      01-03-2019, 10:40 PM   #1
pcohen15
pcohen15's Avatar
380
Drives: 2013 F10 M5, Singapore Gray
Plugs and coils, or just plugs?
I have 70k miles on my 2013 F10 M5. The plugs were changed (based on Carfax) at 26k miles. The car is running fine (no misfires) in all regards but I'm planning to change the plugs to stay ahead of any problems and they are due.
I have an indy shop that will replace the coils as well with no additional labor charge. FCP Euro is running a special until 1/7 with 19% off, so I can save some money buying the parts now.
I've read many posts about replacing coils. Some posters say no need to replace the coils unless there's a problem. But I'm wondering since I can save a bit by buying coils and plugs now, and not have to pay extra to have the coils installed, it might be a good idea.
This might be a matter of whether or not I feel like spending an extra $185 to replace the coils. Or is there a mechanical/technical reason why I should replace both the plugs and coils together?
Given the infrequency with which both plugs and coils are replaced, I'm thinking to just go ahead and have both replaced.
Or an I missing something? Thanks for your opinions.
1972 Bavaria> 1973 3.0Si> 2013 328i> 2009 E92 M3> 2013 F10 M5: Singapore Gray over Sakhir Orange, Executive, Driving Assistance, B&O
      01-05-2019, 05:17 AM   #2
Craze
Buy genuine coils only and replace them
I had 2 bmws prior that ended up at dealer at inconvenient times due to coils going bad after that many km
The f10 i changed before it failed
      01-05-2019, 09:24 PM   #3
pcohen15
pcohen15's Avatar
380
Good enough for me. I'll change the plugs and coils.
Thanks!
      01-06-2019, 02:30 AM   #4
YanoM5
Drives: 2018 Individual Nardo M5
I went stage 2 and got a drive train malfunction. I was also around 73k miles. After researching many sites I too was stuck with your question.
I ended up buying 1 coil and after moving the original coils around and changing the plugs, I ended up not needing the extra coil. If money wasn't an issue, I'd do both though.
      01-06-2019, 11:34 AM   #5
pcohen15
pcohen15's Avatar
380
That's my plan. With sale pricing on the coils and no additional charge to install them, it seems worth it.
      01-06-2019, 05:46 PM   #6
Eno335
Eno335's Avatar
Drives: 2013 BMW M5
Just replaced all my spark plugs and coils due to a misfire in cylinder 6 and DT error. Went with NGK spark plugs, Bosch coils, mission Performance stage 2 tune and gapped my spark plugs to 0.022... all is well
      01-10-2019, 01:26 PM   #7
BDG671
Guam
Drives: 2013 M5
Planning to change plugs and coils. Just for peace of mind. Better now then being sorry about it later with a DTMAL. Good luck to you bud! Should be an easy job if you're doing it on your own. 😁
      08-13-2020, 03:47 AM   #8
AisteLau
Drives: BMW M5 M6
BMW M5 / M6 BOSCH EU6 injection/ignition service MEGA KIT
Kit includes:
8x BOSCH 0261500262 RP injector EU6
8x BMW 13537577649 Decoupling element
8x BOSCH 0242145541 High Power Spark Plug
8x BOSCH 0221504470 Direct Ignition Coil
2x BOSCH 0258017187 Upstream Oxygen Sensor
Can also be sold in separate parts.
Price: 1015EUR (1197USD) including VAT, excluding shipment.
VAT invoice available
All in stock. Shipped next day.
All 100% GENUINE
Seller - company
Payment - PayPal
Got my own '15 M5 with CP with 50K on clock last February.
Got this replaced on my own car - the power increase was enormous and no drivetrain errors since then.
