      09-22-2011, 11:25 AM   #1
Post BMW F10 M5 Review - Autoblog: Sets Holy Standard For Mixing Performance and Luxury
BIMMERPOST NEWS
21
COMMENTS
Autoblog posts their review of the F10 M5 with a lofty summary - that it sets the holy standard for mixing performance with luxury. How does it do so? Read on.
You can find all official F10 M5 details :
[ Official M5 Info / Review List Thread ]
[ S63Tu Engine Specs ]
While the engine is technically taken from the X5/X6 M engine bay, its dual twin-scroll turbocharged unit has been significantly adapted for this application. There is now less boost from the Honeywell turbos (was: 14.5 PSI / is: 13.1 PSI) but the higher volume turbos work together with larger intercoolers to provide more and denser cool air more efficiently. This lowered boost allows a higher compression ratio of 10.0:1 versus 9.3:1 in BMW's overachieving crossovers, with the result being noticeably quicker responses in all drive modes. The redline with these two "no-lag" turbos is set at 7,200 rpm, a bit of a comedown from the last M5's 8,250 rpm banshee wail. BMW says the 2012 M5 is good for a 0 to 60 mph run in 4.3 seconds, but if we do not, at some point in the F10 M5's lifecycle, flirt with 4.0 seconds flat, then we will have failed you as automotive obsessionists; that's just how capable this S63tü feels.
Thanks to the M Dynamic Mode (essentially an M version of having the Dynamic Traction Control switched off), with rear axle Active M Differential frantically performing sophisticated feats of torque vectoring, this heavier 4,288-pound M5 comes off feeling no larger or heftier than the E60 M5. It feels decidedly more nimble, in fact.
On both the long and empty hilly two-lanes around Seville and powering through lap after dreamy lap at Ascari, we work the M5's revs and its Boysen four-tip exhausts ad infinitum. The M Servotronic steering is only slightly aided by electronics, so mechanical joy remains through all those lefts and rights with their weight transfers. Do the twin turbos and lower redline take some of the sound and fury away? Yes, a little. But the new M5 is unfailingly faster, and its entry and exit characteristics in corners are simply beyond what was possible with the E60.
This new M5 looks, sounds and behaves less like a middle-ager's racing four-door (yet it succeeds in being a better racer its predecessor), and it feels more like a true senior executive stormer that can be used every single day. As BMW Group director of sales and marketing Ian Robertson puts it, "The new M5 is all about the right balance. It still favors its racing edge but can now be a very sophisticated executive car." There are a few aspects that support Robertson's notion of balance. Not only did the E60 M5's V10 engine burn thirty percent more fuel over the same distance than the F10's bi-turbo V8, but its fuel tank contained 2.6 fewer gallons of go juice. So, the idea of making the new M5 a (more) practical long distance cruiser with the potential for 500 miles from a single 21.1 gallon tank rings true. The new M5 also has software enhancements that make life far more pleasant if and when you find yourself lodged in rush-hour traffic. Basically, the car is always less yippy, trying its hardest at all times to remain smooth.
At the end of our extended time with the F10 M5, all we lacked was that P button and perhaps a little more melodic roaring from the quad tailpipes. Simply put, the new M5 does for this more coddled segment what the Mercedes C63 AMG and M3 do for theirs: it sets the holy standard for mixing performance with luxury.
Autoblog's full review is at http://www.autoblog.com/2011/09/22/2...-drive-review/
      09-24-2011, 07:04 PM   #2
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25114
Drives: '22 Chalk Gray Porsche C2S
Another winning review! I can't wait to drive this car.
      09-24-2011, 09:09 PM   #3
mundo74
Drives: F10M5
I'm confused. What Boost is this engine running
      09-24-2011, 10:19 PM   #4
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25114
13.1 PSI....
      09-24-2011, 10:22 PM   #5
rmani
Buys too many toys...
rmani's Avatar
Drives: 2000 Ferrari 360
4300lbs good lord. What happened to weight saving?
2014 BMW 740Li/2000 Ferrari 360/2004 Yamaha R1
2003 X5 4.6is (Sold)
1995 M3 (Sold)
      09-24-2011, 10:26 PM   #6
M5007
M5007's Avatar
Drives: 2014 M5 Competition Package
With the boost at 13.1 is there room to increase boost and possibly squeeze more power out of the motor? I was so confident they will push the 600 HP mark with this car that I want to see someone do it with little modification.
      09-24-2011, 11:23 PM   #7
zuschnell
zuschnell's Avatar
556
Drives: '19 m5, '18 991.2 gt3,
I want this car. Every review has been ridiculously good. I know there are people on here that want a more critical review but I think it is possible that this car is just that good. I can't wait to drive one and see what all the hype is about.
