10-05-2023, 02:43 PM | #1 |
sportscars only
3245
Rep 3,195
Stupid tight bathroom faucet
I'm trying to diy this lousy faucet that is stuck (well, tight, as if the rubber isn't moving smoothly inside the cartridge). I tried taking off the top but the ring marked in red is stuck or is one piece w the stem...so how the heck can I fit a wrench in there to loosen the nut and take out the cartridge? There must be something I'm missing. I tried to follow this YT diy video but I'm stuck (no pun intended lol).
Please help. Tia.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
10-05-2023, 03:44 PM | #2 |
Rep 2,010
Socket wrench?
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
tranquility3244.50 |
10-05-2023, 04:16 PM | #3 |
C2H5OH
3915
Rep 2,144
Open the valve and try again. There can be a little suction and it can make them stubborn.
If you're replacing it, don't be afraid to get a little rough with it. That beauty ring at the top, use an old rubber jar opener and a pipe wrench. It'll come off without marring it. |
tranquility3244.50 00SH4WN84.50 |
10-05-2023, 04:19 PM | #4 |
Rep 914
I tried to replace a Moen cartridge with no luck with the plastic nut. You would think it would be simple. I wound up destroying it and just buying another faucet.
10-05-2023, 04:37 PM | #5 |
Rep 2,010
It appears that there is a nut surrounding the green area, so maybe the correct size socket wrench would help. It should fit inside the ring.
10-05-2023, 04:57 PM | #6 |
Rep 279
Drives: 2014 328Xi GT, 2020 X3 MC
Some times you just have to bite the bullet and replace it all. It's a shame as it has replaceable parts, just can't get them apart to replace them.
10-05-2023, 04:58 PM | #7 |
Rep 2,873
Many of these use a specialized tool to fit inside and turn threaded parts, or something kind of like a bearing puller that screws into the threaded hole in center of the square stem. If you know the brand, find more (or better) videos.
10-05-2023, 05:43 PM | #8 | |
Rep 145
You need to pull the chrome finishing ring off first. It’s threaded usually. Use a non marring strap wrench or wrap a rag around it and use a pipe wrench. Thread it off. Then undo the brass nut that holds the cartridge in place. Wiggle the cartridge and pull straight up. Replace the cartridge and make sure all the old orings are out. Put some lube on the new seals before sliding the cartridge in. Make sure you turned the water off, and open the tap to drain it
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, |
10-05-2023, 06:25 PM | #9 |
sportscars only
3245
Rep 3,195
So that part I highlighted in red comes off for sure? I just need to put some muscle into it?
What lube do you suggest? The video I think refers to 'silicone grease' but I wonder is there something else or the hardware store will know what I'm talking about? Tx everyone.
10-05-2023, 07:08 PM | #10 | |
Rep 145
usually it corrodes in with the water, cleaners, and soap mixture. removing that will give you access to the cartridge nut. You can see the threads on the outer part of the brass body in the still start of your video posted Once you remove that, you can wiggle sthe spout back and forth and lift it off the body and lube that up also. Be carefull as some of them have orings as well.
10-06-2023, 09:00 AM | #11 |
Rep 279
They should have a plumbing grease that you use to lube it.
Also look to see if they have a puller as it won't wiggle much. Like I said, sometimes starting new is easier and cheaper. |
tranquility3244.50 vreihen1615271.00 |
10-09-2023, 05:30 PM | #12 |
Rep 3,406
10-10-2023, 01:29 AM | #13 | |
We are what we allow ourselves to be...
85
Rep 93
10-10-2023, 06:41 AM | #14 |
Rep 802
Retired Master Plumber of 35yrs chiming in,trust me when I say just go buy a new one. They're cheap enough to throw out and go new. Unless it you have a Grohe,Toto or high end Kohler toss it
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582) Gone but not forgotten: -'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG |
10-11-2023, 01:34 AM | #16 | |
Rep 802
Alternatively: If you're not ham-fisted you could use a Sawzall and cut the base of the faucet right off without damaging the lavatory,the rest will fall under the lav Have tools,will travel... however my hourly rate from South Carolina to Canada may not appeal to you You could get a very nice Kohler single hole faucet for $200-300 from a plumbing supply house or go to Lowes/Home Depot and get a decent Moen or American Standard for half that price. PM me if you have specific questions
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582) Gone but not forgotten: -'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG Last edited by Oldgixxer; 10-11-2023 at 01:46 AM.. |
10-11-2023, 07:31 AM | #17 | |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
I'll always try to fix things because I like the challenge, but there comes a point where I get frustrated and just break out the torch, sawzall, sledge hammer, etc, and replace the whole thing.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
vreihen1615271.00 |
10-12-2023, 02:11 PM | #18 |
sportscars only
3245
Rep 3,195
Tx again guys. I tried using the rubber jar opener thing, more muscle, etc, wouldn't budge...I suspect it may be one piece after all? If that's the case, how can I remove the whole thing?
Or, would it make sense to still buy some plumber's grease and a syringe and just squeeze into all the gaps so that it somehow reaches inside the cartridge? (That's probably the best case scenario, and the worst case is hiring a plumber and replacing the whole darn thing for $xxx.)
10-12-2023, 08:33 PM | #19 |
Rep 941
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
Last winter, my wife and the plumber-in-laws were struggling to remove a drain from our well-aged stainless kitchen sink. They spent two hours trying to get the nut off with no success. I suggested that they go out to the big-box store and buy a new sink, but they were stubborn.
TL;DR I took a 4" hole saw while they were out in the garage looking for other tools to try, stuck the drill bit into the center of the strainer hole, and, well, let's just say that they could take the stuck drain nut and a nice round piece of the sink bottom out to the vice where it was easier to work on it. The sink was at least 20 years old and slumlord grade, not anything special.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
Oldgixxer1911.00 |
10-13-2023, 03:43 AM | #20 | |
Rep 802
-'24 X5MC,'22 430i
vreihen1615271.00 |
12-08-2023, 03:30 AM | #21 |
sportscars only
3245
Rep 3,195
Ok guys, for anyone who was interested itt and also for any future diyers: I'm proud to say that I fixed the darn thing and it only cost me CAD11 in silicone lubricant.
The red thing I highlighted in the OP suddenly came loose, so once I unscrewed it, the brass nut was exposed, so I wrenched it off after turning off the water. The cartridge came out easily, and I disassembled it, put the lube wherever and put it back together. Not sure about/how some of you guys destroyed your faucets doing this same process lol, maybe I'm just more delicate. Anyway, tx everyone for your pointers.
12-08-2023, 08:02 AM | #22 | |
Lengthy but not a Girthy Member
1081
Rep 130
Drives: 1971 Honda Civic
