09-28-2019, 10:34 PM | #1 |
Rep 429
F10 Carbon Ceramic Brake (CCB) Kit Install success w pictures
I recognize this topic has sparked some debate and my sanity may come into question but installed the Carbon Ceramic Brakes this past week replacing my factory Steels. I was able to source a new Carbon Ceramic Brake Kit (Part 34112317804) for far less than retail and able to make it work with my local dealer doing the install below their normal shop rate. The instructions suggested it would take 4 hours but realistically ended up taking 11 as they have to install a new booster and bleed all the lines as well as replacing all the rotors, pads, calipers, etc.
I decided to move forward for several reasons. First, I needed rotors and pads on all four corners and anticipate keeping the car at least 3 or 4 more years. Secondarily, I enjoy having peace of mind that I won’t need to replace the brakes again during my ownership, appreciate no brake dust and really dig the gold calipers and shiny rotors. I recognize I could have just painted my steels but that just didn’t sit too well with me. I’m not going to track the car – and there has been discussion that even if you track the car – you’ll have to replace the carbon ceramics anyways, etc. I think a lot of things came together and even though it wasn’t cheap – it was something I could manage. The install went great with one hiccup towards the end. I only felt comfortable having a dealer install in lieu of an independent shop and glad I went this route. Even though the instructions suggest you don’t need to do any coding – the dealer insisted that coding or something needed to be done. They ran into snags as I had coded a few things myself using Bimmercode and the computer was not accepting whatever they were resetting – specifically suggesting I needed a new idrive controller? (I replaced mine with a ceramic one but that was plug & play with no coding) After calling the home office in NJ to add the product code 2NK and resetting my “build sheet” I was good to go – no need for a new idrive controller, etc. Only downside is I have to recode all the previous changes again but that isn’t too difficult. I think this should satisfy my mod bug for at least a few months. 😊 Hope you enjoy as much as I did and I’ll try to get a full car shot sometime in the next few days. One last comment – I noticed my M stickers on the front calipers are all white whereas I’ve seen others with the M colors. I’m curious why they are different and ordered some replacements from ebay for cheap if I decide to change. Part Number Quantity Description Wieght Notes 34 11 2 284 370 1 Repair kit, brake pads asbestos-free 12.4 lb 34 21 2 284 390 1 Repair kit, brake pads 3.8 lb 34 11 2 284 801 1 Carbon ceramic brake rotor, left 17.5 lb 410X38 34 11 2 284 802 1 Carbon ceramic brake rotor, right 17.5 lb 410X38 34 21 2 284 803 1 Carbon ceramic brake rotor, left 12 lb 396X26 34 21 2 284 804 1 Carbon ceramic brake rotor, right 12 lb 396X26MM 34 11 2 284 815 1 Protection plate left 0.7 lb 34 11 2 284 816 1 Protection plate right 0.7 lb 34 33 6 850 655 1 Seal, brake booster 34 33 7 846 663 1 Brake servo unit 4.8 lb 34 21 7 848 313 1 Caliper housing left 7.9 lb 34 21 7 848 314 1 Caliper housing right 7.9 lb 34 21 7 848 315 1 Calliper carrier left 3.6 lb 34 21 7 848 316 1 Calliper carrier right 3.6 lb 34 11 7 852 119 1 Caliper housing left 10 lb 34 11 7 852 120 1 Caliper housing right 10 lb 51 75 8 049 956 1 Engine encapsulation, front 7.8 lb M 51 75 8 059 917 1 Cover, brake air deflector, left 0.2 lb 51 75 8 059 918 1 Cover, brake air deflector, right 0.2 lb 51 11 8 174 185 4 Expanding rivet SCHWARZ 07 11 9 905 374 2 Self-locking collar nut 0.35 oz M8-10 ZNS3 |
Ickdeep5720.50 OneExtra810.50 theinfamousdrew501.00 94jedi830.00 Pankrivoklat33.50 bquicksilver25.50 M5Rick60134.00 |
09-29-2019, 03:35 AM | #2 |
Rep 634
Congrats on the upgrade, I'm supre you will be happy.
I have them on mine and I really like them. Few words of advise. -Certain cleaning agents will make them virtually useless for a short while, wise to use the brakes after cleaning the car. -They do squeak a fair bit I must admit I did laugh when you said you got them "far less than retail". I checked prices for 4 rotors and pads, with my 15% discount at that parts dealer, I was quoted 22.700USD. Which was laughable considering that in my Country they are a 7700usd option when you order the car. Full price one front rotor was 6400usd. At that price I was hoping I would never have to replace them. |
Beast27358.00 |
09-29-2019, 03:35 AM | #3 |
Rep 19,582
Nice install and it doesn't look that difficult,just add one at a time to what your replacing the only thing being the tight confines of the booster?
