09-28-2015, 10:48 PM | #1 |
Rep 2,062
New injectors, finally runs but now a grocery list of errors
Over a two week span I'd taken my 2010 X5M apart to remove both PCV hoses running to the valve covers, removed the plugs and injectors, the front window was randomly replaced in the middle of all this by Safelite for a rock chip, then once parts arrived, everything was replaced with all new parts with the assistance of a buddy who's a full time tech at A BMW of Seattle. During the two weeks period the battery had died for likely multiple reasons...door opened and closed randomly (which wakes the computer, primes the fuel pump, etc) so I finally put a trickle charger on the car. To my ignorance, I'd plugged it into the switched outlet that only worked when the lights were on in the garage. After realizing the battery was stone dead, I switched to another outlet that was constant, but even after a few days, it was still dead...I finally removed the battery and charged it on my work bench for 24hrs.
After we finally got everything reinstalled, we threw the battery back in, but it still wasn't enough, the battery from the GF's Scion wasn't even but we finally got it to start using the battery from my Harley F150. Car stuttered a little bit but ultimately it's finally running like a top. Issue is now that I've noticed oddities that no matter how many times I reset the codes using my Android phone and an app called Carista, I still can't get things to operate as normal. iDrive gives me an error message saying "Lighting system! Stop vehicle" and "Seat Calibration" error messages - my windows won't roll down via the normal window switch (only the rears and sunroof open and close via the keyfob), no interior lights, power folding mirrors and mirrors themselves and I've got a car on lift icon that won't go away. Google searches have led me to believe it could be anything from a blown LCM light control module, all the computers just needing to be recoded so they see each other to maybe even a fault caused by the window company replacing the rain/headlight sensors since my headlights won't shut off, no marker lights, no dash lights, no turn signals, no hazards and the headlights themselves won't turn or self level while the car is moving. Stock battery is back in the car, but the codes remain. Another BMW tech buddy suggested doing the simply system reset of disconnecting the battery and touching the terminals together for 15 min, so I'll try that this evening, but nevertheless I figured I'd post these here...all I ask is please to keep the replies factual vs "I heard from a friend" scare tactics because I've read some of those today when people said that they either could code or had to replace modules in the footwell, the LCM, etc to getting a tech who knows what they're doing and just reset it all. These are the codes that came up after finally get a good battery in the truck, start it for the first time and then running codes: OBD2 - confirmed: U0100 - Lost Communication With ECM/PCM "A" OBD2 - pending: P1701 OBD2 - pending: U0100 - Lost Communication With ECM/PCM "A" OBD2 - pending: P16A3 OBD2 - pending: P0172 - System Too Rich Bank 1 OBD2 - pending: P0175 - System Too Rich Bank 2 OBD2 - permanent: U0100 - Lost Communication With ECM/PCM "A" Transmission: 507D Transmission: 50DC Transmission: CF2F Transmission: CF30 - Check Control message Transmission: CF33 - Delay requirement ACC Transmission: CF37 - SMG 3 Transmission: 55C3 Transmission: 55D0 Heater & air conditioning: E71F Rear heater & A/C: E75E Traction/stability control: 5DCF Traction/stability control: 6EC4 Traction/stability control: 6EA5 Traction/stability control: 6EC8 Airbags: 9408 - Undervoltage during self test Airbags: 93D0 - Undervoltage Instrument cluster: 931B Instrument cluster: 931D Instrument cluster: A3B0 - CAN signal fault dimming Instrument cluster: A3B4 - CAN signal fault light system Instrument cluster: A3C1 Instrument cluster: A566 Dynamic management: 641A Dynamic management: 6460 Tire pressure monitor: 604F Tire pressure monitor: 6050 Tire pressure monitor: 6051 Tire pressure monitor: 6052 Parking brake: 6023 Trailer: AAAA Trailer: AAAB Trailer: E559 Car access system: A0B1 Central electronics: A2CD Central electronics: E2D5 High beam assist: E0D5 - unknown failure High beam assist: E0D8 - state of lamp Center roof module: DE8B Driver's seat: 9E77 - Normalization error SLV Infotainment system: C588 Infotainment display: A475 - Ignition failure Infotainment display: E5D8 Heads-up display: A4EB Heads-up display: A4F8 - CAN Message failure These are pretty much all the codes that remain even after countless resets: OBD2 - permanent: U0100 - Lost Communication With ECM/PCM "A" Transmission: 55C3 Transmission: 55D0 Heater & air conditioning: E71F Rear heater & A/C: E75E Traction/stability control: 6EC8 Traction/stability control: 6EC4 Traction/stability control: 6EA5 Traction/stability control: 6F4E Traction/stability control: 6DE6 Instrument cluster: A3B0 - CAN signal fault dimming Instrument cluster: A3B4 - CAN signal fault light system Instrument cluster: A3C1 Instrument cluster: A558 Instrument cluster: A559 Dynamic management: 6460 Trailer: E559 Central electronics: E2D5 High beam assist: E0D5 - unknown failure High beam assist: E0D8 - state of lamp Driver's seat: 9E77 - Normalization error SLV Infotainment display: E1CD - unknown failure Infotainment display: E5D8 Heads-up display: A4F8 - CAN Message failure OBD2 - pending: P0175 - System Too Rich Bank 2 OBD2 - pending: P0172 - System Too Rich Bank 1 OBD2 - pending: P0308 - Cylinder 8 Misfire Detected (likely my fault for getting into boost before coding the injectors )
04-27-2016, 10:29 PM | #3 |
Rep 2,062
Turns out due to letting the battery die, a module called an FRM3 died. They're actually a common failure item, BMW has since come out with updated modules...it's a software issue where it goes into bootloop. There are people on the boards who'll repair them for $150.
The injectors have a service campaign, so anyone with older injectors can get a service loaner and they'll be replaced for free to at least index 12 injectors. The PCV system is becoming a notorious item on these vehicles as well. There's yet another service campaign for the connecting line (middle in LH picture), but ultimately all 5 lines should be replaced roughly every 60k. I replaced the two in the RH picture because they were weeping oil, the other lines I replaced due to being brittle or leaking oil.
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's Last edited by m5james; 01-10-2017 at 04:10 PM.. |