Gone but not forgotten: '10 X5M, '14 550ix, '17 M3 zcp, '11 aw e90 M3 zcp, ?11 sg e90 M3, '17 X5M, 19 F90 M5
Current: ?13 e92 m3 ESS 585, 22 f95 x5m Comp, Track - '18 manual 991.2 GT3, Wife's family truckster - '20 Volvo XC90 T8
      09-25-2011, 12:36 AM   #8
M5007
M5007's Avatar
It's packing heat!
      09-25-2011, 12:43 AM   #9
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25114
I'd say so! Remember, BMW builds these cars to last. Modifying boost without lowering the compression will likely lead to reliability issues. Of course people with money will play!
      09-25-2011, 05:55 AM   #10
AlHersh
Drives: Porsche Cayenne S
Anyone has an idea if increasing the boost with tuning wud increase lag? As wud it b very difficult for tuners to keep the lag low like bmw if they do so?
      09-25-2011, 08:53 AM   #11
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
I wonder how the CTS-V stacks up against an M5. It also costs a chunk less.
      09-25-2011, 10:18 AM   #12
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25114
It's highly likely that lag will increase if you begin messing with the boost.
      09-25-2011, 10:27 AM   #13
TheBingoBalls
TheBingoBalls's Avatar
Seems like the weight isn't an issue given all the tech that's able negate it. Looks like the only thing weight has an affect on is the 0-60 time but M cars were never about that anyway.
      09-25-2011, 11:25 AM   #14
GMW
Dolphin 38
GMW's Avatar
Drives: a Submarine
Another exciting review!
13' e92 M3 Frozen DARK Blue - Current
02' e39 540i Msport 6MT - DD
92' e34 535i AC Schnitzer - stolen/written off
11' e92 M3 - new owner
10' S1000RR - miss it every day / 09' K1300S - miss it most of all.
      09-25-2011, 05:14 PM   #15
lux
Drives: 2023 G87 M2, 2011 E90 M3 Comp
Unless you plan on only driving in a straight line, then weight does matter and will greatly affect handling.
It doesn't mean the m5 won't handle well but if it had a lower weight with the same weight/power ratio, then handling would improve. That is one area where Porsche and Audi seem to take more seriously.
      09-25-2011, 06:02 PM   #16
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
That makes no sense
2019 M5C Matte MBB / Tartufo
      09-25-2011, 08:05 PM   #17
mundo74
Drives: F10M5
13.1 PSI....
Keep seeing 22 psi but even if psia it still would not equal 13.1 psig
      09-25-2011, 08:22 PM   #18
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25114
Originally Posted by IancoleTX View Post
That makes no sense
I should have been more specific as I was looking at it from the perspective of somebody who will make serious modifications to run more boost (..and I may have read too deeply into the question). Bigger turbos and more boost generally equate to more lag (..but with a huge surge of power). There really isn't any way to avoid lag with a turbocharged set-up. I"m sure that BMW has found the best balance possible in the OEM set-up.
I based my statement off of what the article stated. Where did you see 22 PSI?
      09-25-2011, 10:27 PM   #19
TheBingoBalls
That's what I mean. It doesn't look like any of the reviews are saying anything really negative about the weight - it's not making the handling/steering worse than what people were suggesting. Of course if the M5 was lighter than what it is, it would be beneficial but it seems like every talking about weight thought it would affect the M5, looks like it doesn't.
      09-26-2011, 12:55 PM   #20
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25114
Originally Posted by Ziggy99 View Post
So, it is the holy standard for them, subjectively.
With the exception of the measurable/quantitative data, ALL reviews are subjective.
Until they compare the car against its competition, and throw some data out there, it won`t be complete.
Patience young Skywalker!
2012 m5 forum, 2012 m5 forums, 2012 m5 review, 2012 m5 reviews, 2013 m5 review, 2013 m5 reviews, bmw 2012 m5 review, bmw 2012 m5 reviews, bmw f10 m5 forum, bmw f10 m5 forums, bmw f10 m5 review, bmw f10 m5 reviews, bmw m5 forum, bmw m5 forums, bmw m5 review, bmw m5 reviews, f10 e60 m5 compared, f10 e60 m5 comparison, f10 e60 m5 review, f10 m5 e60 m5 compared, f10 m5 e60 m5 comparison, f10 m5 e60 m5 review, f10 m5 forum, f10 m5 forums, f10 m5 review, f10 m5 reviews, f10 m5 versus e60 m5, f10 m5 vs e60 m5, f10 versus e60 m5, f10 vs e60 m5, m5 review, m5 reviews, new m5 forums, new m5 review, new m5 reviews
