06-22-2020, 07:57 PM | #1 |
Rep 319
Green spark plugs
Changed my plugs. The ones on the drivers side seemed to have some of this green corrosion looking crap. I cant remember which two were the worst but they were on the drivers side.The connectors up in the coils looked ok. Did water or coolant somehomehow get in these spark plug wells?
I didn't have codes before or after. 30k miles. Any ideas? |
06-23-2020, 03:47 AM | #2 |
Rep 19,556
^ From leaky turbo coolant pipe hoses probably or a mechanic spilt some a/f while topping up. Those coolant pipes need to be checked regularly.
06-23-2020, 10:17 AM | #3 |
Rep 319
The turbo lines look almost brand new. All of the coolant reservoirs seem to have proper coolant. Maybe it leaked in the past. Ive only had the car a few thousand miles.
I just wanted to make sure there was no way coolant can leak from the heads on these cars into the spark plugs holes. I know oil can on this design but I wasn't sure about coolant. |
06-23-2020, 03:03 PM | #4 | |
Rep 19,556
06-23-2020, 03:43 PM | #5 |
Rep 319
No, I only noticed after i pulled the plugs out. The coils didnt tell much of a story to. Harder to remove but its not like the stuff was all over the coils.
06-25-2020, 07:17 AM | #6 | |
Rep 19,556
Another thing I wanted to ask was what gap did you set your standard plugs at, they are set at the factory but it's wise to check before you put them in. |
06-25-2020, 09:54 AM | #7 |
Rep 319
.032
They came pregapped at that and I double checked. The ones I pulled out were also .032. As long as they are all the same, I have read of bmw gapping them all the way down to .028 on spark plugs. And if you want to save yourself some money the bosch ZR5TPP330A has superseded the ZMR5TPP330. It is perfectly fine to use the newer plug. fcpeuro has them for 5.87$ each. Newer and cheaper. |
M5Rick60089.00 |
08-13-2020, 03:39 AM | #8 |
Rep 7
BMW M5 / M6 BOSCH EU6 injection/ignition service MEGA KIT
Kit includes:
8x BOSCH 0261500262 RP injector EU6 8x BMW 13537577649 Decoupling element 8x BOSCH 0242145541 High Power Spark Plug 8x BOSCH 0221504470 Direct Ignition Coil 2x BOSCH 0258017187 Upstream Oxygen Sensor Can also be sold in separate parts. Price: 1015EUR (1197USD) including VAT, excluding shipment. VAT invoice available All in stock. Shipped next day. All 100% GENUINE Seller - company Payment - PayPal Got my own '15 M5 with CP with 50K on clock last February. Got this replaced on my own car - the power increase was enormous and no drivetrain errors since then. |
