      05-03-2017, 08:39 PM   #1
brandonwuwux3
Drives: f80 m3cs
DRIVETRAIN MALFUNCTION (no codes popping up when pugged in)
so i know there are a lot of DTMAL threads, i read all of them! I recently got one and when i brought it to my local indy shop they plugged in the snap on code reader and no codes popped up except my catless downpipe code. After i left the code popped up again when i did a 60% throttle first gear pull and then when i shut off the car it went away. Anyone know if this is a spark plug and coil issue? First time i had power loss and second time DTMAL it was just the warning but car ran the same.
Royal Flush car crew, E92 black m3,Work brombacher, kwv3, 3D lip, VRS style difuser, CSL carbon trunk, Performance steering wheel, Full elite exhaust,Evosport pulley, Afe stage 2 intake
      05-03-2017, 10:40 PM   #2
ARC550
Try cleaning mass air flow sensors. They usually throw random stupid codes when dirty.
      05-04-2017, 03:02 PM   #3
BPMSport
BPMSport's Avatar
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
They must not be reading it with a proper tool because a Drivetrain Malfunction will always store a fault.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      05-05-2017, 02:46 PM   #4
brandonwuwux3
Drives: f80 m3cs
Snap on code reader, is that not a good one?
      03-26-2019, 01:46 PM   #5
naiza3k
Drives: 2013 M5 & 2019 x7 xdrive50i
Did you ever get this figured out?
I'm currently running a flash tune and just had this issue pop up yesterday. I plugged in the OFT tablet and no codes were shown.
The engine went to limp mode right away but when i turned the car off and back on it was running normal but no codes...
2013 M5 Space Gray, Piano Black|Night Vision|Every option|6MT|RW Carbon front Lip|Vorsteiner Rear Diffuser|
2019 x7 50i White, Loaded | chrome delete | black grill |
Previous: 2015 X5 Graphite, |All options| - 2014 435i Xdrive Msport, |Fully Loaded|6MT|FBO|JB4|Front,side,rear lips/spoilers|- 2015 320i Xdrive, |Wife's beater| - 2008 535i Xdrive
      02-13-2020, 09:50 PM   #6
sumairm
Drives: 2012 Monte Carlo Blue M5
I had DTMAL similar situation under load and it was a spark plug issue, I went and replaced all 8 and 8 coils and haven't had any issues. If you're tuned make sure to gap the plugs correctly.
