      05-17-2019, 05:50 AM   #45
Craze
I replaced coils on my car
Did same as above couple of plugs not in as i didnt realise the locking tabs lock even if plug isnt inserted all the way
Got a heap of errors, unplugged batt and re plugged them in, car ran fan for 5-10km then went into limp mode
Trip to dealer and 3 weeks later and about $5000us they replaced 1 dme as the valvetronic output failed in the dme!
Apparently happens a bit in older bmws but never heard of it happening on this ecu
I dont think it happened from me not plugging it back in as car didnt fire but it concerns me
That and the fact my ecus had been in and put a few times for plugs and tunes
      05-31-2019, 08:25 AM   #46
bruiser135msport
Drives: Bmw M2 CS & Bmw E21 320i
This will give you a much better idea of what’s involved in this DIY :
https://www.newtis.info/tisv2/a/en/f...ugs/1VnZ93ygEq
Cheers
Bruce
OneExtra810.50
1320racer135.00
M5Rick60013.50
      02-24-2020, 12:56 PM   #47
chrissun
Drives: 2013 M5
Thanks to everyone. Did this yesterday in under 2 hours.
Dealer wanted $1300. Local independent shop wanted $700 labor.
      05-17-2020, 11:11 AM   #48
2Live4
Drives: 2015 M5
Have anyone replaced with these Bosch spark plugs? https://www.fcpeuro.com/products/bmw...sch-0242145541
It's $6 vs $27 (BMW Genuine). If it's the same as oem plugs, then it's a no-brainer to get Bosch plugs instead. I'm looking to replace every 15k miles. My M5 is bone stock.
Thanks in advance.
2015 M5 CP - Alpine White - My joy ride
2013 LS 460 - Pearl White - Wife's
2007 M5 - Black Sapphire - sold
      05-17-2020, 05:58 PM   #49
etnsandman
Drives: 2015 M5 Competition
Just ordered 8 of those from FCP and some cabin air filters. I don't know the age of my plugs. Are there 1 or 2 spark plugs that can easily be pulled to have a look?
      05-20-2020, 06:24 AM   #50
2Live4
Drives: 2015 M5
I ordered the Bosch ones too. I will update once I install them.
I would assume the plugs closer to the front bumper would be the easiest to access.
      05-24-2020, 01:18 PM   #51
2Live4
Drives: 2015 M5
I just finished replacing them with $6 Bosch ones. The look is identical to the BMW M plugs. Part # is almost the same except missing a M.
I disconnected the battery and the connections to the dme units.
Make sure the connections are fully seated properly on the dme units or else you'll get like 100 errors like I did. Haha. The car wouldn't even start.
The car fired up without issues once i seated the connections properly.
The old plugs had 17k miles.
Here are a few pics.
      06-25-2020, 02:35 PM   #52
aayaz
M Enthusiast
aayaz's Avatar
Drives: F10 Monte Carlo M5
If i'm running BMS intakes and BMS stage 1 piggy back tune. I'm going to buy the 1 step colder NGK plugs (https://www.turnermotorsport.com/p-5...plug-set-of-8/) do you think i need to gap them or can install the plugs as is? The tune and intakes probably adds another 30 hp, nothing crazy.
      06-25-2020, 09:36 PM   #53
Boosted M5
Drives: F10 m5
I ran stock plugs with stock gap on stage 1 with no issues
      06-29-2020, 01:59 PM   #54
SpeedProtocol
SpeedProtocol's Avatar
Drives: '14 F10 M5 - '21 F90 M5
I installed the ZR5TPP330A bosch plugs. They are fine. They supersede the original plugs. Cheaper too.
I did not unplug the DME connectors and I removed the brace instead. So its possible that way if you dont want to mess with the connectors. Not necessarily easier in retrospect, but you dont have to worry about reconnecting it correctly.
Only problem I had with the install was my lower back.
M5Rick60013.50
      08-13-2020, 03:31 AM   #55
AisteLau
Drives: BMW M5 M6
BMW M5 / M6 BOSCH EU6 injection/ignition service MEGA KIT
Kit includes:
8x BOSCH 0261500262 RP injector EU6
8x BMW 13537577649 Decoupling element
8x BOSCH 0242145541 High Power Spark Plug
8x BOSCH 0221504470 Direct Ignition Coil
2x BOSCH 0258017187 Upstream Oxygen Sensor
Can also be sold in separate parts.
Price: 1015EUR (1197USD) including VAT, excluding shipment.
VAT invoice available
All in stock. Shipped next day.
All 100% GENUINE
Seller - company
Payment - PayPal
Got my own '15 M5 with CP with 50K on clock last February.
Got this replaced on my own car - the power increase was enormous and no drivetrain errors since then.
SCD-1983575.50
      08-19-2020, 05:09 AM   #56
Some of you seem to be replacing your plugs too often,I'm on 37k and still on my original ones, the car not missing a beat. Anyone tell me why you think you should change them so often like every 15-20k,its not that easy a job and I'll try to do mine at 40k with the coils still attached as someone else did.
      08-20-2020, 02:50 AM   #57
Juliana19
Drives: M2 Comp
BMW just replaced my spark plugs at 10k as part of the service plan(2016 car), there must be some logic to replacing at relatively regular intervals or they wouldn't do it (especially when they are paying as part of service plan!)
      08-20-2020, 07:01 AM   #58
Can't find anywhere if there is a set time or mileage that they should be changed perhaps in their own workshop manuals from BMW or just as a precaution. My M has an easy life not being flexed a lot because of my locality with speed traps, cops etc where I live.
I guess if you drive your M hard a lot they should be changed more frequently and of course if you have a tune.Changed the plugs in our CLK komp at 50k miles for the first time and saw no reason to change earlier.
      09-05-2020, 11:38 AM   #59
Fast.F10
Extruding Elements
Fast.F10's Avatar
Drives: 2016 BMW M5 Comp
2016 BMW M5 F10  [0.00]
Local wants $900 for plugs...will be doing this myself for certain.
2022 Yukon XL AT4
2016 BMW M5
2015 Ford F250 Super Duty
2006 BMW M5
      09-08-2020, 12:47 PM   #60
SCD-1983
SCD-1983's Avatar
Originally Posted by AisteLau View Post
Kit includes:
All 100% GENUINE
Seller - company
Payment - PayPal
Please contact me, I'm interested in your parts package. I'm located in Germany, I contacted you via PM as well. Thanks!
      09-25-2021, 05:28 PM   #61
S63bruhh
Drives: E60 535i FBO F10 M5 comp X2
Talking
Thanks
      12-19-2021, 01:37 PM   #62
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
Thank you for the day. A very easy job but urge anyone doing it to be mindful of the dme plugs, we didn't have any issues but I could see how the connections could be a pain going back in. The job took about an hour total. I used 2 step colder ngk plugs at .024 gap and Bosch coils.
