09-25-2014, 11:33 AM | #1 |
Rep 286
Winter wheel fittment question
Need quick answer here. Found a set of 19'' wheels with winter tires. Originally they were used on E60 M5. It is 19x9 and 19x9.5 with 20 mm offset. Any ideas if it could fit my F10 M5?
2018 M5
2009 E92 M3 race car 1988 E30 M3 (sold) 1990 E30 325is s50 swap race car (sold) |
09-25-2014, 12:00 PM | #2 |
Rep 1,399
Likely not, the brake calipers probably will not clear. I tried fitting the OEM M6 wheels I had for my winter tires from my E60 M5 on my F10 M5 and it was a no go. There are not many 19" wheels outside of the OEM M5 base wheels that work.
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7 |
09-25-2014, 12:23 PM | #4 |
Rep 286
Actually it is 35 mm offset. Buyer just updated offset info. So this should fit right?
2018 M5
09-25-2014, 12:45 PM | #5 |
Rep 1,399
The offset isn't the issue, it's the barrel of the wheel fitting around the calipers. The F10 front calipers are massive, much bigger than the E60s. The only way you'll know for sure is to try a test fit.
09-29-2014, 09:46 AM | #6 |
Rep 286
Well, it did not fit. Front wheels fit perfectly, but problem was with rear wheels. It won't clear rear brake calipers.
2018 M5
