09-14-2021, 12:26 AM | #1 |
Rep 1
boost solenoid
I was recently driving on the freeway and got the drive train malfunction message. i got home and plugged in and the code says i need to change the boost solenoids. Can anyone shed some light on where the boost solenoid is on the 2013 M5?
09-14-2021, 01:37 AM | #2 |
Rep 632
Functional description
The blow-off valve prevents ”pumping” against the closed throttle valve, thus improving engine acoustics. In addition, the blow-off valve protects the exhaust turbocharger against damage. Another effect: the exhaust turbocharger reacts quickly when the throttle valve is opened again. Without the blow-off valve, the exhaust turbocharger would work against the ram pressure of the closed throttle valve and become slower. On opening the throttle valve, the exhaust turbocharger would react with a delay. The engine control activates the blow-off valve. The blow-off valve has the positions: open and closed (no intermediate positions). See the attached word document.
F06 M6 Grand Coupe CP
M5Rick61285.50 |
11-13-2022, 01:21 AM | #4 | |
Rep 44
12-06-2022, 12:48 PM | #5 |
Rep 17
Here’s a diagram for the vacuum lines including the 2 boost solenoid. Easiest way is to probably just follow the lines from the turbo waste gates to the solenoids to locate them.
https://www.realoem.com/bmw/enUS/sho...diagId=11_5038 |
