Go Back   M5POST - BMW M5 Forum > M5 Classifieds > Sponsors Classifieds
      10-08-2012, 03:37 PM   #1
Nate@IND
Nate@IND's Avatar
2868
iND F10 M5 Cosmetic package
Similar to the E9X M3, BMW gave enthusiasts a head start with the elimination of the chrome window trim in favor of their gloss black "shadow line" trim. Unfortunately, BMW did not address the chrome front or side grills.
With BMW leaving off at the window trim we decided to pick up the pieces and offer a high quality painted solution for the F10 M5 community. All IND front and side grilles utilize the OEM part as a base to ensure a 100% fit. The original BMW chrome base does require a touch more preparation than if we had used an equivalent aftermarket part, but the end result is a product with perfect fitment.
***Please specify if F10 M5 has the Night Vision option in the front grilles***
LCI Package
https://ind-distribution.com/product...etic-package-1
Pre-LCI Package
https://ind-distribution.com/product...ackage-pre-lci
Package A:
F10 M5 Gloss black front and side grilles (matte black or body color) with optional Light or Dark LED's
Package B:
F10 M5 Gloss black front and side grilles (matte black or body color) with optional Light or Dark LED's + Painted reflectors
Package C
F10 M5 front and side grilles (matte black or body color) with optional Light or Dark LED's + painted reflectors + custom painted rear M5 emblem
Photos-
AW Surrounds + Gloss black centers + Light LED's
Frozen Black Night Vision grilles-
Frozen black side grilles with Frozen LED's
AW Surrounds + Matte black center + Clear LED's
Azurite black Side grilles with Surrounds and center painted-
Silverstone II A29 Surrounds + Matte black centers + Clear LED's
Black Sapphire surrounds + centers + clear LED's
Originally Posted by IND Distribution View Post
IND Side Marker Installation Procedure
Tools required:
1.) Step one is to ensure you provide yourself with the most comfortable installation environment. Our technicians are accustom to working with body tools around paint so in the installation photos you will notice no painters tape was used. With that being said we do recommend the DIY installer uses painters tape to frame the side marker. Framing the side marker with painters tape will protect your paint in the event that the hand gripping the nylon pry tool accidentally slips from the side marker.
2.) With the use of a flexible bondo spreader begin to separate the side marker from the fender. The F10 M5 side marker is held in by plastic tabs so the purpose of the bondo spreader is to create room for the nylon prybar to do its job.
3.) With the bondo spreader creating a view of the mounting tabs, please take note of these tabs. There are 3 tabs on the top portion of the side marker, 1 toward the front of the vehicle, and 3 more tabs on the underside. The best option is to work from the top down as a loose top will allow you to simply wiggle the bottom of the side marker free.
4.) with the bondo spreader in one hand and the nylon pry bar in the other, carefully pull the bondo spreader toward your body. This action will result in exposing the mounting tab. With the tab exposed press the nylon pry bar down on the tab with light pressure. The pressure from the pry bar will release the tab from the
5.) Repeat step 4 across the top portion of the side marker all the way to the side tab located in the direction of the front bumper.
6.) AUCHTUNG! Do not pull the side marker out of the vehicle without first removing the clip from LED power cable.
7.) Now that the side marker is free from the LED power cable you are now able to install the IND Painted Side Marker. The side marker will simply snap into place. First, reposition the LED power cable into the male connector on the LED. Similar to the removal place the top clips into the fender housing and carefully push into the fender.
8.) Ensure that both turn signal LED's function properly before driving.
Viola!
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      10-09-2012, 04:27 PM   #2
Nate@IND
Nate@IND's Avatar
2868
Imola set that just went out today.
      10-11-2012, 03:27 PM   #3
Nate@IND
Nate@IND's Avatar
2868
Photo of the Light tinted LED option-
      10-15-2012, 09:46 AM   #4
Nate@IND
Nate@IND's Avatar
2868
Singapore Grey F10 M5 with iND front and side grilles
      10-15-2012, 10:00 AM   #5
SlammedR8
SlammedR8's Avatar
Drives: 2019 X5 40i/2020 R8 V10 Spyder
Great Stuff Nate!
