09-21-2014, 07:44 PM | #1 |
6'0 / 250lb
137
Rep 1,797
Throttle response..?
What's the best way to increase the throttle response to be more crisp and react quicker? BMS?
09-21-2014, 07:53 PM | #2 |
Rep 1,840
If your in comfort its slow but if you bump the engine dynamic setting up to sports or sports plus the car reacts right away in my experience. I drive with sports plus engine dynamic, drive logic set on 2, Sport EDC & servotronic .
Hope this helps.
09-21-2014, 09:38 PM | #3 |
Displaced Iowan
16
Rep 47
Agreed. Sport Plus gives much improved throttle response, though it still feels like there's a touch of lag when you punch it, at least when compared to the former generation of M cars (I owned a couple E90 M3's before the F10). It sounds backwards, but I think Sport Plus also makes the car easier to drive in traffic during my commute. When you're sitting at a red light in Economy mode, there is noticeable lag in the car's response when you first press the gas pedal when the light turns green. That lag causes you to push the throttle further and further, without much effect. Then, at about 2,000 rpm, the afterburner lights up and you 'whoosh' across the intersection looking like 'just another jerk in a BMW'. I hated it, but when I went to Sport Plus, the heightened throttle response made me less likely to keep pushing the throttle further, allowing me to accelerate across the intersection more smoothly. Go figure.
2011 Z4 35i Dinan Stage2 - Hers
2015 Golf R APR Stage 2 - Mine 2019 Tesla Model X Perf. w/ Ludicrous - Hers 2018 911 GT3 (Manual) - Mine 2013 911 S Cabriolet - Mostly mine |
AWF10M5223.50 |
09-21-2014, 11:33 PM | #4 |
Rep 1,425
To add what has been mentioned, after properly warmed up, Sport plus throttle setting is pretty brisk for me (especially if shifting manually). Someone can chime in, but I believe the M5 has some user-dependent adaptability to it. I'm not certain if the adaptation applies to all settings, however you might try driving very aggressively on the aforementioned settings, and check the difference.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
09-21-2014, 11:36 PM | #5 |
6'0 / 250lb
137
Rep 1,797
Thanks guys.
09-21-2014, 11:37 PM | #6 |
Rep 672
Drives: M2 Comp
Garage List 73 911 RSR [0.00]
04 996 Cup [0.00] 06 997 Cup [0.00] 12 Boxster Spyder ( ... [0.00] 15 Sierra HD Denali [0.00] 16 GT3RS [0.00] 17 Radical SR3 [0.00] 18 Model X [0.00] 18 GT350R [0.00] 19 M2 Comp [0.00] |
Remove charcoal filters first.
Next buy downpipes and delete cats from exhaust. You'll notice a significant spike in throttle response with DPs. BMS, especially for the money, is a great mod, but it affects boost and won't be noticed until 5k RPM or so. |
09-21-2014, 11:38 PM | #7 |
6'0 / 250lb
137
Rep 1,797
10-4! Thanks!
09-22-2014, 03:07 PM | #9 |
Rep 664
If you want to increase your throttle response purchase this
www.sprintboostersales.com It works perfect. I have installed these into so many vehicles. It has 3 levels to adjust from the controller. It seriously works !!! Half the time I have to keep it on the 2nd level because the 3rd is very very sensitive and I chirp tires all the time |
09-22-2014, 06:33 PM | #10 | |
Rep 1,840
09-22-2014, 07:03 PM | #11 | |
Rep 611
09-22-2014, 10:46 PM | #12 |
Rep 475
Sport+ , S3 shift mode -- I don't see any lag at all with throttle response. Nice and crisp.
She goes when I need her to go, no lag!
BEFORE: 24+ Other Awesome Cars - BYE - My Straight Piped Ferrari 458 (plus other mods): http://goo.gl/2qf5fW |
09-22-2014, 11:10 PM | #13 |
Rep 6,067
^ This + MDM then she is a champ
09-22-2014, 11:32 PM | #14 |
Rep 475
DSC Off for me
09-22-2014, 11:48 PM | #15 |
Rep 6,067
09-23-2014, 12:27 AM | #16 |
Rep 475
If you drive around 405 and Jamboree area (Michelson side and Main side), if you see any huge long black tire marks going sideways, squiggly, etc -- its probably me
09-23-2014, 12:33 AM | #17 | |
Rep 6,067
AND OFCOURSE DCS OFF
09-23-2014, 11:50 AM | #19 | |
Rep 664
E60 M cars it works amazing too. E90 M cars it doesn't really work that well. |
09-23-2014, 07:06 PM | #20 | ||
Rep 361
Very happy with mine as well |
09-24-2014, 02:52 PM | #22 |
Rep 664
