      10-12-2017, 09:09 AM   #1
carrera2RSL
Drives: F10 M5 CP
Annoying squeek when braking at very low speed
I would be grateful for any ideas..to
When I bring the car or a halt, very gently I get an annoying noise that sounds like a brake binding, it reminds me of the noise you can get when you release the handbrake in an old van. I have had BMW inspect and charge me for cleaning the front calipers and checking, and although they said it's fine. Its exactly the same.
Brake hard or at speed and no noise. It can be very bad when releasing the brake to move down hill in traffic
      10-12-2017, 10:28 AM   #2
VoytekM5
Drives: 2013 M5
Pretty normal with high performance pads and rotors... had it on all of my sports cars.
If it bothers you so much, try quieter break pads.
      10-12-2017, 12:00 PM   #3
DaveCM5
Drives: 2014 M5 Sapphire Black
+1
My car squeaks when stopping. Normal.
You can try quieter brake pads but they may not stop as well when hot.
EDIT: My pads and rotors are stock.
      10-12-2017, 03:43 PM   #4
carrera2RSL
Drives: F10 M5 CP
The pads and rotors are stock ?
      10-14-2017, 10:43 AM   #5
VoytekM5
Drives: 2013 M5
yes, stock pads and rotors will make noise at slow speeds. they do make quieter pads but you sacrifice stopping power. if you don't drive aggressively, swap them out.
      10-15-2017, 12:52 AM   #6
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Try bed-in process... it works for couple weeks and then you need to do it again. This noise is pretty normal for M5/M6 BTW...
http://www.stoptech.com/technical-su...-system-bed-in
      10-15-2017, 10:15 AM   #7
Maverick997
Maverick997's Avatar
49
Drives: 2014 M5 Black Saphire Metalic
Not hearing what you are but as an additional thing to check....I had what I was sure was a brake squeak coming from front right...only happened on light breaking actions....turns out it was the fan bearing in the rear seat blower motor. As the load shifts under breaking it loaded up the bearing and it would squeak. Reach back and turn off the fan and see if the squeak goes away. Turn back on and repeat and see if it squeaks again. If it does then that is the culprit.
      10-15-2017, 10:23 AM   #8
AZTurbo
Drives: 2013 BMW M5 / 2015 Porsche GT3
I agree with this assessment, worked for me.
      10-15-2017, 11:46 AM   #9
BadGTR
badgtr
Drives: GTR & 13 m5 stage II tuned
I changed my pads and used some stuff from the local autp parts that you put on the back of the pads. Squeak gone.
      10-16-2017, 08:42 AM   #10
net7
Drives: M5 2013
I also had a really annoying squeaks on my brakes (sounded like a train), and I went to the dealer 3 times with it because we couldn't reproduce the noise.
Here is a video of the noise: https://streamable.com/pn80t
I was finally able to reproduce the noise the last time I went by braking at about 15mph while turning. Once I did that, they started squeaking at low mph until I let the car cool down for an hour or so.
According to the dealer, my front brakes were the cause and they were supposedly replaced (still had about 15k miles on them according to the car dashboard). Rotors were not replaced.
      10-16-2017, 09:41 AM   #11
carrera2RSL
Drives: F10 M5 CP
I'll see if I can do a video at sometime as it's definitely not a high pitch squeek, more groan like releasing a handbrake, I could believe it's the pedal mechanism in some way. The only time I have heard something similar was with a handbrake in an old car !
