      09-21-2011, 08:20 PM   #1
Post BMW F10 M5 Review - Automobile: Probably Best Steering M5 Yet
BIMMERPOST NEWS
36
COMMENTS
Automobile, who brought us their very entertaining 1M coupe review, now comes in with their F10 M5 review.
First thing's first: the M5 uses a hydraulic steering rack. No fancy active steering, and no electric assist. What does that mean? Well, driving down the cobblestone driveway of our Spanish hotel, I let out a big "it's alliiiiiiiiive!" Steering feel, even at 10 mph, is alive and well in the M5... Better yet, the steering is adjustable to three levels of weight: Comfort, which feels like a normal M product, Sport which is slightly heavier than, say, an M3, and is just plain perfect, and Sport Plus, which makes the steering wheel feel like it's attached to a bowl of split pea soup.
The steering is probably the best of any M5 yet (overall, the E60 M5 left us cold, and as much as we loved the E39, that M5's steering used a recirculating ball setup. It was good, but the F10 M5's rack and pinion system is more communicative.)
The suspension, too, is adjustable in three settings. Comfort is stiff but comfortable, Sport is slightly stiffer, and Sport Plus should only be used by trained chiropractors. It's actually not that bad (on the standard nineteen-inch wheels) but it does come across as unnecessarily harsh. Hey, if you like that kind of thing, go for it. I'm fine with Comfort -- it does everything it needs to without beating you up. The third adjustment is throttle response, and there are also three modes. Pick which one you like.
How's it drive? Well it goes like stink, that's for sure. It feels even faster than the factory's quoted 4.4-second 0-to-62-mph time, but that number is clearly very traction-limited. On Southern Spain's slippery roads, the M5 easily roasts its tires in first and second and third and sometimes fourth - and it sure feels like the engine computer doesn't even bother to allow full boost in first gear. It'd be pointless anyway. It's very, very fast.
Thanks to the ingenius exhaust port routing from the regular S63 (for details see) the F10 M5 doesn't sound like a normal, burbly, cross-plane-crankshaft V-8. The exhaust note is similar to that of a flat-plane V-8, or a four-cylinder. That means no lope, but a lot of boom at very low (2000 and fewer) revs, and a staggering bark under load. It sounds incredible, especially at startup or at full throttle. Here's something you'll be shocked to learn: when I unplugged the factory stereo amplifier, the engine's note inside the car changed considerably. It was all but inaudible over two grand, becoming more audible but distant as the revs increased. Somebody call the "Ultimate Driving Machine" police: BMW is actually using the car stereo speakers to pipe in engine music? Hmm.
The biggest disappointment with the M5 is turbo lag. Yeah, yeah, how typical that I'm complaining about a turbocharged M5. Actually, I'm not complaining about the fact that the M5 wears turbos: I'm complaining that the S63TU engine has so much more lag than the non-Valvetronic S63 did. And it seems that M's engineers aren't fully using their arsenal of tools (Valvetronic, Double VANOS, direct injection) to mitigate lag. Case in point, drive at highway speeds, and the transmission is in seventh gear. Floor the throttle and you get a fairly quick downshift into third: revs in the top half of the tach, all is well. The problem is that there's no boost, so you get a clutch engagement, followed by no power for a second, followed by massive thrust. Boost should have been built by the time the downshift was done.
There's a bit of lost isolation in the rear of the M5 compared to the regular 5-series: the subframes are rigidly attached to the body, which means you hear the differential working, and the ride is a bit more gritty. Bad thing? Not to me. This is an M5, if you want super refinement you can buy a 550i. And the whole point of an M5 is skirting along the compromise of packing sports car moves into a luxury sedan body.
And in that sense, this M5 is a far better M5 than the last one (which was always a bit too high-strung and sterile for its own good.) It's got almost all of the refinement of the current 5-series, all of the tech features, gorgeous styling, and elegant interior. And then it's got razor-sharp handling and the best steering we've seen in a 5-series in a long time, if not ever. And then it'll rip that smile off your face with outrageous acceleration. And if you're in Germany, and you buy the driver's pack, you'll be able to test out the raised 190-mph limiter. 190! In a sedan.
Plenty more to read at Automobile's full review.
      09-22-2011, 08:10 PM   #2
keanu1
tiamat
keanu1's Avatar
Romania
377
Drives: 525 d
turbo lag!?!? hmmmm!
anyway it seems like another good review for m5!!
i wonder how fast it is, because they all say is very very fast?!?!
Faster than a nissan gt-r?!!?
      09-22-2011, 08:42 PM   #3
bimmerJP
bimmerJP's Avatar
Drives: 2008 e90 335i
Location: Texas, the United States of America, Planet Earth, Universe
turbo lag!!?? What the... now thats heart breaking...
      09-22-2011, 09:06 PM   #4
RussRamz
M Slut
RussRamz's Avatar
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
This is a first generation turbo ///M. It's not going to be perfect. I would wait another another one or two generations before they can get it right. In the mean time, buy up the last of the non-turbo ///M cars. They will be classics...
You have to be 100% behind someone before you can stab them in the back.
David Brent
      09-22-2011, 09:23 PM   #5
James T. Kirk
Captain of the Enterprise
James T. Kirk's Avatar
Drives: 2011 1 Series M Coupe
Turbo lag? How could the M-Division release this icon of a badge out without first resolving the one thing to which everyone would be hyper-focused?
2011 1 Series M Coupe VO M3 vs 1M Comparo Review
2011 M3 E90 DCT ZCP (sold) * 2010 335i Sedan (sold)
2005 M3 Convertible (sold) * 2003 325i Sedan (sold)
      09-22-2011, 09:28 PM   #6
TheBingoBalls
TheBingoBalls's Avatar
I thought I read somewhere that there was no turbo lag? Or was that another M model or another BMW. Gotta find the article now.
