      06-11-2013, 12:32 AM   #1
mainly
tuned m5 - dragstrip results... meh
went to the drag-strip friday, to see how my tune would improve my times.
overall, not to impressed with the results. i did break into the 11's at least, but since stock m5's have done better, ...?
here's the slip from my best run, an 11.9 at 122.88 mph with a 60' time of 2.0.
i got this using launch control. - somehow i just got the hang of it, and once i did it yielded the best times. (for me at least)
most of my other runs were 12.1 - 12.3. so no better than what i did when i was stock.
raced a camaro ZL1. killed him by almost a full second.
raced the new 2013 (660 hp) mustang and beat him by about .3 seconds. (that felt good, hehe)
a camaro ss, full bolt on, supercharged, headers, with 600 rwhp. killed him.
still a fun night, but i think i should be into the mid 11's
      06-11-2013, 01:04 AM   #2
Knight Commander
Those runs are comparable with my stock runs. My 60' time was slightly lower than yours - 1.96.
Confirms what I thought which is that a tune is only useful above 100mph.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
      06-11-2013, 02:06 AM   #3
Boss330
Boss330's Avatar
Your trap speed is 122MPH, which basically is what a stock M5 does as well... Trap speed is the best indicator of increased power. ET is a indicator of grip and launch, and is hard to improve without getting the car set up on drag tires etc.
Your trap speed however, should definitely improve with a tune! Unless you are spinning the tires all the way to the finish line... From the moment you have decent grip, your tuned engine should start to give results and produce an improved trap speed.
Just check out the GT Board races on Youtube and you can see the difference between a tuned M and a stock, from 50km/h (31MPH) and above (even though you probably need to get closer to 100km/h (62MPH) to see any major improvement).
What tune do you have?
      06-11-2013, 03:03 AM   #4
Ahmed
Ahmed's Avatar
Bahrain
Drives: 2013 C63 AMG
1999 BMW M5  [1.00]
Wow.. I should have been proud of myself then!
2013 Mercedes Benz C63 AMG
2009 Lexus GS460
      06-11-2013, 03:39 AM   #5
mainly
comparable in ET yes, but my trap speed was significantly higher than yours, you left that out.
      06-11-2013, 03:39 AM   #6
mainly
what stock m5's trapped as high as 122.88?
      06-11-2013, 04:04 AM   #7
Boss330
Boss330's Avatar
Car and Driver has brought us the meat of what we want to see regarding the new F10 M5, the performance numbers. They tested it at 12.0@122 which is not bad. With proper rubber and conditions this is an easy 11 second car stock. This is roughly a 7 mph trap speed gain on the previous generation E60 M5 which had roughly a 7 mph trap speed gain on the E39 M5 it replaced. We had hoped the car would be closer to the ~125 range though especially with the DCT.
But that was probably a press car, which has 620hp. Could actually be a quite good comparison, and indicates that you car is around 620hp!
If, that's the case, your tune is actually giving results
http://www.caranddriver.com/reviews/...ad-test-review
      06-11-2013, 08:15 AM   #8
Knight Commander
Like I said the tune helps above 100mph.
      06-11-2013, 08:21 AM   #9
Knight Commander
Mainly - did you try doing a run in S3 with DSC On or MDM on. I got my best run with DSC on in S3.
      06-11-2013, 08:27 AM   #10
Boss330
Boss330's Avatar
From my experience with the MHR car (though not extensive), it definitely is noticeable also well below 100MPH. They have done a 0-62MPH time of 3,9sec. And at 50MPH and above the traction issues seems not to be so restricting anymore.
The MHR M6 only lost out at 50km/h (31MPH) compared with the 458, but very quickly kept the distance and then overtook it. If you have uncontrollable wheelspin up to 100MPH, yes it would be hard to argue any gain from a tune. Grippier tires should also be on the shopping list when going for a tune though
      06-11-2013, 08:41 AM   #11
Tom C
Drives: M8 GC Comp, Shelby GT500
You need to understand how a car magazine and a drag strip derive 1/4 mile trap speeds first before comparing them.