Might be getting an F10 M5 next summer...nothing is for sure yet. Looking at some other, very different options!
But if I do end up with the M5, you know I will be calling you for the Eisenmann and all the stuff above!
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      10-15-2012, 10:04 AM   #6
Nate@IND
Nate@IND's Avatar
2868
Originally Posted by SlammedM6 View Post
Great Stuff Nate!
How have you been man
Let me know if you end up getting a new beast.
      10-16-2012, 12:58 PM   #7
Nate@IND
Nate@IND's Avatar
2868
Close up shot of the Gloss black front grilles on Singapore Grey
      10-19-2012, 11:42 AM   #8
Nate@IND
Nate@IND's Avatar
2868
Just had another Beast in the shop yesterday. We installed a 3D Design pedal set and exhaust, Gloss black front and side grilles + Black Sapphire front reflectors.
Side grille install (Gloss surrounds + matte center + Clear LED's)
      10-19-2012, 10:19 PM   #9
SSR
SSR's Avatar
Drives: F10 m5
Ordered mine,saphire black hope the paint quality is perfect...
I will post pics..
      10-19-2012, 10:30 PM   #10
GOLFFRR
GOLFFRR's Avatar
10816
Drives: GOLFFRR cart
nice! def a must IMO
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      10-23-2012, 12:47 PM   #11
Nate@IND
Nate@IND's Avatar
2868
I will post pics..
They will be perfect
Thanks!
Frozen black set that just went out
      10-30-2012, 09:39 PM   #12
koxal
koxal's Avatar
Drives: 2015 LBB F85 X5M
2015 BMW X5M  [0.00]
2010 BMW M3  [0.00]
2013 BMW M5  [0.00]
Hi Ind Dist,
I need the whole package except for the front grills.
My dealer already installed the perf front grills for free.
I want the side grills in performance part's color. Inside and out with no tint on the lens.
Car is singapore gray. I want front and rear reflectors.
Can u pls pm the price to 07047 and earliest shipping date? We will take it from there..
      11-02-2012, 04:49 PM   #13
Nate@IND
Nate@IND's Avatar
2868
Originally Posted by koxal View Post
Hi Ind Dist,
PM sent
      11-11-2012, 07:07 AM   #14
SSR
SSR's Avatar
Drives: F10 m5
Got my side painted grills and they are perfect very happy I will order kidneys now (cameron)
      11-11-2012, 09:30 AM   #15
Nate@IND
Nate@IND's Avatar
2868
Thanks! Front grilles are in stock and ready to go.
      01-08-2013, 09:37 AM   #16
Nate@IND
Nate@IND's Avatar
2868
Gloss black front + side grilles in stock now
      01-08-2013, 07:21 PM   #17
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
If u opt for gloss black side gills that leaves the inner piece matte like OEM right? gloss only pertains to the surround piece?
2016 991.1 911 Carrera GTS
      01-09-2013, 09:37 PM   #18
Nate@IND
Nate@IND's Avatar
2868
That's correct gloss black surrounds + matte black inner.
      01-16-2013, 09:37 AM   #19
Nate@IND
Nate@IND's Avatar
2868
F10 M5 Cosmetic packages are in stock and ready to go!
      04-18-2013, 06:02 PM   #20
gneypiks
Drives: f10 m5 white
Need a set of frt /side grill n side marker.....are they in stock?
      04-19-2013, 07:07 AM   #21
Nate@IND
Nate@IND's Avatar
2868
In stock and ready to go. Shoot me a pm or email to info@ind-distribution.com
      01-05-2014, 02:48 PM   #22
FASN8N
Drives: 328i Wagon
Just installed my IND cosmetic package, very happy with the results