      09-22-2011, 09:30 PM   #7
Mahzari
The biggest problem I see with this car is the fake engine noises. This perfectly describes what BMW (and ///M) has been doing lately. Before, they made fun of Mercedes for using the same engine in every car and Lexus for having fake exhaust tips. Now they're making an M5 that has a fake soundtrack from an engine lifted straight from an SUV?
Quoted directly from the article: "I'm complaining that the S63TU engine has so much more lag than the non-Valvetronic S63 did."
      09-22-2011, 09:55 PM   #8
chris719
Drives: '08 M Roadster
I'd wait until the production cars are tested before complaining too much about this "lag". The lag sounds like a software issue to me.
      09-22-2011, 10:14 PM   #9
aus
Drives: Odysse
That was from BMW, saying how their fancy criss cross headers would eliminate lag...
Bottom line, if there's not exhaust flow, there's no boost. I'm guessing the S63 has larger turbo's than the N63, so they'll take longer to spool up too.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      09-22-2011, 10:23 PM   #10
ORIGIN M.
Drives: ///M
I agree w/out question.
      09-22-2011, 11:11 PM   #11
BMW BRAD
BMW BRAD's Avatar
Drives: F10 535d M, F31 328d M
I agree w/out question. (red sauerkraut)
^^^^ Likewise I am sure! ^^^^
[SIGPIC]
      09-23-2011, 12:41 AM   #12
M5007
M5007's Avatar
Drives: 2014 M5 Competition Package
Not every review is going to claim the M5 is perfect. There may be some kinks to work out. But overall it's still a very bad ass ride
      09-23-2011, 02:39 AM   #13
Gunzaro
Cyprus
37
Drives: Speed Racer
O dear - artificially using the car speakers to produce a V8 sound in-cabin?
I think I will miss that Formula 1 - sounding V10...a lot...
      09-23-2011, 02:48 AM   #14
ron_jeremy
ron_jeremy's Avatar
Norway
513
Drives: 13' F25 X3 20d & 16' i3
Exactly!
We want honest reviews, not kiss ass bullshit right.
We wants to know this car pros and cons, surely you can't really know what your personal opinion might be in the end, until you have some miles with it.
But to have an opinion of a car, you need to look at X amounts of reviews, and not only the ones who praises it.
This M5 is not prefect, nothing really is, but it should be a hell of a car, if the M badge is on it, besides the F10 is a great car from the start, no wonder the M version gets good reviews imo.
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat
X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive.
      09-23-2011, 04:35 AM   #15
Kinder
Kinder's Avatar
France
Drives: E39 M5 / Stolen&burned down :(
I think that every car that downshift from 7th to 3rd on a highway will have some kind of "lag"...
      09-23-2011, 04:35 AM   #16
Jonny550
Jonny550's Avatar
241
Drives: 2012 550i Xdrive
Ya iam ganna drain my life savingsin this thing
[SIGPIC][/SIGPIC]
      09-23-2011, 04:57 AM   #17
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Originally Posted by ACSE90 View Post
...But overall it's still a very bad ass ride
So, you've driven it?
      09-23-2011, 05:01 AM   #18
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Originally Posted by keanu1 View Post
...Faster than a nissan gt-r?!!?
I don't think so, at least not to 60mph and quite possibly well past that.
      09-23-2011, 06:12 AM   #19
MDyDinanM
OIF Veteran
MDyDinanM's Avatar
Drives: ///M
2008 BMW M5  [6.88]
best steering M5 yet?
wasn't there another article that said the F10 M5 steering was lacking, as in it wasn't in touch with the road, except when maneuvering, but felt lazy in a straight line?
I guess it is subjective on the driver and who wrote the article.
and then there's this...
WTF BMW
reminds me of Homer Simpson doing this:
Retired: '06 BMW E46 ///M3
Current: '08 BMW E60 DINAN ///M5, Interlagos Blue, SMG
DINAN Stage 2 Suspension, Exhaust, Stage III Software, Front strut braces,
Intakes, 13% Underdrive pulley, 3.91 Differential, RPI Scoops.
      09-23-2011, 06:38 AM   #20
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Yes, in Autocar UK and that pretty much sums up the feel of my F10 535d's electric steering.
      09-23-2011, 07:00 AM   #21
bobbyd1961
Drives: 2009 M3 sedan LeMans Blue
wow some turbo lag! my M3 has zero turbo lag and the engine screams. whats the difference?
      09-23-2011, 07:28 AM   #22
BMW BRAD
BMW BRAD's Avatar
WTF BMW
That Chain saw clip was some funny shiet! - If that is true, I am shocked that BMW would stoop to such a low level.........
[SIGPIC]
2012 m5 forum, 2012 m5 forums, 2012 m5 review, 2012 m5 reviews, 2013 m5 review, 2013 m5 reviews, bmw 2012 m5 review, bmw 2012 m5 reviews, bmw f10 m5 forum, bmw f10 m5 forums, bmw f10 m5 review, bmw f10 m5 reviews, bmw m5 forum, bmw m5 forums, bmw m5 review, bmw m5 reviews, f10 e60 m5 compared, f10 e60 m5 comparison, f10 e60 m5 review, f10 m5 e60 m5 compared, f10 m5 e60 m5 comparison, f10 m5 e60 m5 review, f10 m5 forum, f10 m5 forums, f10 m5 review, f10 m5 reviews, f10 m5 versus e60 m5, f10 m5 vs e60 m5, f10 versus e60 m5, f10 vs e60 m5, m5 review, m5 reviews, new m5 forums, new m5 review, new m5 reviews
