03-27-2014, 01:00 PM | #1 |
Rep 105
Dinan Sway Bar... End links
Installed the Dinan sway bars but the end links even threaded all the way down are almost two inches off using KW V3's has anyone has had this problem?
15 M5 Alpine/Sakhir
14 M5 Alpine/Sakhir 13 F-350 Dually Platinuim 87 735i 09 G37S Pearl White/Red 600hp stroker supercharged |
03-27-2014, 01:05 PM | #2 | |
Knight Commander
559
Rep 5,948
2022 Mercedes-Benz EQS 580
03-27-2014, 02:57 PM | #3 |
Perennial PFC
336
Rep 1,274
I still have stock everything, but when I installed the CP bars in the M5 there was some misalignment there too. As I remember the bar end hole was about an inch from the linkage bolt. What I did was leave the mounting bolts very loose, just four or five turns in to engage the threads in the mounting points. That would allow me to move the sway bar ends to better engage the linkage, and I could push the linkage bolt through the mounting hole on the bar. Then I tightened up the mounting bolts and it all works nicely. Similar situation for the rear bar also.
03-27-2014, 03:32 PM | #4 | ||
Rep 105
15 M5 Alpine/Sakhir
03-27-2014, 03:35 PM | #5 | |
Rep 105
15 M5 Alpine/Sakhir
03-27-2014, 03:48 PM | #6 |
Perennial PFC
336
Rep 1,274
The stock BMW bar, both standard and CP, are bonded to the rubber mounting bushing and have a predetermined angle once the mounting bolts are tightened. From the pictures I've seen of the Dinan bar, it can move independently of the mounting bushing, at least before the bolts are tightened? If that's correct and you haven't tightened the mounts, you could lower the bar to accommodate the longer linkage arm that Dinan furnishes, couldn't you? Two inches lower though and I'd be a little worried about clearance issues.
03-28-2014, 12:27 PM | #7 | |
Rep 105
15 M5 Alpine/Sakhir
07-30-2014, 11:06 AM | #8 |
Rep 1,917
Was this resolved? I have Dinan sways and will be installing V3s in the next few weeks.
Matt
07-30-2014, 02:30 PM | #9 | |
Rep 1,840
I know it's not kv3 but may help you ? Could there be a special install trick to get it setup ?
07-30-2014, 03:39 PM | #10 |
Rep 1,840
Nice brake line upgrade =)
07-31-2014, 10:53 PM | #11 |
Rep 105
They worked just fine... They looked a little strange on the lift but on the alinement rack they looked fine...
15 M5 Alpine/Sakhir
11-24-2020, 09:16 AM | #12 |
Big girls don't cry.
125
Rep 506
I came across this thread when I did the same install yesterday (KWV3 & Dinan Sways). It looks like Dinan has updated their endlinks with a shorter design to get rid of this issue and prevent stock endlinks from being installed with Dinan sways.
