04-01-2018, 06:54 AM | #1 |
Rep 3,071
Anyone switch oil to 10w-60?
Thinking of switching at net refill. Anyone do this and have issues?
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
04-15-2018, 04:03 PM | #2 |
Rep 142
10W-60 Not to be Used in the S63TU Engine
G’day
That Oil specification will cause harm to your engine and as a result all sorts of problems down the track. It was specified for the previous M5 E60 S85 (V10) engine BUT not ours. The S63TU requires (from the owners manual) : When selecting an engine oil, ensure that the engine oil belongs to the viscosity grade SAE 0W-40, or malfunctions or engine damage may occur. As an alternative, you can also use motor oils with a viscosity grade of SAE 0W-30.◀ The engine oil quality is critical for the life of the engine. Suitable engine oil types You can add engine oils that meet the following oil rating standards: Oil rating BMW Longlife-01. BMW Longlife-01 FE. Cheers Bruce |
04-16-2018, 04:06 PM | #4 |
Rep 142
Oil & TBN
G’day
I did a lot of research about BMW approved oils and i use (insist) on Mobil1 0W-40 (which is approved by BMW & Mercedes AMG & Porsche). I use High TBN (Total Base Number) oils because they have a greater ability to resist engine wear and tear (pollutants associated with the combustion process) . And I have used this in both my Bmw 135i M Sport (N55 Engine) and now my M5 with great success . I change my Oil and Oil Filter every 12 months regardless of km/miles. Our family has owned Bmw’s for over 40 years and we are pedantic about Annual Oil & Filter changes to protect our engines. Our engines are immaculate on tear down for overhaul/heavy maintenance. I do not get/suffer any Oil Burn/Consumption between Oil Changes . Cheers Bruce |
04-23-2018, 08:56 PM | #5 | |
Rep 1,857
However 30 or 40 I don't think it makes much difference. |
04-23-2018, 09:01 PM | #6 |
Rep 1,124
05-20-2018, 07:02 AM | #7 |
Rep 3,071
I spoke with Redline and they recommended going up to 10w-40 to slow down the oil burning. Also, I live in South Florida so lowest temp here is 40s (rare) with lots of 80s-100
05-29-2018, 04:55 AM | #8 |
Rep 687
I dont get people's fascination with changing oil weight from manufacturers specs
Thinking valve tappet noise or oil usage determines if the car prefers this oil or the other |
07-19-2018, 10:29 AM | #9 |
Rep 47
Why would you want 10W-60? That oil is as thick as syrup. I had heart attack every time I tried to start my 07 M5 during the winter months, the car started up like a diesel truck. I had to switch to 0W-40 during winters.
2015 M5 CP - Alpine White - My joy ride
2013 LS 460 - Pearl White - Wife's 2007 M5 - Black Sapphire - sold |
ticat9285.00 |
08-25-2018, 01:23 AM | #13 |
Rep 142
If you Rebuild Motor Don’t use 10W-60 Oil
The S63tu requires a specific viscosity in order to flow cold and hot ; a 10w-60 oil will cause untold wear/damage to your engine .
This oil was approved and recommended on the previous E60 M5 S85 V10 engine but NOT ours. BMW Technical Bulletin : Favorable Viscosity Temperature Behavior “Viscosity is the tendency of oil to resist flowing. Engine oil, when cold, should be thin enough so that the engine can be cranked over. Hot oil should be thick enough to maintain proper lubrication.” BMW M5 F10 : “When selecting an engine oil, ensure that the engine oil belongs to the viscosity grade SAE 0W-40, or malfunctions or engine damage may occur. As an alternative, you can also use motor oils with a viscosity grade of SAE 0W-30.◀” Cheers Bruce |
08-28-2018, 03:10 PM | #14 |
Rep 19,541
Using a 10-60 oil on the M5 S63tu is bad news for the timing chain,too thick and may cause premature wear. For UK moderate climate I use 0-30 Edge with LL04 rating which is higher than Mobil 1 0-40 LL01.
09-09-2018, 11:27 PM | #16 |
Rep 843
10W-60 is to be used in high hp N/A engines. With stock engine I would stick to same weight OEM recommends.
I would suggest using a better oil than what BMW uses, a full ester based synthetic. Liquid Molly, Motul... |
02-07-2019, 05:39 PM | #17 |
Rep 11,891
10-60 is barely acceptable even in the S85/S65. That's why most people went to M1 0-40. I know this because I owned a S65 motor. After much research, it was recommended that M1 0-40 was easier on the bearings and simply delayed bearing wear. (Did not eliminate due to bearing design)
You're asking for a lot of issues putting in 10-60 for the S63 motor that required a thinner oil to begin with. Just stop it. Use OEM 0-30 or LL-01 LFE-01 0-30 oil with better friction additives |