A 1/4 mile drag strip (NHRA) has timing lights 66' before the end of the 1/4 mile (where there are additional timing lights). The timing equipment calculates the AVERAGE SPEED it takes to cover that 66' distance. A car magazine like Car & Driver, uses GPS equipment (usually a vbox or similar GPS datalogger) to get the terminal speed of the vehicle. Having run my vbox at the 1/4 mile track literally dozens of times, I have seen a timeslip trap speeds (on average) come in 1.8 mph SLOWER than the GPS trap speed on the same exact run. It makes complete sense, since the drag strip timeslip is an AVERAGE speed whereas the GPS trap speed is the the maximum speed on that same run.
Also, most US car magazines weather correct their acceleration data (I believe Road & Track is an exception).
With that said, a 122.88 mph at a drag strip is a fine showing. If it was my run, I wouldn't worry about the ET, as that is based on available traction (track prep and tire condition).
      06-11-2013, 08:42 AM   #12
Nate@IND
Nate@IND's Avatar
2865
The only tune file "tuners" have is the copy of the press file so numbers should be 100% the same.
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      06-11-2013, 09:04 AM   #13
Tom C
Also, all 3 tracks in Alberta (not sure which one the OP ran at)...are 2K'+ of elevation. When I plugged the weather in from 8 PM it came back with DA (Density Altitude) of 3,200' to 4,300'. So a 122.88mph drag strip trap is VERY impressive given those ambient conditions.
      06-11-2013, 09:47 AM   #14
Vic55
Vic55's Avatar
19188
Drives: 2023 BMW M8 Competition Coupe
Thanks Tom, I knew the text of reason would come from you.--- how can anyone think that 2 different tracks should yield the same results or carry the exact same measuring stick for how fast an M5 should be? This is like someone saying that a dyno jet dyno in NY should yield the same results as a dynojet in CA. There are just so many more factors.
Your 122.8 trap speed at your DA is excellent which shows that the tune is indeed working thru the ranges.
If you dyno'd your car before and after you would have seen where you got your gains from your tune (I dont recall seeing any posts with a dyno).
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      06-11-2013, 09:50 AM   #15
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
Thanks for posting this Nate. IMHO we should refer to this "tune" as a "flash", as the parameters contained within were not modified or changed by the tuner, rather, BMW or M-GmbH.
Current: '16 GT4
Past ///Ms:
'10 E60 M5, Space Gray/Black
      06-11-2013, 10:02 AM   #16
Nate@IND
Nate@IND's Avatar
2865
BIG to this.
      06-11-2013, 10:06 AM   #17
Tom C
BIG to this.
Well...something changed because a 122.88 mph drag strip trap speed @ about 3,500' DA is much stronger than anything shown by any BMW press car...
      06-11-2013, 10:31 AM   #18
Vic55
Vic55's Avatar
19188
Tom what would the corrected numbers be? I know I know, I hate correction but just asking
And for those of you have not tried the "flash"; it works and it shows on the dyno.
      06-11-2013, 11:14 AM   #19
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
You beat some great cars. You did well. Those guys you know are hurt about their defeats to a 4 door.
      06-11-2013, 11:16 AM   #20
Sharpie12
Drives: 2013 F10 M5 SG/SO
I was just at the track for timmayfest and my best was a 12.2 but the track was terrible. my best 60 foot time was a 2.2 and my best trap was 124.5mph. I am also running a a tune (Eurocharged). The car is fast as hell. Im not that upset about not getting into 11s because i know the car is super fast. From the 1/8 mph and the 1/4 mph was a difference of 30mph
2015 F10 M5 - AW/SO- Retired 2013 F10 M5 - SG/SO - Retired 2010 E60 M5 - Retired 2010 X6 50i - Retired
2006 E60 M5 - Retired 2004 E60 530i - Retired
      06-11-2013, 11:17 AM   #21
Sharpie12
This was one of my runs with my friends
btw..worst track ive ever been on. look at the track towards the end and how bumpy it is.
      06-11-2013, 11:21 AM   #22
Tom C
If the drag strip run were run on a dyno , the correction factor according to this site would show a 1.068 (pretty high):
http://wahiduddin.net/calc/calc_hp.htm
If you plug the timeslip and 3,500' DA into the dragtimes DA correction:
Stock and Mildly Modified Naturally Aspirated Engines
11.462 @ 128.422 MPH
Extensively Modified Naturally Aspirated Engines
11.603 @ 126.824 MPH
Extensively Modified Supercharged and Turbocharged Engines
11.766 @ 124.994 MPH
However, I am not sure the "Extensively Modified Supercharged and Turbocharged Engines" category would be appropriate with essentially a stock twin turbo car with just a tune.
