      07-01-2014, 02:35 AM   #1
Brci
Drives: M5 - individual
Tracking tyre pressure
Hi,
Could you please guys help how much to deflate the tyres for track use of F10 M5? I'm having the 343 M wheels in 20" size.
Thank you.
      07-01-2014, 06:14 AM   #2
Drives: Black M5
If your going to be tracking the M5 on a hot day, I'd go to about 32psi on all 4 tires. If it's really hot out, you'll see temps over 120 degrees in the tires.
      07-01-2014, 09:10 AM   #3
Northern X5M
Northern X5M's Avatar
After a hard 20 minute lap session, the pressure in my tires went up 8-10 psi.
      07-01-2014, 09:13 AM   #4
Brci
thank you so much for the answers
      07-01-2014, 06:14 PM   #5
gmd2003
gmd2003's Avatar
352
Originally Posted by Brci
Hi,
Thank you.
After the first session come in immediately and check your tire pressure . This will be your hot pressure which should be within 1 psi of where you were on track . The PSS likes to be at 34-36 psi hot temp . Depending on you're experience level , ambient temp , track surface temp , humidity in you're tires ( most important factor ) the tire temps on a 600 hp 4xxx pound car on track can increase 8-10 psi !! So throughout the day you will be releasing air from your tires to maintain optimal pressure . If you don't then you will run over pressure and loose a significant amount of traction , bc of reduction in tire contact patch .
      07-02-2014, 08:58 AM   #6
thebishman
Drives: ‘24 iX M60
Some ultra high performance street tyres have small 'triangles' slightly raised on the top of the sidewall tread showing where the maximal contact patch should be. If you aren't noticing that the tread wear is coming over to those triangles you are over inflated; if the tread wear is past the triangles, then you are under inflated. Just another data point to use. What is the gold standard of course is tyre temperature which you should have someone measure for you in the hot pits. You will be attempting to have the same hot temperatures across the whole of the contact patch. Furthermore, remember that you most probably will have to have different psi in the tyres, front, rear, side to side, depending on the layout of the track and whether it is clockwise versus anti clockwise.
Taking the time to get tyre pressures right is vital not just for safety or increased speeds and better handling, but also in tyre longevity. Having a $400 tyre 'chunk', (throw off tread blocks), and be ruined makes for a very expensive weekend! lol
Good luck and have fun.
