doesn't solve anything.
Clutches can be swapped over obviously.
      05-26-2017, 02:37 PM   #12
panhe
Drives: 2013 BMW M5
Im having trouble finding the transmission,any specific place I could
Look into?Thanks for all your help allmotor
      05-26-2017, 04:06 PM   #13
allmotor_2000
1087
Ebay:
http://www.ebay.com/itm/12-BMW-M5-M6...FZD~B8&vxp=mtr
http://www.ebay.com/itm/BMW-F10-M5-F...VY9kTE&vxp=mtr
There are like another 8-9 on car-part.com Search for 2014 BMW M5 Transmission and select 7AT (DCT).
Even a 2016 with 5K miles...
All between 4-5K
      05-26-2017, 05:39 PM   #14
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
On the dodson set we did(before we swapped to SSP) I would sometimes get this fault code if the car wasnt super hot before trying to do teach in. Eventually after I got it hot enough it would go through.
      05-26-2017, 05:56 PM   #15
panhe
Drives: 2013 BMW M5
Tried many times,transmission is shot!
      05-27-2017, 05:59 PM   #16
wheelpro
wheelpro's Avatar
Egypt
176
Drives: M5,F10,JB4,DP,CP,METH,SSP
I had this fault code after installed my new clutches
but I you have to know for 2 big snap ring both like same size but not same thickness
can you tell me big thickness and thin one where installed ????????
      05-27-2017, 06:49 PM   #17
allmotor_2000
1087
There are two reasons this code could come about:
1. As Wheelpro stated
2. My issue was when redlining 4th gear it would cut out and throw a transmission error
      06-02-2017, 05:37 AM   #18
NightM
NightM's Avatar
450
Drives: Bmw
Sounds about right
      10-09-2017, 10:44 AM   #19
steeve13m
There appears to have been new revisions by BMW to this trans to fix issue....one member "Cocoa" got a trans replacement under warranty with a different part number B28007843840 ?
      01-23-2018, 11:45 AM   #20
steeve13m
Clutch diagram....anyone can confirm the latest part number fixes(red) the issue VS the earlier part numbers? if we decide to change transmission
BMW dealer said they have seen this issue and it is caused by internal metal shavings due to wear accumulating in the magnet(?) inside transmission and thus requires a transmission change(interesting)
      01-23-2018, 02:24 PM   #21
M5Rlz
Drives: R8, f10m59(Rip), m4, GTR
They don't have a bad rap any more than if you go to a GTR board and talk about SSP and Dodson having all the GTR records. Its simply a platform that in this case SSP is king of and has down pat.
Coming from GTR land where I got 30k miles out of Dodson clutches at 1400hp+ I'd have immediately went with them again. But as you see from reading here all the success is coming from SSP so on further inspection SSP is the choice for the M5. Hardly means dodson is bad, just not the best for this platform.
      01-23-2018, 02:26 PM   #22
steeve13m
M5's from (2012-2015) Getrag GS7D36BG
M5 from late 2015 > Getrag GS7D36SG
Anyone have details on this new version Getrag GS7D36SG ?