Are you happy now with the performance and how is brake dust compared with when you had the steel ones. |
Beast27358.00 |
09-29-2019, 03:44 AM | #4 | |
Rep 19,582
09-29-2019, 06:17 AM | #5 |
Rep 485
Congrats to an amazing upgrade, absolutely stunning!
And thank you so much for the detailed technical information and documents, very helpful for others attempting the same modifications. I planned on doing this upgrade shortly, but our newborn daughter deserves more attention at this point I do have the retrofit kit in my garage though and a firm installation quote from my local BMW dealership, I will get it done next April, after winter time. I’m very looking forward to having the kit installed, it’s a lot of money indeed! I hope I can contact you in case questions arise, since my dealership doesn’t perform this costly upgrade on a regular basis. Once again, congratulations and enjoy her in good health. And by the way, I also did the ceramic iDrive controller upgrade, totally worth it. Last edited by SCD-1983; 09-29-2019 at 06:26 AM.. |
09-30-2019, 08:00 PM | #8 |
Rep 429
Sure - feel free to reach out when installing - my dealer also was a novice as my Service Adviser had only seen it done on an M3 in 5 years...
10-01-2019, 01:39 PM | #9 |
Rep 485
10-06-2019, 01:03 PM | #10 |
Rep 429
Have had them on for about a week and a half - love the performance and didn't hear any squeaking until a few days ago at low speeds but not too loud. I guess I'm pretty used to it as my steel's did the same.... overall - happy with my upgrade.
10-15-2019, 08:30 AM | #11 |
Rep 28
Drives: BMW F10 M5
CCB
Hey Beast - I may be a new guy to M5POST, but not to blogs/bulletins; so, permit me to share my appreciation for your presentation - it represents the type of intelligent postings that make blogs meaningful; really well done, thanks...
Pankrivoklat33.50 |
10-26-2019, 08:48 AM | #12 | |
Rep 634
Fall has really set in where I live which means rain 5 days a week, squeaks a lot until I have used them and dried them off when the car has been parked outside. |
10-27-2019, 09:28 AM | #13 |
Rep 1,254
NC folks; I'm sure we could knock this out in a weekend in someone's garage, I'm game for a DIY day!
11-10-2019, 01:12 PM | #15 |
Rep 429
Went with Ceramic controls as well...
11-14-2019, 11:36 PM | #17 |
Rep 349
Nice retrofit of some very serious braking components. Thanks for posting!
I hope you never have to replace the exorbitantly expensive rotors again though (shouldn't have to if you're only going to keep it for another few years, but at some point someone is going to get whacked!). |
11-15-2019, 11:03 AM | #18 |
Rep 485
I would enjoy a DIY day a lot, I used to live in the GSO area for many years. After receiving an awesome offer to return to Germany, I decided to sell my BSM M5 and purchased a German imperial blue metallic M5 I will perform the upgrade to MCCB next spring, I plan on taking tons of pics and report back. She is hibernating now, stored away during the brutal German winter time. By the way, I dig the ceramic controls, recently installed the iDrive controller myself
94jedi830.00 |
11-18-2019, 12:34 AM | #19 |
Rep 72
This is common missconception. One can't compare price of _upgrade_ when buying new car. Upgrade price does not contain price of regular brake kit (standard fitment on car) which is also pretty expensive.
2019 BMW F90 M5 | 2014 Porsche 991 Carrera 2S | 2013 BMW F01 740dX | 2011 BMW E82 1M Coupe | 2008 BMW E70 X5 3.0d | 2003 BMW E46 M3 Coupe | 2000 Porsche 996 Carrera 4 | 2000 BMW E39 535i | 1998 BMW E39 528i
11-20-2019, 02:12 AM | #20 |
Rep 485
Quick question: Did you replace the whole control unit or just added the ceramic knobs? I could purchase a full set of ceramic control unit, but I don't know if the replacement is a hassle. Thanks for any insight
11-20-2019, 07:36 AM | #21 | |
Rep 429
https://f10.5post.com/forums/showthread.php?t=1524455 |
11-20-2019, 12:06 PM | #22 | ||
Rep 485
