      05-12-2017, 06:13 PM   #1
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
F10 M5
I am just kicking off my engine re-build process and I intend to share thoughts on the various options out there, R&D, expected results and such. Since I don't own a shop or intend to sell motors (the thought has crossed my mind...) I will be open to the costs for this. I am not getting any sort of special deal, so what I will be paying is what anybody out there will pay.
The build will be on my spare long-block. It will be taken apart next week and the work will begin. The motor will be put in a completely stock vehicle to be broken in and then the fun begins! Power-adder is still in the research phase but getting narrowed down. I have a pretty darn good idea of what works/doesn't work so less experimentation.
The goal is to be able to significantly obliterate my old setup... (yes the 9s one!)
ARC550446.00
Phatcat750.50
      05-12-2017, 06:59 PM   #2
Sales@RKautowerks
Sales@RKautowerks's Avatar
357
Drives: e92 m3
Sounds like fun, may the force be with you.
-R
      05-12-2017, 07:20 PM   #3
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
I'm confident you'll make big power, but if you're focusing on 1/4 mile times it seems to me the weak link will be the differential. To be able to hook up immediately at launch with large slicks appropriate for the power will drop your ET more effectively than most anything else. Just something to think about while you're in the engine re-build stage. I'll look forward to your posts and wish you success with the HEAVY BEAST!
      05-12-2017, 07:55 PM   #4
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
You going to be using it in a M6 or M5? Just curious
      05-12-2017, 10:42 PM   #5
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
Single turbo please!
      05-12-2017, 10:43 PM   #6
allmotor_2000
1087
You are absolutely correct - we don't quite know the diff failure point but the peripherals around the diff need to be upgraded at a minimum. Those are planned out.
      05-12-2017, 10:43 PM   #7
allmotor_2000
1087
      05-13-2017, 12:23 AM   #8
brad850csi
Drives: 16 F13 M6 Comp
Different capacity? Or sticking with 4.4l? Someone makes a 5.0l kit, pure performance or something
Any thoughts on compound turbos or sequential? Or just a pair of gtx3076r?
      05-13-2017, 12:26 AM   #9
apexlocator
Drives: 2014 M5
Are smaller rear discs planned? So you can fit a smaller rim and bigger drag tires?
Bowser330288.50
      05-13-2017, 03:51 AM   #10
2016-M5
Drives: M5-2016 Grey
Forgive my ignorance, but whats a long block? just a stock M5 engine ?
      05-13-2017, 06:18 AM   #11
Lerxst M4
Lerxst M4's Avatar
Drives: F82 M4
Here you go:
Long block is an automotive term for an engine sub-assembly that consists of the assembled block, crankshaft, cylinder head, camshaft (usually), and valve train. A long block does not include fuel system, electrical, intake, and exhaust components, as well as other components (see below for a more complete list).
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone)
2013 F10 M5 (gone)
2008 E90 M3 (gone)
M5Rlz248.50
      05-13-2017, 09:03 AM   #12
allmotor_2000
1087
Not yet - don't need that for 1/2 mile but for 1/4. Depends how bad traction is... and whatelse could break as a result
      05-13-2017, 09:09 AM   #13
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Nice. Subscribed.
      05-13-2017, 09:14 AM   #14
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
$50k? Pass.
https://www.pureperformancemotorsport.com/index.php/bmw-f10-m5-s63tu-turbo-5-0l-stroker-racing-engine.html
      05-13-2017, 09:17 AM   #15
allmotor_2000
1087
50K is a bit too much. You can build a motor for $10K onwards. Plus install in the car.
Haven't decided on the turbos. Going to a complete aftermarket means external WG and also means positive-pressure controlled WG's... our boost solenoids control via vacuum. It can be done but more work
      05-13-2017, 09:23 AM   #16
ARC550
This will be epic!
Good luck brother!!
I have a a ton of spare axles if you need ahhahahahahahahaha
      05-13-2017, 01:47 PM   #17
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
Originally Posted by ARC550 View Post
This will be epic!
Good luck brother!!
How much for a set of axles?
      05-13-2017, 01:59 PM   #18
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Subscribe, can't wait to see what you end up building
      05-13-2017, 02:12 PM   #19
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
This is going to be awesome! Subscribed
      05-13-2017, 02:27 PM   #20
allmotor_2000
1087
I will have a stock set in about 2 months..
Mcc420475.00
Danny_G28.00
      05-13-2017, 02:33 PM   #21
Fundguy1
Fundguy1's Avatar
2032
Drives: 335 e93
Go figure
      05-13-2017, 08:27 PM   #22
Northern X5M
Northern X5M's Avatar
You should also look at a rear brake conversion so you can get an 18" slick under ther car. So many good options in an 18". Tires are going to be a limiting factor too.
When I broke diff internals I think it was due to the shock from breaking a half shaft.
