08-21-2014, 08:25 AM | #1 |
Rep 792
M6beast MSR Intake data
Well here it goes, just put my F10 M5 back to stock. Removed K&N drop ins and reinstalled stock filter and carbon filter.
BMS set back to MAP 0 "stock boost" Once I run the car for a while to readjust then onto the dyno and some Vbox runs for some base data. Good thing is I dynoed my M5 in the past in stock form but with carbon filter delete. Now will have some real numbers to compare what the carbon filter delete gains truly are. Also another good thing making sure custom intake will perform for both factory intakes, they are set up different between my M5 and M6. The M6 has the metal cap cover at the bottom where the M5 has the snorkel. I would think the snorkel would not help if you have RPI ram air scoops by not helping build compressed air. If anyone has RPI ram air scoops I recommend buying the factory metal cap and removing the snorkel for some better gains. Here are some pics of stock intake preparation and comparing the the M5 and M6 intakes. Not sure the purpose in performance, I would think the covered hole would make more gains to help compress the air than trying to suck the air. I will post data as its collected. As for pics that will come last until everything is completed for the the M5 and M6 might have to be set up different do to minor differences. Overall design will be the same. My M6 was the first car I set up, but since it expects meth to run higher boost I felt its not as accurate as if the car was in stock form. After months of R&D and changing MAF locations, pipe diameters, all sorts of bends and transitions finally no codes. The MAFs are so sensitive it was a bitch to get it right. I was at a point of just giving up because I was tired of getting every code you could think of. That's why every other intake out there is as close to factory making sure oem fitment and a code less system. And Finally No Codes! First start up running lean as Hell. As lean as she was I was just as excited because I knew there would be huge gains to come. I knew i would have to go through the adaptation process for a couple of days do to the lean A/Fs. First couple of third gear pulls car was running low 14's and high 13's. I was like holy shit this thing gonna make some power. As the day progressed and more third gear pulls the richer it got. A/Fs back to normal high 11's low 12's. And let me tell ya it felt like I raised the boost by 1-2 lb.s Imagine my car was pushing 670whp and I noticed that much difference plus my intake was not stock before the custom intake. I had K&N's carbon filter delete and RPI Ram Air Scoops. the power is insane and it just keeps on pulling all the way to redline. Not sure how much the meth is helping it but it ran consistent throughout the day. I couldn't wait to dyno. Finally got some dyno numbers and there she was 40whp and 30wtrq down low and 20-30 gains all through the mid range to redline. Imagine that's on a dyno that doesn't get the real velocity of the air as on the street. Who knows the true gains but thats what the Vbox will be fore. Now for the true test my F10 M5! Should be a better test comparing a stock car with just a bolt on intake. Don't truly know what to expect and as for the two different stock intake styles of snorkel and covered metal will see if the car is not effected in any way. Now to get the M5 to adapt back to its normal self, Damn I hate the thought of driving a slower car lol. Have a buddy of mine that has a M5 would be a good comparison run before and after. Lets hope he accepts the challenge. Hope you guys enjoy this post! Last edited by m6beast; 09-04-2016 at 10:03 PM.. |
08-21-2014, 10:38 AM | #6 |
Rep 745
Drives: '14 M5 CP & '62 corvette
I cant wait to see the results.
2014 ///M5 Singapore Grey Metallic, Black Extended Merino, Anthracite Wood Trim, Comp Pkg, Driver Assistance Plus, Exec Pkg, Lighting Pkg, B&O, 343M Wheels (11.597 @ 122.44MPH)
Mods: Gloss Black Wheels, 35% 3M Tint, IND Gloss Black (LCI Grilles, Side Markers, Rear Emblem) IND M5 Floor Mats, RKP (McRae Splitters & Rear Diffuser), Passport 9500ci, Suntek PPF-C, M Door Projectors 1962 Corvette Convertible Red/Black (Gone:'11 750Li, '09 Z06, '08 550i) |
08-21-2014, 05:29 PM | #9 |
Rep 883
08-21-2014, 07:27 PM | #12 |
Rep 792
Yeah doesn't help for its still has to suck air instead of a compressed ram air approach, which is what the caps do. The rpi ram air scoops help guide the air to the factory intake helping more volume of air.
08-23-2014, 12:33 AM | #13 |
Rep 4,106
I have snorkels in mine. Will wait for your results.
08-23-2014, 06:22 AM | #14 |
Rep 792
Well I believe the car is ready for a stock Dyno run hope to get it later today or Monday. Still trying to find a good level road for a 60-130 Vbox run. Have some good ones but they slope a bit at the end of the mark. Might not have a choice and at least have some data to compare to. As long as both runs, stock and intake are on the same stretch of road it will be a good comparison.
Will install intake next week. Will take some readings of A/F's at first start up and first third gear pulls. Should be pretty lean till it adapts. Ill make sure to keep documentation on A/F's as well |
08-28-2014, 07:01 PM | #16 |
Rep 792
Well got the base Dyno run today in both gears 4th and 5th. This was completely stock car with charcoal filter, stock paper air filter and stock boost.
08-29-2014, 02:04 AM | #18 |
Rep 792
Tell me about it! I always felt it seemed stronger than other M5's I've driven, anyway will be running some Vbox runs Before the intake install and document peak air fuels on the street. Then will be installing the intake. Once adapted back to the Dyno and Vbox again.
Wanted to go to the track but those plans fell through. Either way ill have all sorts of data to look at hoping some great gains as what the M6 showed. Ill keep it coming! |
08-29-2014, 03:54 AM | #19 | |
Rep 611
08-29-2014, 09:22 AM | #21 |
Rep 792
No it's stock, I can say its stronger then other M5's I've ran. Here is a previous Dyno run with charcoal filter delete only and the numbers are even higher "580 whp and 540 wtrq". At the time the car had only 1000 miles on it. Then installed the BMS with 3 lbs boost and did a couple more pulls didn't even give it time to adapt.
Here are the results This time started from the beginning base run, custom intake, custom catless DP, custom muffler delete, then the BMS. The M5 is my test mule on all these products Last edited by m6beast; 08-29-2014 at 09:42 AM.. |
08-29-2014, 11:52 AM | #22 |
Rep 792
Everything out f the car now ready to prefit intake make sure fits just as good without too many can he's compared to the M6 do to its size
